Question about Garmin Nuvi 660 GPS Receiver
Starting point is wrong
Whatever I do the NUVI wants to start from a location 60 miles from my home as a starting location. I have tried changing my home address but that does not work. Whatever I do as soon as I turn the GPS on it goes to that location. I don't even know what the location is. What can I do? Thanks.
  • sharonstrous Jan 04, 2009
    I tried resetting and it changed to a new starting address but still a wrong one. When I use favorites it shows the correct address as Home. My model is Nuvi 350. Help!!??
    Thanks.
  • 928 Answers
As you are turning on the unit press and hold the lower right corner then it will come up with a reset option. Reset the unit. If that does not work please reply back with the model of your Nuvi unit.
Posted on Nov 24, 2008
  • Thomas Lim
    Thomas Lim Jan 04, 2009
    Try instead the reset with the small hole in the back. Press it in for 15 seconds then turn off and on the unit.
Error in "go home" function. inputed correct
Try this see if it works....
Tools...My Data....Set Home Location
also
To change your Home location, touch Where To...Favorites...select Home from the list. Then touch Edit ....enter your changes , and touch Done
Oct 27, 2010 | Garmin nuvi 1300 Car GPS Receiver
How to change my start location
Press Tools, My Data, Set Home Location.
Select an option
  • Enter your new home address
  • Use your current location
  • Choose from a list of recently found locations
Aug 12, 2010 | Garmin nuvi 255W GPS Receiver
Wrong starting location
you didnt mention it but i assume its not aquiring the satellites. got to the link below and update your unit if you havent already. if you have that already, the link also explains the hard reset.
Aug 07, 2009 | Garmin NUVI 360 GPS Receiver
Location is not shown correctly
everytime u turn the GPS device on it takes anywhere from 30secs to 4 mins to find and lock in the satellites . Once the satellites locked in it will be then start taking ur commands. In ur case u turned it off as u started driving and when u restarted it , it had a memory of where u turned it off and displayed u the location where u turned it off which was ur home, right, now if u would have waited till some satellites locked in , it would have then automatically displayed ur then current location. so next time when u start the unit (any GPS) wait till it locks in the satellites.
thank.
Apr 20, 2009 | Garmin Nuvi 370
My nuvi 760 routes me the long way around
You should do the following: Changing the Navigation Settings;
Touch Tools>settings>Navigation. There you'll find how the sysytem will calculate your route.Route Preference.........Faster Time....Shorter Distance.......Off Road....Avoidances,very helpfull....Restore original navigation settings.
Hope this will help you,
JADF
Mar 24, 2009 | Garmin Nuvi 760 Car GPS Receiver
Garmin nuvi starting location is wrong
I tried to fix a problem similar to this for 1and 1/2 hours. Ahhh! However, after raising the antenna, (in back of device), the satellite picked up my exact location. Hope this helps.
Nov 23, 2008 | Garmin Nuvi 350 Car GPS Receiver
Getting started
I just moved to another location - changed the start point !
Nov 05, 2008 | Tomtom ONE GPS Receiver
Change Home Location on Nuvi 660
Go into 'Where To', 'Favorites', 'HOME', 'Edit...', 'Delete'. Then from the main map screen you can tap the screen and 'Save' the location as your new home. You can't save a 'Home' location if there's already one called that in memory, so you have to delete the old one first.
(I have a 680, but I assume it's the same)
Oct 16, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
154 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
