Question about Intel Desktop Board D850EMV2 Motherboard
Pc turns on when i plug it in but won t boot and won t turn off
Was a working PC until Windows XP Perpetual boot and would not turn off, so I unpluged it. Now when I plug it in, it comes on immediatly without power button. I removed all cards (AGP, SCSI, Sound, & Memory) with no change.
  • 837 Answers
Reset the CMOS to defaults. Since it is not actually booting properly you will have to jumper it. Hopefully you have the manual and you need to look at the layout and find what jumpers need to be shorted to reset
Posted on Nov 24, 2008
My eee pc netbook won't turn on I need help
1-remove the battery and put it again
2-turn it on from the power button
3-if it doesnt work press F1
Jan 27, 2013 | Computers & Internet
Asus x83v won't boot up
Unplug the machine, remove battery, leave the battery out, plug in the machine, try to boot normally. If the fails unplug, plug in, push the on/off button and IMMEDIATLY start tapping the F-11 REPEATEDLY. Enter restore/recovery section select a date before this problem started and restore. If that fails do a system recovery to factory settings. Or if you have a Windows Vista repair disk, Windows Vista Install disk that you can use to repair
Nov 12, 2012 | ASUS Computers & Internet
I try to recover factory my acer m3400,then said error recovery and no picture,what can i do
you must open you pc and unplug the hard drive data and power conector, turn it on until it boots because it option its only for software configuration not wardware, another tool you can use its hirens boots cd its a freeware...plug again the hard drive and wait until comes to windows if dont restart and press f8 for a boot safe..let me knows if it works
May 01, 2011 | Acer Aspire M3400 PC Desktop
Not booting to desktop just logging off
I'm sorry, there's not enough information here to respond to.
Is the laptop not booting up to Windows? or is it in a perpetual state of "logging off"? If it's the latter, you may need to do a hard shutdown... press and hold the power button until it shuts off.
Then unplug it, pull the battery out and press and hold the power button for 30 seconds, release and press again for 30 more seconds. This will remove any residual power inside the system.
Plug it back in and turn it on.
Did it help?
Sincerely,
Mark
Apr 01, 2011 | Compaq Evo N110 Notebook
Upon turning on my desktop, it froze on the blue "hp" screen with the f10, escape, etc. Options. I noticed the "num lock" light was not lit on my keyboard so I purchased another one to...
Your computer is not booting, and until it does so, the "num lock" light light will not come on.
Booting requires BIOS to run.
BIOS stands for Built In Operating System and it must successfully load and run before it can initialize the keyboard and recognize the hard drive where your windows program is stored.
A number of things can cause this, including something plugged into the computer that is bad, so first, turn off and unplug the computer from the wall outlet, then label and unplug everything from the back of the computer except the monitor and keyboard.
Plug it in and turn it on again. If it loads windows, plug in the items you unplugged, such as printer, scanner, mouse, and so forth, one at at time, and ensure all work properly.
If it does not boot, Unplug the computer from the wall, open the computer case, and ensure all the various plugs and boards are securely plugged into their sockets. Gently wiggle things to see if anything is loose or not locked down properly. Avoid static damage by placing one hand on the metal case while wiggling with the other hand. Try to only touch the edges of the various boards.
If it still does not load windows, you can try to reset BIOS. The HP website lists the following steps to do this. If you have another computer, this is the page to visit: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07110&tmp_track_link=ot_recdoc/c00007682/en_us/bph07110/loc:1&lc=en&dlc=en&cc=us&os=228&tool=softwareCategory&query=a121-n&product=1118241#N281
You can enter BIOS by entering F10 at the first screen. If it does not work when your computer if frozen, then repeatedly press F10 as the computer is powering up and stop when it enters the bios setup program.
Once you are in the setup program:
1.Press the F5 function key.
2. Select Yes or OK using the arrow keys .
3.Press the Enter key.
4. Press the F10 function key.
5.Select Yes or OK to save the defaults.
6.Press the Enter key again if necessary.
The computer will reboot. If it still does not work properly, you need to take it to a competent repair person.
Jan 06, 2011 | HP Pavilion a1210n (ED895AA) PC Desktop
I am using acer aspire 4315.but i can't install windows xp.how can i install windows xp 3
tHIS is the guide:
Turm on the laptop, open the cd drive and slot the cd of the windows xp 3 and then close it.
Turn off the pc by pressing and holding on the power button until the system turns off,
Then turn on the pc and allow it to start.
On start up booting, a screen will appear asking you to press any key to boot from cd, then press the enter key and allow set up to run.
follow the screen instruction and guide until installation finishes.
More guide, then mail me for more help, brightprofiles@yahoo.com
****UTILITY SOFTWARE GUIDE FOR FIXING PC ERRORS, SPEEDING UP PC, DRIVER UPDATE, INTERNET SECURITY... OPEN FOR ACCESS/SELECT TOOLS*****
Dec 15, 2010 | Acer Aspire 4315 Notebook
Boot up menu restart; will not power
Boot up to the safe mode screen & select last known good configuration.
Jan 15, 2009 | Gateway 4026GZ Notebook
I add downloaded messenger to my emachines ET1641-02w
e machines have problems like this. unplug it from the back of the computer for ten seconds, plug it back in, do a start mode> If this does not work try rebooting to an earlier time
Jan 09, 2009 | E-Machines eMachines Desktop PC
I turn my computer off and back on i hear the music but i get a black screen
Try and do a XP repair: Boot the PC with a Win XP cd.
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your applications, it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 18, 2008 | Dell DIMENSION 3000 CELERON 2.4GHZ...
Windows XP
load up your boot xp cd ensure your bios is set to boot from the cd
Jul 26, 2008 | Computers & Internet
Intel Desktop Board D850EMV2 Motherboard Logo
153 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
