Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Frigidaire LTF2940EE0 Front Load Washer wont spin.
It will wash clothes and drain but when it gets to the spin it shuts off.
HELP!!!
  • 1 more comment
  • sistergarden Nov 26, 2008
    My unit is doing the same thing, skipping the spin cycle, right to that loud annoying buzzer!
  • mrmrwashingt Dec 26, 2008
    Experiencing the same problem on machine I purchased less than 2 years ago. Repairman said speed control timer needs to be replaced. Repair cost....$400. Not sure what to do at this point.
  • unclebudus Feb 11, 2009
    Same deal, my LTF2940EE0 does everything it's supposed to except spin. It drains, can hear the pump pumping, but no spin. It then begins a rinse, agitates, drains, etc. At the very end of the cycle it does a clockwise/counterclockwise rotation a few times, then shuts off.
SOURCE: Frigidaire front loader washing machine won't spin...
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
Posted on Sep 24, 2008
SOURCE: Frigidaire front load washer (LTF600ES1) Error E20
took off the screw clamp and it had a sock in it. works great now thanks
Posted on Nov 08, 2008
huuum
  • 750 Answers
SOURCE: frigidaire front loader wont final spin timer stops at 7 min.
its_me_ac You probably have a faulty timer switch.
You can buy parts at this site , v
Please give me a good rating
Posted on Dec 05, 2008
SOURCE: ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
Posted on Aug 30, 2009
  • 1531 Answers
SOURCE: my frigidaire GLTF2940ES washes but doesnt spin on
replace the door lock mechanism
Posted on Apr 10, 2010
The washer is not spinning to get the excess water out of the clothes.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
My washer wont spin it washes but wont spin i have a Frigidaire Gallery
heatman101
Oct 26, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire GLT F 2940 ES Front Load washer. Spin is slow. Clothes wet
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 03, 2010 | Frigidaire Affinity ATF7000ES Front Load...
I have a Frigidaire front load washer. Model #: LTF2940EE0 Serial #: XC64319573 and it is not spinning on high speeds. It is spinning but only slow. When I put it on the rinse/spin cycle it spins in low...
Motor has some shorted windings. Timer switches to higher current for faster rotation and the thermal overload protection shuts the process off as the current is too high because of the shorted windings.
Oct 04, 2017 | Frigidaire GLTF2940ES Front Load Washer
Not spinning water out of clothes
CHECK OUT THE DRAIN MOTOR PUMP , it cpould be clogged , located where the drain hose is connected inside , youre gonna see 2 hoses connected to thi small motor , hope it helps , AJ
Nov 16, 2009 | Frigidaire GLTR1670A Front Load Washer
Frigidaire front loader wont final spin timer stops at 7 min.
Dec 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washing machine gtlf490e
ill save us some time that washer is one of the best out there i have one my self pop me an email at b4829@yahoo.com and check my4 boxes say in e mail front loader wont spin ill send ya something
May 21, 2008 | Frigidaire GLTR1670A Front Load Washer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
208 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
