Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Water does not dispense
Ice maker is fine, but no water dispenses when button on front is depressed. Where is the water reservior and how does water get to outside of door?
  • 1 more comment
  • VRCARTER24 Dec 12, 2008
    WATER LINE IN FREEZER DOOR FROZEN. NOT FROZEN IN RESIVOR AND VALVE OK
  • Anonymous Dec 29, 2008
    water line does'nt work. ice maker does but not the water line.
  • DEAberle Feb 11, 2009
    I too have an issue wherein the water doesn't dispense but ice maker works. I did replace the water dispense valves to no avail. Where is the water dispense resevoir?
  • 74 Answers
There should be a water line that runs from the reservior that is in the fridge compartment under the appliance to a connector at the bottom of the freezer door, if water is getting to there then the water line within the freezer door is frozen . If water is not getting there then the reservior may be frozen or the watervalve may be faulty
Posted on Nov 28, 2008
Dispensing ice not working but makes ice fine and water works also
If your refrigerator has an ice dispenser, you are probably used to getting ice right away when a lever or button
is pressed. However, if you depress the ice maker button and nothing dispenses, there is an issue with your
refrigerator. There are a few different reasons why an ice dispenser would suddenly not work. It is important to
troubleshoot your refrigerator first to determine the problem. Some problems can be fixed at home, while others
must be repaired by a professional.
1. Remove the ice bin from the freezer and press the button on the front of the refrigerator for cubed ice.
2. Open the freezer door and hold down the switch on the door, which "tricks" the freezer into thinking the door is
closed, and push the lever or button to dispense ice. The motor behind the ice bin should turn. If it does not,
this means the motor is frozen.
3. Remove the motor, following the directions in your refrigerator's manual. Heat and dry out the motor with a hairdryer until the motor turns again, then reinstall the motor according to the manufacturer's directions.
Have a nice & a happy day : ).
Aug 15, 2011 | Kenmore Refrigerators
Whirlpool refrigerator water dispenser not working
hve u tried to clean any blockages in the unit.let me know wat other problem u face
Oct 23, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice maker will not dispense water or ice.
sounds like maybe the switch that is press to release water not working so it doesnt sent the signel to let water out dispenser
Sep 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
I have Kenmore frostless 25 with an ice and water dispenser in the door. It does not makes ice, but the water dispenser works fine. I could hear the ice maker switch bar moves up and down in the ice...
Most times it's the water control valve on the rear of refrigerator and near the floor. And you can test the ice maker by filling with water. Let it freeze and if it dumps the ice and does not refill then the water control valve. If the water freezes and nothing happens the the ice maker is the problem. If you had your model number I could tell you part numbers. Anyway try that and let me know your findings. Kenmore uses a model number like 312.54689 for example found on front near floor and behind the fresh food section door. Let me know, Thanks Sea Breeze
Aug 20, 2009 | Kenmore Refrigerators
Whirlpool refrigerator ice dispenser no longer workds
HI, the Ice maker control module will need to be replaced in your unit asap if possible. this module controls and initiates the actions when the lever is depressed.
Jun 05, 2009 | Whirlpool GS6SHAXLS Side by Side...
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
The ice maker and water dispenser does not work. There is no power to the exterior dispensing unit on the refrigerator.
I'm assuming you are saying there is no ice and water being dispensed, but that the ice maker is producing ice.
Actual ice maker operation is independent of the fountain which is for dispensing only.
The power is checked at the fountain board on wires Red/Black and White. The door must be closed when doing this check as power goes through the door switch. If no power is present, check the same wires at the connector under the upper door hinge cover.
The next check would be Red/Black to Blue while depressing the actuator pad button.
Outputs off the board are Pink to auger motor, Black to fountain water valve, other Black to fountain light, Violet to cube solenoid, the two brown wires go to the ice chute door solenoid.
The ice maker can be checked by removing the plastic cover up front. Check test points L to N for 120VAC. Short test points T and H to cycle the ice maker. Make sure it does not have ice or water in the mold already, or it will run over.
Of course last but not least, check water to the refrigerator. It is a dual valve and unlikely both solenoids could fail at the same time.
May 04, 2009 | Jenn-Air JCD2295HES Side by Side...
GS6SHEXMLoo side by side ice dispenser not working
On advice from the tech I removed acess door. It was covered by frozen moisture.
I removed the motor it was full of water. I verified 120 volts at plug to motor from control
by depressing the door switch and ice dispenser lever at same time. The motor ohms out
but because of amount of water removed from it I am going to replace it and see what happens.
Aug 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Ice and water dispenser
Has someone pressed the lock button on the front of the fridge just above the dispenser, next to the crushed & not crushed ice button, if so there is also an unlock button next to it.
Jan 04, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
99 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
