Question about Roper RGX4634KQ Gas Dryer
Cant get to the gas coils on roperrgs7646kq3 --help!!
How do i access the gas coils on my dryer? there is no access point that i can see
thanks Pete
  • 95 Answers
Thats scary Gas coils? There is a burner assy on the bobbom remove bottom panel. I would not recommend doing anything unless you are certain you know what you are doing.
Posted on Dec 30, 2008
Will start, clothes will tumble but will not heat up to dry the clothes
Run it with the vent off if you feel some heat for the first minute and the airflow is strong you best bet is to change the valve coils.The vent is not a part in the dryer the vent is was connects to the back of the dryer pull the vent off and run the dryer to test.
The coils are on the top of the gas valve.
Gas dryer with no heat: The parts that I have pointed out with the arrows are the parts that you will need to check with an ohm meter if the dryer is not heating. First check and see if you have 110 volts coming to the gas valve at this type of a connector. If you have voltage, then unplug the dryer and check the parts I have pointed to. Some dryers have 3 coils instead of the 2 shown here. If you do not have voltage coming to the burner, then you will need to check the timer contacts that feed the gas burner, hi limit thermostat, operating thermostats, the safety switch on the motor, and any other point that you can see on your wiring diagram picture that feeds voltage to the burner. The coils on the gas valve are very bad for working once or twice and then quitting. If you find a open circuit on one of the gas coils, replace them all = less problems later on. If the glow coil does not work ( get red ), check it with a ohm meter for continuity. The next thing to check if the glow coil does not come on would be the radiant sensor. Inspect the igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter wire plug when dryer should be calling for heat. Sometimes the ( older style ) igniter is separate from the holder and the holder can no longer hold the igniter tight enough and the two parts burn/arcwhere they touch each other = new igniter and holder ( some manufactures have new kits to replace these older style parts ).
Does the igniter get red and stay red, or does it get red, you hear a click and it goes off, then a minute later its gets red again?....if so you possibly have a bad set of coil valves. If the igniter gets red and stays red constantly then its the flame switch that is bad and maybe welded closed.
Check out, this possibilities.This should help.Thanks.Helpmech.
Mar 25, 2011 | Kenmore 93142 Gas Dryer
Everything works except the dryer won't heat up. Pleaqse help. thank you. Pete e-mail esquiro@alaska.com
Here are 2 videos to help you troubleshoot the dryer. One of the videos is for a gas dryer, and the other is for a electric dryer. I didn't see which one you have.
Jan 06, 2011 | Dryers
Our dryer is turning but no heat what is the first to go on dryers model#pyg2300aww thanks
first,check and see if the ignitor glows,if not it probably is burned out,then if it glows,but wont start check the flame sensor eye for dirt so it cant sense the flame,if this isnt the problem,then check the gas valve coils on the gas valve,they get weak and cant keep the valve open to supply gas to the dryer
Mar 12, 2010 | Maytag PYG2300A Gas Dryer
Coil replacement
I'm not an expert but assuming you ordered the coils for your dryer your dryer must have them. I just finshed repairing my kenmore gas dryer after about 10 minutes the gas would shut off. This is becasue the coils that are on top of the gas line before the ignigter were defective. The coils control the gas valve and when my dryer got hot the coil being defective would close the valve. There are 2 coils a 2 prong and a 3 prong. Remove the front panel to gain access to the bottom of the dryer from there you will see your coils about as round as a quarter and 10 or so high. unscrew the screws holding down the retainer and undue the electrical clip. reverse for the install. good luck!
Dec 13, 2009 | Kenmore 72802 Gas Dryer
Gas dryer spins but does not get hot. checked door, connections and lint screen. Have replaced ignitor on other dryers, where do you access on this Whirlpool Ultimate Care II?? Thanks in...
There are other things to check also... See this picture.
http://www.fixya.com/uploads/images/7152136.jpg
The burner is located in the bottom of the unit to the front but inserted inside the intake for the blower duct. The parts list is here. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=504275&diagram_id=130018#d130018
You can also find them here under this model number GGQ8831LL0 http://www.repairclinic.com/Appliance-Parts?s=t-GGQ8831LL0-%3d%3d Hope this was helpful.
Nov 04, 2009 | Whirlpool GGQ8831L Gas Dryer
GE gas dryer will work intermittenly
coils will get warm then stop working. change them all 3....have seen this many times!
Aug 07, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
How do i get access to gas valve coils on maytag neptune series dryer
Here is a link of an exploded view of a dryer hopefully this can help you! have a good day! Ps don't forget to give me a rating if this was helpful!!! thank you
http://www.repairclinic.com/0100_17.asp
May 10, 2009 | Dryers
I need access to gas valve in my Maytag mdg5500aww dryer
When I posted the question, I had not removed the front of the dryer. I thought the gas burner etc. had to be accessed from the back. As soon as I removed the front of the dryer I realized it was all up front and accessable. Conversion was straight forward from that point.
Jan 16, 2009 | Maytag Neptune MDG5500AW Gas Dryer
How do i access the gas coils on my roper dryer?
http://www.pcappliancerepair.com/model-display.php This is a good site for parts and help. You can see the screws #2 holding the front on. Release the spring clips #20 with a putty knife in the gap on the front.
Nov 24, 2008 | Roper RGX4634KQ Gas Dryer
The burner in the dryer will not stay on.
Most common cause is poor airflow. Make sure your ductwork is clear, and that you have good strong airflow at the exhaust point outside.
If that doesn't help, it may be the gas coils that need replaced....not a terribly expensive part, you can usually get the pair of coils together.
Jan 16, 2008 | Whirlpool GGQ8831L Gas Dryer
Roper RGX4634KQ Gas Dryer Logo
52 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
