Question about Makita LS1013FL 15 Amp 10 Inch Dual Bevel Compound Sliding Miter Saw With Laser And Fluorescent Light
Makita LS1013 miter saw motor runs very slowly
The saw will start, usually, but only runs very slowly and not at a consistent speed. This model have a soft start. I'm think it may have something to do with the controller. Does that sound right? The saw is about years old and hasn't been used hard. Is this something that can be fixed or will it need a new part?
Thanks for the help,
Dave
  • Anonymous Apr 09, 2009
    need part
    Novelist:
  • 99 Answers
Could be a bearing problem. If the bearings are dry and seizing up they will hinder the motor speed. Alternatively, if they are worn and allowing lateral movement in the motor the armature will rub against the field windings when it all magnatizes (sp?). I would investigate bearings before electrics. Hope this helps, good luck.
Posted on Nov 29, 2008
How do I view the owners manual on line for a Makita LS1013 sliding miter saw
I have attached a link with the parts breakdown and the owners manual both in PDF format.
The parts breakdown should help you, if not let me know and I'll try to talk you through it.
Makita Products Tool Support
Mar 11, 2015 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Can I bypass (hotwire) the controller on my Makita ls1013 Miter saw?
Not a good idea. Miter saw are too dangerous to be altering them in any way.
Aug 24, 2014 | Makita 10" Dual Slide Compound Miter Saw...
Makita LS1013 110V feels underpowered. What could have caused this? Brushes are barely worn.
How underpowered? running at half speed? If so check the wiring in the 110v plug. I have seen saws come into the workshop where 1 of the wires is connected to earth pin this results in 55v being fed to saw hence 1/2 speed. Is there heavy arcing at the commutator? if yes armature probably blown. If not still worth examining armature for discolouration, examine field coils at same time if everything seems ok then a possibility is the controller. You could try by passing the controller and if saw seems to run better then you know you need a new controller. It is located at the back of the motor. If you are not sure about electrics do not try this you may electrocute your self or blow the controller.
Feb 21, 2014 | Makita Saws
We need an op-erating manual for Makita miter saw, Model LS1013. Where can we find it?
Cut and paste the following link into your browser search bar, and you will be taken to the page that you need to get started:
http://www.makita.com/en-us/Modules/Search/Default.aspx?Param=ls1013
Then click on the appropriate full model number and you will next see links for the parts breakdown and manual for your saw.
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Good luck, and please provide feedback if this helps!
Dec 29, 2011 | Makita LS1013FL 10" Slide/Compound Miter...
Need owners manual for a mikita miter saw LS1013 to replace cover spring
Go to Makitatools.com and on the right side type in your model number and it will take you to a page where you can get the manual or the breakdown. Let me know if I can help further, I work on them everyday/
Jun 09, 2009 | Makita 10" Dual Slide Compound Miter Saw...
Makita LS1013FL manual missing
Yes go to Makitausa.com and type in your model number and you can download an owners manual for the tool. Let me know if you need any more help
Feb 15, 2009 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Makita LS1013 chop saw just started making a bad bearing noise and the elecric brake is not kicking in after the trigger is released.
You will have to check if it is a bearing going and the electric brake may not be getting any power to it now or it could be sticking.
Jan 23, 2009 | Makita 10" Miter Saw LS1030N
Brand new miter saw/ran for 10 hours power was not consistent, then nothing
What part of the motor has blown? There is the armature and field coil and they won't always need replacing at the same time. There are brushes as-well, but as they are quite cheap I'm guessing you have been quoted on one or both of the motor parts to be replaced. Have you asked the repair guys for a report. They should be able to suggest a reason for what has blown and why by looking at the faulty parts. Although most manufacturers and service agents have discretion over warranty claims, if your machine is more than a few months over htere is almost definately noting you can do on the warranty side of things.
Oct 16, 2008 | Makita 10" Dual Slide Compound Miter Saw...
Makita LS1013FL 15 Amp 10 Inch Dual Bevel Compound Sliding Miter Saw With Laser And Fluorescent Light Logo
881 people viewed this question
Top Makita Saws Experts
Marvin
Marvin
ray gallant
rlev_7
Level 1 Expert
Are you a Makita Saw Expert? Answer questions, earn points and help others
