Question about Maytag Performa PAV3200
Grinding noise on washing machine
Just today the washing machine started making a grinding noise when it hit the spin cycle. Now it makes the noise for an entire cycle. It sounds like a metal on metal sort of grinding. its very loud!!
  • 1 more comment
  • redhouserhs1 Dec 16, 2008
    same problem you described, except the sound from our washer is
    Normal
    0
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
    mso-para-margin:0cm;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";}
    intermittent
    and the washer is throwing the drive belt off.
  • lpreed71 Jan 03, 2009
    I am having the same problem with the grinding noise throughout the cycle. Did you solve your problem?
  • Anonymous Feb 27, 2009
    ahh what is that! PLEASE
SolutionGuy
  • 331 Answers
SOURCE: Loud noise when spinning
I agree with Gittos on the bearing assessment. This considered part of the drive system. If it's less than 5 years old, your next move is to contact Sears and claim a warranty repair on the tranny (it has a 5 year warranty on it). If it's more than 5? Well, honestly it wouldn't be worth the repair. You'd have spent more money on all the parts required than what the unit is worth (worth= what it would sell for in working condition on the market). Hope it's less than 5!
Posted on Aug 12, 2007
SOURCE: MAYTAG WASHING MACHINE
The rubber smell is the belt from the motor to the tub. The grinding sound is/was the tension pulley that keeps the belt tight. The bearing on the pulley probably went out and now the belt is burning because of the friction of sliding around the pulley. The belt and the pulley need to be replaced. If you have the room, turn off and disconnect the hoses. Unplug the electrical cord from the wall outlet. Remove the drain hose and any water in the tub. Carefully tip the washer over backwards, DO DROP IT!!! Now you should be able to see the motor, tub, tension pulley, and belt. With a basic 3/8' drive socket set, probably metric, and a couple of screw drivers you should be able to remove the belt and the pulley. Take the belt, pulley, and model numbers to an applicance parts store and buy replacements.
I only suggest this because I hate paying labor. If you are not machanically inclined then you are going to have to pay the labor.
Good Luck
Posted on Dec 19, 2007
  • 79 Answers
SOURCE: grinding noise
The Neptune bearings are an interesting breed... Maytag wants you to replace the whole outer tub which includes the bearings installed for $180 or so. You can replace the bearings yourself. See www.tonytool.com to see how it is done. The tool costs $379 or so... but it is designed for the service tech. not the d.i.y.er. But watching the video can give you an idea of how to do it yourself. The bearings were available on www.neptunewaxmotor.com for about $35.00. You will also need the Maytag seal kit 12002022 to complete the job whether you decide to replace bearings or the outer tub.
Posted on Jan 05, 2008
IrishDruid
  • 2712 Answers
SOURCE: Grinding noise from hell - no spin, no agitation (except my own!).
Please see the following link for all possible troubleshooting tips:
http://www.repairclinic.com/0088_11_1.asp#Level1_3
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 04, 2008
SOURCE: Grinding Noise when Washer Attempts to Spin
It is probably the same problem because it is trying to drain during the spin cycle. My machine sounded as though a chain wis clanking, the solution was removing a coin caught in the drain pump. Access the pump from the bottom of the machine. 4 screws hold the mounting bracket on undo those, the electrical connection and two hose to the pump. Undo three screws holding impeller to motor and coin can fall out. Examine for damage if it is not too tore up, put back together. Keep in mind that when you unclamp the hoses that water will come out.
Posted on Feb 13, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
What is causing my Kenmore top washer to make a grinding noise before the rinse cycle?
Have you replaced the clutch or spin tube? There is a brake actuator that comes with the clutch kit and if this is broken it can make a very loud grinding or clacking sound.
Jun 25, 2014 | Kenmore Washing Machines
Grinding noise before spin cycle
Good Morning John,
I see that you are hearing a grinding noise before the spin cycle in your Frigidaire washer, model# GLET1031CS0. A certain amount of "grinding" or gear sounds are normal in a heavy-duty washer. If you notice that the grinding sound appears to be getting louder, I suggest contacting either the manufacturer or your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Mar 16, 2014 | Frigidaire Washing Machines
LG direct drive washer makes a grinding noise with power and moving it by hand. how much to repair?
sounds like the bearings have worn out. probably expensive, requires the machine to be dismantled almost completely.
Nov 12, 2013 | LG Washing Machines
Whirlpool cabrio makes grinding noise on the wash cycle
On this style washer the motor has a belt and pully type clutch under the machine called a splutch.There has been an ongoing problem with the nut coming loose and dropping the belt/pully down which in turn hits the safety shield.
Mar 31, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Have a proforma toploader and is making a grinding noise in both wash and spin cycle. it is still draining and doing everything just making the noise.
We have a proforma toploader washing machine and when using the machine in makes a very loud grinding noise during the spin and wash cycle. On occassion it also does not spin the clothing out properly, however the machine is still usable.
Dec 29, 2010 | Maytag Performa PAV3200
Whirlpool WF665/1 clunking/grinding
Could be worn drum bearings.
Jun 04, 2010 | Washing Machines
Washer loud grinding noise spin stop
if its brand new it shouldnt be making a loud grinding noise id get it checked make sure they removed all shipping bolts
May 17, 2009 | Maytag Washing Machines
Cheers!
IrishDruid
Oct 04, 2008 | Washing Machines
Washing Machines Logo
1,007 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
