Question about Karcher 1750 psi Electric Pressure Washer
Losing pressure somewhere
Hi could someone tell me how to solve that nightmare of mine,I`ve got a Karcher 1700 psi, was going hum hum every time I release the trigger but it sound like the pressure is bit low as well,I replaced head.suction valve,and check all the the parts internaland the only part that i didn`t replace is the detegent valve, to me it look perfect ok and the machine is only about 13 months old, never store it with pressure in the unit so what you reckon it could be Please advice
Bryan
PS. Not even a trace of water leaking from the machine
Hi, I work in the italian factory of Karcher. In my opinion the problem is caused by the breaking of the collector. This is a black component of plastic where is inserted the detergent suction valve and the safety valve. To replace this component you have to go in a repair center Karcher.
Posted on Dec 07, 2008
  • 169 Answers
You need to check the setting of the unloader. If you've replaced it with a new one it probably didn't come preadjusted to 1700 psi.
Posted on Nov 29, 2008
Why does my karcher 1750G have no pressure
can't solve this but can you solve why mine leaks oil all the time?
Jun 05, 2014 | Honda Black Max 2600 PSI Pressure Washer
Karcher K4
think it must be faulty power
Jun 10, 2008 | Karcher 2500 PSI Pressure Washer
Oil type in Karcher gearbox
If you are talking about the water-pump gear box only, the correct oil type is 30W NON-Detergent oil. "ONLY"
Mar 15, 2014 | Karcher Garden
1750 psi Electric Pressure Washer: My pressure washer is losing pressure and is pulsa...
I have d'same problem before. replace the head component with the 3 little cylinders,springs etc.. its a 1 piece part.
May 06, 2010 | Karcher 1750 psi Electric Pressure Washer
New nozzle, plenty of water, but no pressure.
It is warrantied for 1 or 2 years. Low pressure could be due to the un-loader valve needing grease. If it is leaking it will not work properly. If it is stored somewhere cold during winter months the small parts inside will crack.
Sep 18, 2009 | Karcher 2500 PSI Pressure Washer
Leaking inside the casing. No pressure from the
sounds like the bladder or seals are shot they make a kit for this
Aug 22, 2009 | Karcher Garden
KARCHER HDS 1000 de
Hi Jim,i have the same unit to,can you tell me are you connecting to mains water via the small black header tank at the back next to the boiler or is it connected straight to the pump head inlet?
Theres more than one reason i'll just start with this one 1st.
chris
Aug 08, 2008 | Karcher 2500 PSI Pressure Washer
I own a karcher water blaster 449M and needs an expert to solve the pomblem It does not bring out the presure required to the right job and makes a noise as well when you start it can someone please let...
sounds as if you have a pump problem. your best bet is to go online to maker or a dealer near you for service help.you may wind up having to replace pump.
Jun 20, 2008 | Karcher 2500 PSI Pressure Washer
Pressure washer wont run unless choke is on
I have a Karcher pressure washer w/ a 5hp Honda engine. It only will run while the choke is pulled out and only runs at about half the rpm's. When the choke is pushed in.. it coughs, sputters and shuts off. Can you tell me how to fix this....
May 12, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 1750 psi Electric Pressure Washer Logo
806 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
