Question about Western Digital Protege WD400EB 40 GB Hard Drive
Drive appears to have fouled computer
I have a Dell Dimension 2400 that has a WD400EB 40Gb hard drive. When I turned the computer on, the keyboard lights flashed but nothing else. No POST, no "Hit F1 to continue" - no video at all. The drive does not sound like it is running.
I tried a different sound card, unplugged everything except the drive, still nothing. I put the drive in another computer that was running fine - it did not boot. When I took the drive out, it still will not boot now.
Is there some obscure thing that a malfunctioning drive can do to a computer to render it useless?
Thanks in advance!
Dave
    Problem Solver:
  • 11 Answers
"Is there some obscure thing that a malfunctioning drive can do to a computer to render it useless?" Yes it can, however if you take out the HD and put in 1 you KNOW that worked fine and pc is still "useless" then i have no clue. Probably one of those things i just came across (especially with certain types of certain HD's): 1 out of every so many get out of the box broken. Useless. If you broke any seal your warranty is probably gone too, however try to claim your warranty annyhow and in any way, should this be the case (test with a healthy drive). Wine a lot and they might understand you case and send you a new one annyways, free with maybe only shipping cost (say you want to cover those if they don't want to do it initially). If you had the HD longer (not a fresh installation) it's probably fataly damaged, you can try repairing but it probably won't do any good.
Posted on Nov 24, 2008
Is wd1200jb-00gvc0 hard drive compatible with dell dimension 2400
That is a western Digital Hard drive compatible with most computers even Dell Computers
May 15, 2014 | Dell Dimension 2400 PC Desktop
Hardrive is unknown device in bios
The BIOS determines the maximum size hard disk the computer can support.
The max hard disk size for this model Dell is 80Gb.
To use your 250Gb hard drive, install this Hard drive into an USB hard drive case and use it as an external USB hard drive.
Mar 09, 2013 | Computers & Internet
No boot device available stike f1 to retry boot and f2 for setup utility diskette drive 0 seek failure a dell dimension 2400 series
Your computer cannot find a boot-able storage device, i.e. hard disk drive, to boot from. Either your hard disk drive is defective or the OS (operating system software) is corrupted and needs to be re-installed.
Jul 27, 2011 | Dell Dimension 2400 PC Desktop
Can i use my sata hard drive in my dell dimension 2400?
The HDD furnished with this model is:
Seagate Barracuda 40GB ATA/100 7200RPM hard drive
This model of PC pre-dates the use and popularity of SATA HDD technology.
Your answer is "No". Sorry!
Dec 03, 2009 | Office Equipment & Supplies
I have a PC Dell Dimension 2400 with a hard 40 GB
Basically when you install a new boot drive you need to install Windows operating system on the new hard drive, also the device drivers (eg video, audio, modem, LAN etc), your programs and data. The reason programs has to be installed is because the installation process copied DLL files to the System folders and makes changes to the registry.
You can only copy your data onto the new hard disk.
To avoid copying your data to the new hard drive, you can set up the old hard drive as second hard drive (ie. slave drive), if you delete the redundant folders and leave only the data folders then you have an adddition 40Gb of disk space.
Aug 27, 2009 | Dell Dimension 2400 PC Desktop
Before I start my dell dimension 2400 computer up, I have to disconnect my usb mouse and usb keyboard because if I don't I will get these 2 errors, Primary drive 1 not found and Secondary drive 1 not...
The resolution for this is to go into the BIOS with the help of F2. Then look for the option USB Legacy devices. If it is enabled disable it or vice-a-versa. Also look for Boot from USB devices. Please disable that option. And select the first boot device to be the HDD (Internal hard drive)
Jul 11, 2009 | Dell Dimension 2400 PC Desktop
Hard drive crashed
It all depends. Best bet is take it to a data recovery professional & see if they can recover anything for you. Hope this helps.
Feb 10, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 with secondary SATA hard drive keeps crashing
generally all computers can handle a secondary hard drive. i myself am a dell tech. why not try to increase the wattage output of your power supply from the present 200 or 250 watts to at least 300 or 350 watts to give enough provisions for additional devices that will be connected to your computer. normally a hard drive will get burned or fried because of a loose power cable connection. data cable will never fry your hard drive. try running the hard drive diagnostics if it passes then it should work well. try also using chkdsk /r in the command prompt to fix your hard drive if the damage is not that extensive.
Jun 20, 2008 | Dell Dimension 2400 PC Desktop
Western Digital Protege WD400EB 40 GB Hard Drive Logo
128 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
