Question about Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool Duet Sport Gas Dryer - Works fine but makes loud noise
My dryer works as far as drying clothes but it makes a really loud noise almost as if large rocks were in it. It is not a loose button or zipper as we opened it up and looked. Any hint as to what it may be? We've only been using it for about 15 months. Thank you!
  • dbrewer333 Mar 17, 2009
    We also have the exact same problem.  When the dryer has been running for about a minute, it sounds like large coins or rocks are in the dryer.  I took apart the dryer and found that the blower wheel was very wobbly at the connection with the motor, and as it went around, there were small nubs of plastic on the outside of it that would hit the aluminum housing around it.  The housing and the large air outlet served to magnify the sound tremendously.  I tried removing the blower wheel by turning it in the 'remove' direction indicated on the wheel and it would not come off.
  • flyerned Mar 20, 2009
    I Have the same noise, my blower wheel is also loose. I need to look at the wheel support bearing. I'll let you know what i find
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
yriur
Posted on Sep 29, 2010
Why doesn't my dryer dry clothes?
You can find the Installation Instructions and your owner's manual here: http://www.kmart.com/whirlpool-duet-174-7.4-cu-ft-he-gas-dryer/p-02692332000P The links are about halfway down the page and are in red. There are instructions for cleaning the lint screen, which if clogged, will effect the drying time. Hope this helps.
Jun 25, 2014 | Whirlpool Duet WGD96HEAW 7.4 cu. ft. Front...
Whirlpool gas dryer doesn't dry
Make sure vent hose in back of dryer is not blocked or stopped up.
Mar 16, 2014 | Whirlpool WGD94HEXR Duet Steam Dryer gas
My whirlpool duet dryer works but it appears that the air is not evacuating from the baril. The heat and humidity built up and the clothes don't dry. Do I need to replace the fan and if so, how
YOU NEED TO CLEAN THE VENT ON YOUR HOUSE IF THE BLOWER WHEEL IS BAD ON THE DRYER YOU WOULD HERE THE NOISE AFTER THE DRY STOPS THE BLOWER WHEEL WILL STILL TURN AND MAKE A NOISE
Oct 29, 2012 | Whirlpool Duet Steam WFW9700V Front Load...
It is making loud sqeaking noises when turned on
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 04, 2011 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My dryer is making a very loud squeaking sound when I turn it on. Also inside is very hot within minutes.
heatman101
Asker
Dec 27, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
MY WHIRLPOOL DUET DRYER IS WORKING BUT NOT HEATING
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 12, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Loud Noise While Drying
Your rear drum bearing is dried up and need to be re-gresed with high temp grease
Jan 05, 2009 | Kenmore 60172 Electric Commercial Dryer
Dryer
Today my whirlpool dryer started making a loud noise. it is drying the clothes but the noise is loud.
Jul 06, 2008 | Kenmore Dryers
Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer Logo
2,049 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
