Question about Roper RGX4634KQ Gas Dryer
How do i access the gas coils on my roper dryer?
How to access gas coils on roper dryer
    Genius:
  • 1,198 Answers
Http://www.pcappliancerepair.com/model-display.php This is a good site for parts and help. You can see the screws #2 holding the front on. Release the spring clips #20 with a putty knife in the gap on the front.
Posted on May 09, 2009
Gas dryer not heating checked thermo fuse ignighter both good
Than its going to be in your heat coil/ valves and your flame sensor. The flame sensor is a rectangle box on the flame tube. Your heater coils are on the gas valve they are two round silinoids one with two pins to it and one wwith three. Follow the gas line to the gas valve on the gas valve you will see two quick connects that run to it. There is one screw and the plate cover will come off to give you access to the heater coils.
If you have anymore question please comment me back
Jul 31, 2011 | Roper RGX4634KQ Gas Dryer
Roper RGX5634KQ2 Dryer will fire initially, and heat up. It will stay fired up for around 1-2 minutes, and go out. After another couple minutes, the igniter fires, but there is no flame. This continues...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Could be a coil...but I have learned that it usually is the ignitor...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 02, 2010 | Roper RGX4634KQ Gas Dryer
My dryer spins on all cycles-------but no heat. Could it be pilot light?
Good day,
It has no pilot light. The first step is to remove the back cover and check the thermal fuses and limit thermostats. The most common item to fail is here.
73a3a07.jpg You will need an ohm meter to test it. It should read zero ohms.
There are many more, any of which could cause the problem. Look here.
3e706b5.jpg Ignore the ones going to the right canister. That is for electric dryers.
If all check O.K. then you will need to access the front of the dryer.
Usually either the igniter or the gas valve coils. The igniter should read under 35 ohms, the dual black coils on the gas valve cannot be tested.
Here is tutorial on accessing the front. Nothing to do with your issue, just allows you to see how to access these items on the bottom left.
http://www.youtube.com/watch?v=9dd1Ac4_pXY&feature=PlayList&p=2489A2388180145E&playnext=1&playnext_from=PL&index=14
Jun 19, 2010 | Roper RGS7646KQ Gas Dryer
ROPER GAS DRYER IGNITER LIGHTS THE GAS BUT GOES OUT AFTER 30 SECONDS
The gas valve coils are weak and dropping out. Replace the gas valve coils.
Jun 17, 2010 | Roper RGX4634KQ Gas Dryer
I have a roper dryer it spins but it does not get hot what should i do?
if it is electric you need to check the element to see if you have a break in the coil. if there is no break check the thermostats on the element housing. if it is a gas dryer you will need to check the igniter and the coils. hope this helps.
Oct 15, 2009 | Roper REX4634KQ Electric Dryer
Cant get to the gas coils on roperrgs7646kq3 --help!!
Thats scary Gas coils? There is a burner assy on the bobbom remove bottom panel. I would not recommend doing anything unless you are certain you know what you are doing.
Nov 24, 2008 | Roper RGX4634KQ Gas Dryer
Roper gas dryer mdl RGS7646KQ2
hi keith. yes replace the 2 coils on the gas valve. it will solve the problem. thanks the appliance doc.
Oct 16, 2008 | Roper RGX4634KQ Gas Dryer
Roper RGX4634KQ Gas Dryer Logo
457 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
