Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Internet Troubles When I try to connect to the internet with any network other then NETGEAR it says that my connection is 'local only' (as opposed to 'local and internet'). What I found is that that means I cannot go online whatsoever. How do I make my connection always 'local and internet'? I'm using a Windows Vista Premium Thanks, Phil, PS-I think NETGEAR works because I set it's zone to public instead of home.
  • Ricky Ostrom
    Ricky Ostrom May 11, 2010
    What other network connection are you speaking of; USB. Firewire, Wireless, etc.
    Other than your Netgear Network Adapter or Router?
    Note: There is a known bug in Windows Vista SP1 where it says you are not connected, when you are able to browse. It affects getting updates and network applications. This affects both wired and wireless connections.
    Sergeant:
    Champion:
  • 274 Answers
I found this link that might help you...
Vista Connection Problems
Posted on Nov 24, 2008
What does the LAN do on the modem
There are two halves to a router. The internet (WAN) side a local network (LAN) side.
The term WAN means Wide Area Network and generally refers to the internet.
The term LAN means Local Area Network. That would be for the computers that are in your office or home.
The LAN connects your computer to your printers or to other computers.
I hope that answers your question!
Jul 02, 2014 | NetGear WNDR3300 - RangeMax Dual Band...
How do i secure wireless net work its shows local only
Hi if it shows local only means you not connected to the internet and only you can access your network make sure you apply wireless password to make your network secure check the WAN cable which directly connect to your NetGear DG834G Router you can disconnect that directly connected to your laptop and see if you can access the internet should you need any other help please contact me on my weblog http://computernetworksupportindubai.com/
Jul 22, 2011 | NetGear DG834G Router
Intel 82562v-2 network adapter wont connect to the internet, have searched online and this is a known problem but i cant find a fix. my system is an inspiron 530s and router is a netgear wgr614 but im on...
ok this is a really pretty nice question..
I guess you using windows 7!!
- Click on Start / Control Panel
- Go to Network and Internet then Network and Sharing Center
- On Network and Sharing Center on your Right where its written Task, you will find Change Network adapters. click on it
- Right Click on Local Area Connection / Properties
- In General Menu / look for Internet Protocol (IPV4)
- Double Click on IPV4/ choose use the following IP
Ip adresse: 192.168.0.15
subnet mask: 255.255.255.0
default gateway: 192.168.0.1
Use the following DNS server:
DNS1: LEAVE IT BLANK
DNS2: LEAVE IT BLANK
Press apply and ok
Close everything, your local area connection should show you: "Local Area Network Connected"
Disable your Antivirus and Firewall ( for test ) and try accessing internet it should work
Configure your browser also
IE : Tools / Internet Options / Connections / Lan Settings / Tick "Automatically detect settings"
Ok and try accessing internet.
Firefox: Tools/ Options / Advance Menu / Network / Settings / Tick " Auto Detect Settings for this Network, apply ok.Close firefox and start again it should work.
May 13, 2011 | Computers & Internet
The CD is not available for installation is it necessary? I have all of the cable if the Yellow cable connects to the cable router what does the white cable on the wireless router connect to. Thank...
If the cables supplied have RJ45 connectors then they are used for connecting and configuring the wireless settings in Netgear router and to connect the Netgear to the DSL modem foe Internet access.
Most likely the color of the cables is not important.
To configure the wireless settings, connect a cable from one of the LAN ports (not the WAN/Internet port) to the LAN port on your computer. You may remove this cable after configuring the wireless settings if you want to connect to the Netgear by wireless only. You need to connect other computers to the Netgear's LAN port with a cable if they do not have wireless cards installed in these computers.
The other LAN cable is used to connect the Netgear WAN/Internet port to the DSL modem so you computers can connect to the Internet via the Netgear router.
Follow these instructions to configure the Netgear router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Feb 23, 2011 | NetGear WGT624 Wireless Router
My Atheros AR5007 will only complete a "Local Connection, No Internet Connection" to a NetGear N600 Dual Band Router when Security Options (WPA2-PSK (AES)...ect) are selected on the Wireless...
Since the connection works without the encryption settings, it is NOT a driver issue. It sounds like a missing wireless network security setup problem. So assuming Windows (Mac OSX is similiar):
  1. Connect a laptop/PC to the NetGear via ethernet. It saves on some aggravations later.
  2. Connect to the NetGear and restore the security settings, and remember your keyword.
  3. On your computer, open the list of Wireless Networks (usually Start->Control Panel->Network(ing)->Wireless Networks). The menu sequence might differ slightly, depending on which Windows you're running.
  4. Find and click on "Manage Wireless Networks" (or words to that effect)
  5. Right click on your wireless network's name to get the drop down menu, and select "Properties"
  6. Find a button or tab related to "Security"
  7. Under Security Type, select WPA2-PSK (or Personal)
  8. Under Encryption Type, select "AES"
  9. Under Password (or Security Key), type in your router's WiFi security key word. You may have to log back into the NetGear and find the keyword (yours) or the alternate (gibberish) form.
  10. Save the settings
  11. If you're connected to that wireless network, then disconnect
  12. Try connecting to the wireless network again. It should work this time.
Feb 23, 2011 | D-Link Computers & Internet
I cannot connect to the internet. I am using a netgear rooter. Although I am connected to the router I cant get through to the internet
moz-screenshot.png1) Go to Start and click on Control Panel.
2) Control Panel window will appear. Double click on Network Connections.
3) Network Connections window will appear. Right click correct Local Area Connection by identifying correct network card and click Properties.
4) Select Internet Protocol (TCP/IP). Click on Properties.
5) Then try assigning the following values (default) and Select OK.
Nov 18, 2010 | Acer (D10709-002) (D10709002) 802.11g/b...
I have upgraded to windows 7 and my internet is slow. I have the instal disc but when i try to re-instal the router it says that The network adapter in this computer is not responding. You must use the...
Are you trying to install the router ?
Check the status of the network connection.
If the local area connection is disabled then enable it.
Click start . go to control panel. go to network and internet. go to network and sharing center. You will see view network connection. Under that check for the Local area connection.
You can set up the router manually also without the CD.
Click Here for more info about router set up.
Nov 29, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Where is the ip adress
If you want your WAN IP address(Internet IP):
www.ipchicken.com
If you want your LAN IP address:
Go to Start then Run
Type in ipconfig
There is your LAN IP, usually starts with 192.168.x.x
Oct 06, 2009 | NetGear RangeMax WPN824 Router
When starting internet explorer ''no connection'' problem
can you restart the netgear? also see if you can connect ok with a cable. After all these, reboot your PC and check
Jul 08, 2009 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
INTERNET TROUBLES WITH ATHEROS AR5005G WIRELESS NETWORK ADAPTER
you need to reinstall ALL drivers for all devices, clean. formatting is what causes that..this will take some time..but you can get through it.
check your computers warranty here 4 FREE
Mar 16, 2008 | HP Pavilion dv6000z Notebook
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
54 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
