Question about Hitachi Televison & Video
When I turn on my tv it works for about a min. picture sound everything then the blue power light starts to flash & I loose the picture. When I shut the tv off the red lamp light stays on. Hitachi ultravision digital 50".
The guys told me the solution for free they even emailed me a new user manual.
Posted on Nov 24, 2008
TV wont turn on sometimes. push the on button, light turns from red to blue but no display or sound. If I disconnect the power cord for 15-20 min and plug it back in to the tv it will turn on and stay
My Samsung started doing that and it got worst and worst. Searched the web and find answer. It was the high voltage circuit. All TVs now are like computer and it check for 390 to 400 volts and if it is below, the TV will not turn on. Good thing the Samsung has only one capacitor showing the high voltage circuit. Measure the voltage was 381 volts. The capacitor was rated at 100 uf at 450 volts. From some old TV and power supply, got two capacitors rated 150 uf and 220 uf both at 400 volts. Had to connect them in parallel and took out the old capacitor. Now, my TV works fine.
Nov 03, 2017 | LG 42LG30 42 in. LCD HDTV
Blue light remains lit but lose picture. no other indicator lights flash. if i unplug the tv it will restart but lose picture again after half hour
I have a toshiba 50hm67 tv and with mine the blue light would come on and I would hear sound first and then the picture would finally come on... this happend for about a month.... next the yellow and blue light would come on but the pic still wouldn't come on until it clicked off and on by itself for about 10 min this went on for about a week. All of a sudden last night the red lights by the power light started blinking. No tv now and when the tv shut off it said lamp not working.
Sep 17, 2010 | Toshiba 56HM66 56" Projection HDTV
The power comes on and then turns off and the front green power light blinks.
There is a small IC in the power supply section,
not the IC regulator that's the problem.
Jan 06, 2010 | Philips 32PT6441/37 32" TV
Toshiba 46in DLP No Picture, but good sound.
Hi my name is Eric,
I hope I can help you with your issue ,
Sounds like a bad lamp assembly , search for one online by model# for between $100-$200
easy to install yourself
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Sep 09, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Why would our proscan big screen just turn off and then not turn back on. Everything else has power. And also when we tried to unpluge the power cord on the back it sparked. Please help. --- model number...
Jul 16, 2009 | Proscan 19LA25Q 19 in. LCD Television
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
A repair question for the RCA M50WH74S
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Aug 18, 2008 | RCA HD52W56 52" Rear Projection HDTV
New Blue CRT installed now TV won't stay on
sounds like the HV lead isnt sealed properly either at the CRT or the Splitter I would have him come back and recheck his connections
Jun 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Plugged in, worked, turn on later, did not work
First thing i would do would be to check convergance amp ics
Jan 01, 2008 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
221 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
