Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Model 80 get stuck after agitate and will not spin out
The cycle will continue on pumping out all the wash water without spinning resulting in laundry that needs to be re-spun before on to the the dryer. If I catch it right as it is happening I can cycle the door, hear a click under the drum and it will spin out as it should. I have held the lid switch down and watched in get stuck after the agitation cycle. Need help narrowing it down to the gearbox / brake-clutch assm / or ?? Thanks for your help.
Model 110.23812100
  • 240 Answers
I have seen this on the same model recently, try lifting the lid during the neutral drain and reclose, if it engages spin then. then most likely your timer is bad too. The timer after two minutes of "neutral drain" will stop the motor (same effect as lid sw) then restart after a pause with spin/drain. this pause shifts the transmission to its next cycle which is spin. I found burned contacts in timer. Your timer list price is over $100 but easy to replace
Posted on Dec 01, 2008
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
"GE Quality Product Spacemaker Laundry"
you could have a broken belt or a frozen pump pulley. the leak has to be addressed to see where it's coming from. it could be from the pump hoses/connections. it could be the main tub seal that's leaking. if you're not handy with tools and test equipment, i suggest you call someone to have a look at it. these are problems that wont be resolved by pushing a button.
and thankyou for using this site. i hope you will continue to use this site.
if you have any further quesions or need further advice, repost another question. be sure to include the model number as well. you gave a good explanation, and that helps. anything you can think of can be of assistance
thanks,
mike
Jul 07, 2011 | GE Spacemaker Washer and Dryer Electric...
Washer went through cycle but washer was still full of water and laundry. Did not appear to have spun either. Turned the timer to spin and the timer made noise but did not spin or drain. Water has since...
sounds like the pump is goosed.....or may be just blocked............a penny is the ideal size to block a pump and stop it working...........let me know the outcome....
cheers
Mar 22, 2011 | Washing Machines
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water was overflowing over the top and flooding the laundry room
If it was left in the reset position then it could absolutely pushed the diaphragm in the air switch to a point that the contactor couldn't reach it. Set it on a large load, let it fill and watch it. If it starts to overflow, pull the plug out, if it continues filling, you need a new water valve on the washing machine and if it stops then you need a new level switch
Jun 16, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Water not draining during rinse cycle
check the drive belt for the pump under the machine
May 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Thin Twin Stopped Spinning at End of Cycle, H20 Will Not Drain
You have a sock caught in the pump, need to pull off outer case and remove pump and clear it out.
May 23, 2007 | Whirlpool LTE5243D Top Load Stacked...
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
151 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
