Question about Linksys Wireless-G Broadband Router
Cant get wireless & broadband router connected
I have a linksys wireless router (borrowed with no manual) and am trying to connect it to my Siemens SpeedStream 4200 broadband router. Can get the wireless to come up on the laptop but can't connect to the internet on either the pc or laptop. If you can help be very grateful. A diagram would help as not very cluey around computers. Many thanks regards Sylvia
  • David Labossiere May 11, 2010
    what model is the linksys router
    Genius:
  • 1,689 Answers
The links below will show you how to manually install the device on your network
Setting up your Linksys router for Cable ISP
Setting up your Linksys router for DSL ISP
Setting up your Linksys router to have wireless security.
if you have other questions just let me know.
Posted on Nov 24, 2008
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696 Wireless G-Broadband Router support http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 27, 2013 | Linksys Wireless-G Broadband Router
Diagram to hook up wireless router
Are you trying to setup router?
You can do it manually without CD.
Connect the modem to the Internet port on Linksys router. The connect one computer to Ethernet port 1 on Linksys router.
Open the setup page of the router and change the settings manually.
See Linksys router setup
Jan 02, 2012 | Linksys Wireless-G Broadband Router
I am using linksys wireless g broadband router and i cant connect to the internet it says low connection or no connectivity
I believe you would have a cable connection and no a telephone connection because if you have the second one this router will not be of use to you.
Assuming you are using a cable provider:
http://downloads.linksysbycisco.com/downloads/WRT54GC-EU_V30_UG_NC-WEB.pdf
You could see if you are following all the steps from that manual in order to configure it correctly.
Kind regards
Mar 06, 2011 | Linksys WRT54GC Compact Wireless-G...
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
My Linksys BEFW11S4 Wireless-B Broadband Router? i cant connect in my internet and my PSP how can i do to connect it?
Set up an open wireless network or with WPA encryption. The PSP supports WEP/WPA but not WPA2 or Wireless G, it's a B device.
Also use a short passphrase and DHCP to lease IP Addresses.
Nov 03, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Cannot connect to wireless Broadband Router
Call linksys technical support. If they cannot help try this http://technicalsupport.blog.friendster.com
Feb 18, 2009 | Linksys Wireless-G Broadband Router
Cant connect to internet from laptop
The network key is stored in the router, and your manual will tell you how to access it.
If you don't have access to the router's web page, you'll need to reset the router and start over.
Dec 20, 2007 | Linksys Wireless-G WRT54G Router
Wireless G broadband router
Please go to www.linksys.com/download and download firmware version of your router. For manual upgrade call linksys at 18003267114 or check out other linksys numbers.
Oct 15, 2007 | Linksys Wireless-G Broadband Router
Cant connect my router
what is the source of your connection thru telepon line or a broadband connection or DSL?i need to know this........
Jul 16, 2007 | Siemens SpeedStream 4200 (13A4200001)...
Linksys Wireless-G Broadband Router Logo
252 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
