Question about Apple iPod MA446LL/A MP3 Player
My ipod 30 GB turns off on me in less then 10 seconds
How can i fix this problem so that this ipod can work for now on ?
    Scholar:
  • 42 Answers
I would suspect the battery is going bad. Try connecting it to the computer or to a wall charger to see if it goes off then also. If it stays on, then you know that the battery needs replaced. Hope that helps.
Posted on Dec 19, 2008
How do I fix my frozen e reader
Like all electronic devices, iPods sometimes freeze and become unresponsive. Sometimes iPods lock up when they're dropped on the ground or come in contact with water, but less destructive accidents may also cause them to stop working. All versions of the iPod have a way to reset their hardware should they stop playing music or refuse to turn off.
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated. An iPod will appear frozen and unresponsive if this feature is activated. A lock symbol will appear on your iPod's screen if it is in Hold mode. Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button. Press both buttons at the same time and hold them for up to 8 seconds. Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen. Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod. Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it. Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons. Connect your iPod to its powerblock or a computer if it is still frozen. Wait 5 minutes and then try to reset it. Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again. Hope this helps.
Jan 19, 2013 | Apple iPod touch 1st Generation (8 GB) MP3...
Ipod won't turn on
Plug your Itouch into your PC. Hold down both the on/off button at the top and the menu button (center of unit below screen) for 15-30 seconds. You should see the Apple sign come on and your unit is rebooting. Worked for mine
Apr 17, 2010 | Apple iPod touch
My ipod 30 gb just froze wont even switch off pls help
You just need to reset it, hold down the middle button and the "Menu" button for about 7-10 seconds, or until you see the Apple logo.
Hope this helps!
Nov 11, 2009 | Apple iPod nano
The screen says: connect to power supply, Itunes does not recognize the ipod and i cannot get it to respond to any command
I had the same problem and I just got it fixed by pressing the menu button and center button at the same time for about 10-15 sec. Apple sign showed up and a few seconds later it turned on. It works fine now. Try this. Good luck
Jul 03, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
I have an older 30 gb video ipod and that worked jus fine but when i pluged in a newer ipod nano it doesnt connect and it does with a brand new 16 gb ipod touch. is there anyway to fix this problem?
When you synced to a newer version of iTunes, everything was fine, until you connected the nano and
the touch, which worked fine, and then you tried the 30 GB again and it would not work, right?
Upgrade the software in the 30GB, not with your original 30GB disks, but with newer disks supplied NOW
by Apple, since iTunes went to version 8.1.1 and everything should be back in sync.
Apr 10, 2009 | Dual Electronics XDVD8183 Car DVD Player
Won't recognize ipod touch but shows under my drives
put it in DFU mode while connected to the computer. to do this, hold the home and power buttons for 10 seconds and then let go of the power but keep on holding the home for 10 secs. the screen will be black and nothing will show up. go to itunes and click on your ipod on the left. then click restore. this should work.
Apr 01, 2009 | Apple iPod touch Second Gen (8 GB,...
Ipod nano 4th generation hold switch won't turn off, icon remains on the screen and cannot use any of the buttons
First, connect your iPod to your computer, slide hold switch on and off, and hold the Middle + Menu button for 30 seconds.
If that doesn't work, disconnect your iPod and slide switch on and off, and hold the Middle + Menu button for 90 seconds or less.
Nov 23, 2008 | Audio Players & Recorders
Frozen ipod
First thing to try is a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
If that doesn't fix it, continue here:
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
Jul 14, 2008 | Apple iPod MA446LL/A MP3 Player
30 gb ipod not connecting to computer.
If nobody has figured out this problem or if anybody else is having the same problem I have a solution that could possibly work. I had the same problem so I right clicked My Computer and went to Properties. Click on the Hardware tab, and then click on Device Manager. Scroll down to Universal Serial Bus controllers look for anything that may have a yellow exclamation point. Mine said something like Apple Ipod Driver or something along those lines. Right click that and click Update Driver... Then click Next and it should update it for you and work fine. Hopefully this will help anybody that is having this problem.
Jan 24, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod shuffle will not work
take the ipod back and buy a sony, ipod suck I have been waiting on the "ipod help line" for 30 mins on my mobile.
My ipod shiffle won't work at all!!
Dec 24, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Apple iPod MA446LL/A MP3 Player Logo
23 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
