Question about HP PSC 2175 All-In-One InkJet Printer
My Hp F2179 brings up an error message that it does not have correct drivers. Have put in CD that came with the device but no help. Says wrong. I am angry cause this is the 2nd one I have bought and the same thing is happening. The scannner won't scan and the printer has a mind of it's own, prints when it wants to. Could be hours before it prints. The ink cartridge is also unbelievable in the small amount of printing one can do. About 60 pages and black gone. Help Do you know how many times I have tried to get help from Hp?????? I cannot count that high.
  • 277 Answers
SOURCE: "Incorrect black cartridge"error
This message appears also when the head is the right 1, but the connectors are dirty Try this solution ? fill a flat bowl with warm water (not too hot!!) For about 3 millimeters and put the ink head inside so only the connectors will be in the water for about a minute or two Wipe the whole head well, try cleaning the connectors a little and reassemble it Good luck
Posted on Feb 23, 2006
jackboy
  • 2985 Answers
SOURCE: HP 2210 xi printing problem - alignment
Try your question here http://www.techsupportforum.com/hardware-support/printer-support/49664-hp-psc-2210xi-problem.html
Posted on May 14, 2007
SOURCE: HP 3310 - problem with black ink supply
I heard you can get the 3310 to do a pump up the tubes cycle but i don't know how to make it do it. Pressing the ok and cancel buttons when you power up didn't work for my machine. Which has too died a inkless black death!
Posted on Oct 01, 2008
SOURCE: black ink does not print
i had the same problem. black stopped printing. i always used OFFICIAL HP cardridges, so this problem is not exclusive for refilled cardridges.
This solution (offered here) worked for me:
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and the turn it back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartiges in the printer so that it can reset.
I wanted to stress that you should make sure that:
1) you keep the the buttons down untill it shuts off;
2) on restart you get a notification of service;
3) to turn it off again after service before you turn it on for actual use.
Posted on Jan 11, 2009
  • 5 Answers
SOURCE: HP Photosmart C4580 wont scan
It seems that scanner glass is not glowing or may be bulb are not moving properly.
you can try these thigs:
1)Turn ON the printer unplug the powe cable from the back of the unit; wait for 30secs; replug the power cable.
2) Try this to check teh funtionality of hardware Load letter or A4, unused plain white paper into the input tray.
  1. Press and hold the Cancel (c01235250.gif ) and the Start Copy Color buttons at the same time.
  2. Release both buttons. The self-test page prints.
3) Now check if its copying or not?
It will work fine(if your printer scanner glass is fine)
You can also try scanning from computer(if installed)
the location of file would be=
c:\program files\hp\digital imaging\bin
here locate for file "hpqscnvw" hit it and try to scan
Best of luck
Posted on Jul 04, 2009
I do not have the driver to connect my HP Deskjet F2179 All-in-One
Good day Sir/Mam,
Here's the link F2179 all you have to do is choose your operationg system and download. after downloading install the software.
Jun 30, 2011 | Office Equipment & Supplies
CODE 10 ON TSST l632@ VISTA os
This is from Microsoft and is from their code explanation page.
Code 10 loadTOCNode(2, 'moreinformation'); If the device has a "FailReasonString" value in its hardware key, that string is displayed as the error message. The driver or enumerator places this registry string value there. If there is no "FailReasonString" in the hardware key, the following generic error message is displayed:
This device is either not present, not working properly, or does not have all the drivers installed. (Code 10)
Try upgrading the device drivers for this device.
Solution button: Update Driver
To resolve this error code, make sure the device is connected to the computer correctly. For example, make sure all cables are plugged in fully and that all adapter cards are properly seated. Follow the suggested solution button and update the device driver. It may be possible to remove the device and redetect it using the Add New Hardware wizard.
Jan 15, 2010 | HP Pavilion DV6700T Notebook
Error message
Uninstall the printer driver from Device Manager, then scan for hardware changes and install the printer driver when it detects the printer...All the best
Oct 02, 2009 | HP Deskjet 6940 InkJet Printer
Installing Windows 7 - CD/DVD driver missing message.
windows 7 will still be released next month. are you using the beta version?
Sep 12, 2009 | HP Compaq Presario V2000 Notebook
Nothing happens when i put in a dvd or a CD. Under the driver information, it says that i´am having a error code 10.
error code 10 = either the device is not present, is not working properly, or does not have all the drivers installed. this code may also have a manufacturer specific error message associated with it, depending on the device.
Solutions, check the device connections, and check and/or update the drivers.
Aug 12, 2009 | HP Pavilion dv6000z Notebook
Error message. Printer won't do anything
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9ofdfd7
Apr 22, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp officejet 7310 all-in-one software will not install
  1. Solution one: Make sure the hardware is functioning correctly(try to make a copy)
  2. Solution two: Restart both the All-in-One and the computer
    3. Solution three: Check if the correct scanning device is selected as default under HP Software
    4. Solution four: Download and run the Scan Diagnostic utility(FROM HP.COM)
    5. Solution five : Check that the Digital Imaging Monitor is running
    6. Solution five :Try scanning without HP Imaging software
    7.Solution six :Try scanning without HP Imaging software
Jan 26, 2009 | HP PSC 1410v All-in-One Printer
NOT ABLE TO INSTALL VGA DRIVER
i think you are chooing wrong driver, choose appropriate driver from list.
put your driver cd in cd rom, go to device manager, click on the display and update driver it will get automatically from cd
Oct 19, 2008 | AMD Athlon 64 4000+, 2.4 GHz...
XP (SP2) not recognising Maxell USB Flash Drive 2.0
whan i fix my usb in computer and try to open it ,the message appear "please insert a disk into drive d".
what is it? how could be solved this problem? help me
Mar 30, 2008 | Electronics - Others
HP PSC 2175 All-In-One InkJet Printer Logo
49 people viewed this question
Ben Johnson
