Question about Kenmore 73902 / 73904 / 7390 / 673909 Top Freezer Refrigerator
Compressor help I have a Kenmore refrigerator, When you plug it in the compressor will come on for a few secounds and then kick off. Is my compressor bad?
  • 237 Answers
If the compressor is real hot, caused by lack of cooling air and the thermal overload is what's tripping try letting it sit for several hours to cool and try again (clean the front lower coils for proper air flow). If that's not it then you likely have a "start device" failure. The kit comes with the overload and starter. Usually this is the problem BUT if you have a "Tecumseh" brand compressor you're toast. Take the back panel off the fridge and look at the compressor, if you have a little sticker on it with an blue indian head... the compressor is locked up (and even a new one is just as junk as this one). But if you have another brand the little white box on the left could be the problem. Unplug the fridge, unplug the little box (starter) and shake it to see if you hear any rattling or if debris falls out... a sure sign the device is bad.
Posted on Dec 30, 2006
My refrigerator keep tring to kick on but acts like it can't. I unplug it and wait a few seconds then plug it back in and it works fine.
Hi!
That is probably the compressor relay
The relay is on the compressor and needs replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 09, 2011 | Kenmore Side by Side Refrigerator
Amana BX21VW cool but not cold, compressor not working
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Sep 13, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Kenmore Coldspot compressor kicking on and off
It sounds like you may have toasted one of the starting componets. Either the start relay or the start capacitor has probably failed, causing the compressor to try to start, and then kick off on overload. Hope this helps
Sep 10, 2009 | Kenmore 50522 / 50524 Side by Side...
Refrigerate not working freezer not working
sounds like the relay is bad replace the relay this should take care of the problem it is located on the compressor
Jul 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore AC Model 25370156000 keeps shutting off and on by itself
If you have just installed this unit in your window for the season, you may want to wait a day or so, for everything in the unit to settle, and try again. You make have shaken it up a bit too much. If not.....sounds to me like it is kicking out on high head pressure. This happens when refrigerant gets too low, or there is air in the refrigerant system. There is nothing you can do to solve this problem, except take it to a repair shop. If I am correct what happens is you turn the unit on, and the fan and compressor start simultaneously, then after a few seconds (maybe up to a minute) the compressor kicks off, and the air gets warm, then the compressor kicks on for a few seconds, and we repeat. This is actually a safety mechanism for the compressor motor so it does not run without refrigerant. (That would destroy the pump.)
Jun 04, 2009 | Kenmore 76129 Air Conditioner
Not cooling, compressor kicks in for 3 seconds then back out
No the PTC relay on the compressor is bad. Need to replace it.
First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Apr 04, 2009 | Kenmore 53642 / 53644 Side by Side...
Fridge and freezer not cooling
Compressor is probably out on thermal cutoff from trying to restart continuously. You can get what they call a hard start kit at a parts house. Its a plug and go unit.
Jan 17, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore side by side runs then stops
When you say runs awhile, how long? What is shutting off all power or just compressor?
Nov 04, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore compressor cycles and does not cool
It sounds like you have a stuck compressor or bad start capacitor.
Stargazer
Mar 16, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore 73902 / 73904 / 7390 / 673909 Top Freezer Refrigerator Logo
135 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
