Question about Panasonic SA-HE200 Receiver
Panasonic I have a Panasonic 6.1 receiver. sa 200 i have connected various speakers to it in the proper manner. I have a Kef centre speaker. wharfedale front r + l but they are different ohm set up. Is this a problem for my receiver, i also cannot seem to get any sub out volume. i have sent the sw signal to max. Is it possible i have loaded my receiver too much with my varied ohm requests from speakers.
    Genius:
  • 1,074 Answers
Because you have connected speakers that are not the same ohm you had damaged the output transistor or IC of your set, you have to get it replace and get the right the speaker
Posted on Jan 22, 2007
Safe to use 4 speaker with Technics Receiver?
The best thing to do is place a VOM meter to confirm that there are 6 ohm speakers
Nov 21, 2014 | Technics Audio Players & Recorders
Compatibilty
If what you say is true, you should be fine.
Where you get into trouble is having an amp of higher power than your speakers. That means you will likely blow your speakers.
Nov 12, 2014 | Audio Players & Recorders
Speakers
All speakers can be 100 Watts. The Front speakers can use 4-8 ohms. Center and Surround jacks can use 6-8 ohm speakers.
Mar 31, 2014 | Panasonic SA-HE70 Receiver
Marantz NR1402 AV receiver Going to standby Mode
There could be a short in one (or more) of the speaker connections. Try disconnecting all speakers and turning on the receiver. If it still switches to standby, there may be an internal problem.
Mar 03, 2014 | Marantz Nr1402 Av Receiver
Please send me a diagram of how the wiring is to be set up on the back of the speakers
The red connector on the speaker should be connected to the Pos.(+) connection on the Receiver/Amp. The Black to the Neg. (-) connection. ( for the proper speaker) Front Left, Front Right,etc. All, or most paired wire has either a black stripe,different shape on one,or different colour wire(silver/copper) So if you hook up the Blk striped or silver to the Neg.(black terminal) on the speaker, do so at the other end (receiver ) If both speakers aren't hooked up the same, they will work, but there won't be as much Bass because the speakers will be out of phase.(when one speaker cone is moving out,the other will be moving inward.
Dec 03, 2011 | KEF Audio Model Three Main / Stereo...
My parents are getting rid of their Panasonic SC-HT700. The receiver is shot. The speakers and sub work perfectly fine. I was wondering if I could purchase a used receiver (found the SC-HT930 on ebay) to...
the speakers are 6 ohms, and it will be very difficult to find a receiver that is 6 ohm compatible. most home amps are 8 ohm, and will overheat and burn up when used with 6 ohm speakers.
the subowoofer is 4 ohms, but i am unsure as to whether it is self-powered, or if it is powered by the receiver.
4 ohms is the standard for car audio, and 8 ohms for home audio.
Oct 27, 2010 | Panasonic sa-ht930 Home Theater Audio...
OVERLOAD
First of all the KEF is a powered sub which means that it wants a line level signal NOT a speaker level. Send the signal from a tape output or pre-amp output to the sub input. The overload is because the impedence load for the speaker output is too low and looks like a short to the amp. Continued attempts to connect the system as described will result in damage to the output section of the amp.
Please let me know if you need more info.
Dan
Feb 03, 2010 | Technics SA-DX750 Receiver
Replacing a Surround Sound System Receiver
the difference is the "same speaker connections"
the front and rear will connect the same but the subwoofer is amplified by the HT75 , and the HE75 does not have an internal amp for the subwoofer speaker , only a "pre output"(has to be amplified)
Mar 24, 2009 | Panasonic SA-HE75 Receiver
Speaker connection from Denon AVR 2105 to Wharfedale suround
The spkrs sound like they are bi-amp spkrs, meaning you have multiple terminals on the backs of each spkr, the jumpers on the spkrs should be connected as such. Now you just connect the spkrs according to the Denon spkr conection diagram. Do not use the surround back unless you have 6 or 7 pair of spkrs
Jan 27, 2009 | Denon AVR-2105 Receiver
Speakeres killer
Are you paying attention to the power rating of your speakers? Your receiver has a high power capability and would be quite capable of destroying speakers with inadequate power handling capabilities.
By the way, the Tivoli was a great place to be in 1963 for a young guy!
Hope it still is . . .
Apr 23, 2008 | Technics SA-DA10 Receiver
Panasonic SA-HE200 Receiver Logo
103 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
blanqui2000
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
