Question about Microsoft Xbox 360 Console
Router do you have to use a router or can you just use a hub ? isnt a router just another firewall?
    Novelist:
  • 98 Answers
When I got my 360 console, I went out to Walmart and got an Etherfast Cable/DSL router with a 4-Port switch and never had any issues with it. Probably the cheapest and most reliable way to go too. Hope this proves to be useful. Take it easy!
James
Posted on Nov 24, 2008
How can i reset my password on a bt hub
If you do not remember the login password then you have to reset the hub. Reset the red reset button with a paper clip and the hub will return to its factory settings.
Keep me posted
Jul 15, 2014 | BT 2Wire Gateway BT2700HGV Home/Office...
My brand new hpc4780 photo smart printer is not working. When I connected with an HP adhoc connection, it worked fine. So, HP advised that there is probably a firewall on my netgear router blocking my...
Hi, i have the same issue and it isnt the firewall. But here is how to disable it if it is. Go to the router websight at 192.168.0.1 (type this directly into the browser bar at the top of your page. The password is usually password in lowercase. The username is admin. This will get you into the management screen for the router config. Look on the Left and you will see firewall. Click on this then ensure that there are no restrictions for HP.
I still have the issue with the printer so good luck.......scotty
Sep 13, 2010 | NetGear DG834G 802.11G Wireless ADSL...
Iv got a BT home hub 2 cant get conections for utorrent even though opened firewalls
There are ISPs that block utorrent. I found this explanation of how to do port forwarding on the BT home hub, though: http://portforward.com/english/routers/port_forwarding/BT/BTHomeHub/Utorrent.htm
So, all I can suggest is to open the ports on your home hub as suggested above and to connect your computer straight to your home hub rather than to your CWR-854 (unless you actually have no such router and just picked that to ask the question under).
It is possible that someone has decided that you should not use torrents (they slow down everyone because they actually have the nerve to use the internet) and they are associated with thieves. Not to mention that there are tons of legit uses for them,
This could be someone in your ISP or your house. So do you have access to everything? You can poke around with telnet - can you access the ports on the other systems that utorrent accesses to make itself part of the network of systems that are downloading and sharing the torrent?
But if one knows the ports it is easy to block torrent.
If you have multiple routers that do nat, the home hub has to forward to your router, not to your system. So if your router is 192.168.3.12 and your system is 192.168.5.6, the BT home hub has to forward to the port on your router, on 192.168.3.12 , and your router has to forward to your system on 192.168.5.6. If the home hub tries to forward directly to your system (if you have multiple routers, which you might have because of the way you asked your question) then it won't work since your router hides 192.168.5.6.
Jan 09, 2010 | Cnet CWR-854 Router
Can anyone help me set up a dmz on this router(zyxel p 334)
Do you have a static IP to portforward with? i would not recommend DMZ because most routers lie - they still use a firewall even with DMZ.
Jul 01, 2009 | Zyxel Prestige 334 Router
Tried to hook up a hub from computer to xbox360 wont work
Hub? Use a router. I have mine hooked up through a older D-link wifi-G router and it works fine. A router also works as a hardware firewall so no one can hack into your network. And they are cheap to pick up used! Don't forget to lock your wireless network on it or turn it off to keep it secure. Hope that helped.
Jan 05, 2009 | Microsoft Xbox 360 Console
Modem to router to hub to wireless
What you can do is test the PS3 while wired to the router first. If that does not work you may need to forward ports on your router so it will allow the PS3 to accept connections through the router firewall.
Nov 26, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Linksys 5-port Workgroup Hub
Hi Tman,
Here is a link to the Xbox ports. http://support.microsoft.com/kb/908874
In the firewall option, direct those ports to the IP of your Xbox. I don't have an xbox, but I would think there is someway to set a static IP on it. That way DHCP won't change your xbox ip when you reboot it. Some routers allow you to assign a specific IP to the xbox, but not sure about yours.
Visit this site, http://portforward.com/routers.htm It may have your router, and will tell you how to setup the ports for your xbox step by step.
Jan 06, 2008 | Linksys EtherFast Cable/DSL Router
Microsoft Xbox 360 Console Logo
37 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
