PAPER WENT INTO PRINTER CROOKED. NOW PRINTER IS NOT FUNCTIONING AND LIGHTS ARE FLASHING
  • 837 Answers
It would help if you told us what make/model of printer.
Posted on Nov 24, 2008
My Epson 800 prints crooked. Everything leans to the right. Resetting the paper helps, but I have yet to get it straight. Any suggestions??
It appears that the paper feed rollers is not functioning properly. Check it with Epson if your printer is still underwarranty, or send your printer to the nearest Service Center for repair.
Oct 30, 2011 | Epson Artisan 800 All-In-One InkJet...
Error 3 indicated - what is it and how do I fix it
E3 means that there is a paper jam. If you are getting the E3 error and there is not an actual paper jam you may need to do is simulate a paper jam. Try inserting paper crooked to cause a jam so that when it starts trying to feed the paper through it gets jammed. Then lift the cover up and take the paper out. You'll then get a bunch of the lights flashing. Turn the printer off and then back on and you should be good to go.
Mar 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
The paper keeps going in crooked then jamming
Toner complaint may also cause paper jams. It can be solved only by replacing it. When you switch on the loop back plug in, two flash lights appear; then it indicates paper jam. The oil spillage in toner can cause this problem. If the toner cartridge is not functioning properly, the same problem would be the result. The diodes or transistors in the fuser unit of the Multi Function Printer may get damaged and this can lead to fuser complaints. To solve this problem, you should replace it.
Jan 10, 2011 | Canon PIXMA MP470 All-in-One Printer
Feeder problems with Pixma 9500
By having a certified technician do a cleaning on the feed rollers this should fix the problem.
Jun 04, 2010 | Canon PIXMA Pro 9500 InkJet Photo Printer
R200 both red lights flashing
if both red lights are flashing alternately your printer has been locked this is due to full waste ink pads. you need to have them replaced either at your local service centre or do it yourself then you need a scss reset utility to reset your printer you can get a free one of these on the net
If your lights are flashing continuously look to see if you have any outstanding documents in your print queue and delete them
Mar 30, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I865 flashing 3 times
That's a "paper jam" error that can be fixed by removing all paper and pressing the resume/cancel button. Then replace the paper in the feed chute.
The printer can straighten out a crooked feed to a very limited degree. The photo feeder attachment can interfere with a really full 8x11 feed. The i860 is very susceptible to overfilling the 8 1/2 x11 feeder without notice until you try to print. I usually remove the photo feeder until I need to print photos, and keep the regular paper feeder no more than 3/4 full. I pull out the regular paper when printing photos.
Feb 24, 2009 | Canon i860 InkJet Photo Printer
Won't print, all lights flashing
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 26, 2009 | IBM Infoprint 1222 Laser Printer
Alarm light flashing
Is the front cover on the printer(ifs its not the alarm light will keep flashing as there is a sensor that will trigger the alarm if the cover is not on or not on properly.Hope this helps?
Dezzi
Jul 16, 2008 | OKI MICROLINE ML-395 Matrix Printer
Ink and paper led lights flashing
you really needed to download that resetting ink counter, to refresh the counter back to zero... printing might have reach 5000 copies, it has really a counter thing... go to the link below and get it, instructions are there too.
http://www.ssclg.com/epsone.shtml
Oct 24, 2007 | Epson Stylus Photo R200 InkJet Printer
k24674
jasbo
jasbo
