Computer does not boot up completely -shuts down by itself
Hi. I am having problems with my computer booting up completely. What happens is when I turn it on..power supply and fan turns on...it will go through the normal cycle of boot up...floppy drive lights up and dvd drive light lights up...then I hear this "clicking" sound repeatedly then the computer shuts off by itself. I tried unhooking the components separately and thought it might have been the DVD writer. Bought a new one. Restarted the system and then it shuts itself down completely again. Also tried swapping a different hard drive but the system still shuts down. What else could it be?
  • chris-tasker Feb 01, 2009
    i have the exact same problem...mine will only run in safe mode?
  • Anonymous Apr 07, 2009
    same problem as person above and i replaced hardrive and it still happened theeen i brought it to a friends house works perfect no shutdowns maybe the wall socket is shorted?
You hav problem with with your hard drive............
your c: drive partition may crashed.......
check with disk manager.......
otherwise
replace hard drive and install windows.......
Posted on Mar 04, 2009
  • nick1565 Mar 04, 2009
    check drive configuration in BIOS
    Sergeant:
    Champion:
  • 251 Answers
For xp there was a update called service pack 3 witch caused alot of compaq to just boot the shut off this seems to be ur problem although i am not sure of ur pc's brand hope this helps
Here to Help
Shaun
Posted on Nov 24, 2008
It keeps shutting itself off ?
When does it shut itself off? Is this happening time you press the power button and during the boot cycle it shuts off without completing the boot to windows? If it shuts down after you've worked on it for a while it could be that it is running hot. If you let it sit a while to cool off then press the power button, if it completes the boot cycle and allows you to work it is definitely running hot. Normally when they run hot if you immediately try to reboot, it will fail. If you let it cool off it will boot successfully. Computers run hot because of a fan not working, dust clogging the fan vents or the Thermal Paste around the CPU and Heat Sink has become hard or too thin to keep the unit cool. If it's not running hot you might have a power supply or motherboard issue. Try removing the power cord and press and hold the Power Button for 30 seconds to release any Static Buildup. Then plug the power cord back in and try to reboot.
Mar 18, 2012 | Dell OptiPlex GX280 PC Desktop
Hi, My Samsung R580 I3 JBB2-US keeps on shutting down. If I close the lid when I re-open it shuts down & I have to restart or it freezes and I have to force restart. Sometimes when I boot up it...
You can try go to Start - Control Panel - Power Options and check what you want computer do when you close the lid of your laptop. Fix that and restart laptop to apply the setting.
If the boot up not complete and restart by itself, in my opinon, there is something wrong on the start up process, could be hardware malfuctions, could be a software not compatible. Try check the start up process to see.(use Start- Run: msconfig)
If this happen often, you should call the Samsung customer services to find out. Laptop i3 should still under warranty.
Hope this will help.
Thanks for reading
Jul 20, 2011 | Samsung R580 Notebook
I deleted a virus from my computer. when finished it asked for me to restart computer, upon restart, the computer would shut down and not logon to windows desktop
Hi There,
It seems like you're having boot issues after the virus removal from your computer. I have encountered this same scenario before and what I did was to boot to safe mode and clear all startup items. Here's how:
Step 1 - How to go to safe mode :
  • 1. Shut down your computer
  • 2. Disconnect all USB devices,except your mouse and keyboard
  • 3. Restart computer and starttapping on "F8" key repeatedly until it boots to a different screen
  • 4. Wait for the initial logsto complete and choose "Safe mode only" when given the options.
Step 2 - How to clean up startup items :
  • 1. Click on start and choose"Run"
  • 2. Type "msconfig" then pressenter key
  • 3. Click on "Startup" tab
  • 4. Click "Disable all" touncheck all startup items
  • 5. Restart your computer
If same problems persist after completing the above steps, then there is a need to completely reinstall the Operating system of your computer using the CD that came with it.
Let me know if you need further assistance, I'll be glad to help.
Thank you for using FixYa.
Feb 25, 2011 | Compaq Computers & Internet
My laptop has problem when I turn it on then it suddenly shut down so what is the problem? that's the big problem.
Sounds like it could be a RAM problem. If you have more than one RAM chip in your computer remove one and try the computer again. If it works then either the RAM chip that you removed has failed or the RAM slot it goes is has. Shut down the computer and take the working RAM chip and place in the empty slot to see if the computer boots up. This will tell you then if it's the chip or the slot. If the computer doesn't boot up, just to make sure it's the RAM slot, take the other piece of RAM and place in the other slot and try to boot up the computer.
Aug 19, 2010 | Computers & Internet
My laptop shuts down right after booting up. It shows a blue screen witha message about checking the configuration of drive c. It gets to about 75% complete and shuts off! HELP!!
Try to boot up in safe mode, done by pressing F8 while computer is booting up then restart and let computer boot up regular, if you installed any drivers before this happen unistall them while you are in safe mode.
Nov 21, 2009 | Toshiba Satellite A105-S4034 Notebook
Problem booting into Windows.
This could be a hard drive problem. The hard drive is looking for the boot sector on it, but the boot sector is broken. Computer shuts down and tries again but your hard drive can't find the boot sector so it shuts down tries again etc.
Hank
Sep 24, 2009 | ECS C51GM-M Motherboard
Dell XPS 600 turns itself on to solid amber
Hi. the mother board seems to be having some initialization issues during boot up. this is common when the mother board is failing. i would check to make sure the battery on this board is working. if it is, the board my be ruined.
power board seems to be fine.
please rate and god bless.
Mar 17, 2009 | Dell XPS 600 PC Desktop
The computer starts then shuts down.
Try booting up the computer pressing whatever key the Dell needs to boot into BIOS (F10, Delete key, F1...pay attention to the screen) and leave the computer on for about 15min. See if it cuts off then. If it does its more than likely your power supply. If it doesn't then its not hardware related.
Mar 12, 2009 | Computers & Internet
Keeps turning off
Sounds like a hardware failure. Possilbly the motherboard, more than likely, the power supply.
But then - maybe neither.
Shut it off completely, once you restart, start hitting the F8 key ( once a second ) until you see the " Safe Mode" choices screen. Drop down and select the " Last known Good Configuration" option and hit enter.
If this doesnt work, try the same proceedures ( restart - F8 ) but this time select safe mode - at the top of the list.
If you sucessfully boot in safe mode, you have a system file problem that could be virus related, file table corruptions or registry problems or all combined.
We're here if you need us.
www.wvpcrepair.com
Oct 10, 2008 | MSI PT880 Neo FSR Motherboard
Computer wont completely boot
Nope a bad battery will not keep a machine from booting..
Does it shut off or do you get an error or does nothing come up when you turn it on???
Dec 18, 2007 | Computers & Internet
Computers & Internet Logo
744 people viewed this question
David Payne
David Payne
