Question about RCA P52926 52" Rear Projection Television
No picture, no sound
Got a rca 52 hdtv projection monitor, model #d52w26. got it from a friend cause it wasnt working. he said it was working one day and quit the next day when he turned it on, said it made a pop and the screen went black. when i turn it on the srceen is black and a red,green,blue lines appear at the top of the screen.can you recomend a solution?
    Problem Solver:
  • 31 Answers
The power supply for the convergence circuit is not working, check for open resistor on the primary
Posted on Dec 02, 2008
I need to find a bulb for a D52W26
your model doesnt have a bulb like the DLP projection. Instead you have three CRTs ( picture tubes) one red, one green and one blue. If you respond to this same post with your symptoms I can assist with diagnosis.
Oct 25, 2011 | RCA HD52W56 52" Rear Projection HDTV
HDTV monitor 52 in. Model #: D52W26 Serial #: G072CU07E colors are separated, warped screen and cannot find auto convergence
Very easy repair. The ITC222 and ITC222A convergence option missing repair kit available from will solve that issue. Its listed under the RCA repair kits and has the parts and the CD with repir instructions.
Mar 31, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I own a 52" d52w26 hdtv monitor last couple of
I see two possiblites your flyback tranformer has failed and with it your horzital output transitor has shorted. most technicians can replace these. IS the spark in the front or back of tv. if it is in the front this is a tube. as a tech i would first identify what compnents are sparking. also this could be a capacitor shorting cause a burnt curcit board
Nov 02, 2010 | RCA Televison & Video
Rca d52w26 hdtv, work's fine for fifteen to twenty minutes. then screen fades away go's blank, the sound and channel's still work. help!
Replace the deflection board. You can get a replacement deflection board from which also contains instructions on how to remove and replace the board.
Apr 16, 2010 | RCA R52WM24 52" HDTV Projection Television
RCA D52W26- 52 " rear projectio- 3d
try to inspect the convergerce power supply and the convergence output module for cold solder joints around the mos fets...i had seen many of them on the same condition.
Jan 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W26- 52 " rear projectio- 3d colors,,,is convergence issue
um i think your gona meet your maker,,,your solutions are not being tolerated.. the new maker, he can and will make you learn what manners are!!
My rca 52 in projection t.v has problems powering up
Push and hold power button. If it cycles and blinks on/off in 3s or 9 times, it is a power problem. Replace the deflection board. Cost about 250.00
Jan 04, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA D52W26 model tv blanks out, but still has sound
First. Resolder fly back terminals. MAybe liquid coolant projection on the board or yokes, ( some times picture tubes is bad . resolder deflection board.
Apr 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Divergence not working on RCA HDTV monitor 52" D52W26
sound like the common fl231 fuse problem. consult the fl231 problem article under the tips and tricks section. this is probaly the simplest most inpensive repair on this set
Jan 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52926 52" Rear Projection Television Logo
167 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
