Question about Apple iPod MA446LL/A MP3 Player
80g ipod video black
I plugged it in to the computer to charge it it said safe to unplug but i cannot get it to come on now. it stays on the screen that says "safe to disconnect" with a check mark. My son bought a new one and gave this to me and i am not really sure what i am doing yet
  • angelgonzale Nov 24, 2008
    absolutley beautiful!!!! worked like a charm!!!!!!!!
    Thanks a million
  • 33 Answers
Try a maunual reset: Move the hold switch from off to hold and back twice then hold play button and the middle circle button at the same time for 5 seconds. Hope this helps.:)
Posted on Nov 24, 2008
  • Sean J
    Sean J Nov 24, 2008
    Glad to Help :>)
80g ipod video. screen has ipod logo and screen
hold the select and menu buttons until the apple logo shows up, then quickly switch to holding the select and play buttons, this should put it into "disk mode." plug into itunes and click restore.
Nov 16, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod won't turn on
It may be that the battery has drained to such a low level that it is only barely charged. What I would do is leave it for a couple of hours charging using the apple usb cable supplied (if you have still got it) and also if you are using a usb hub plug it directly in the computer usb port. Hope this helps, if not send me a comment.
Nov 05, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod says charged, but when i unplug it it cuts
  1. First thing to do is restore it to factory settings to see if that corrects the problem.
  2. Make sure you’ve installed the latest version of iTunes.
  3. Open iTunes, and then connect your iPod to your computer.
  4. After a few moments, it will appear in the Source pane in iTunes.
  5. Select your iPod in the Source pane and you will see information about it appear in the Summary tab of the main iTunes window.
  6. Click the Restore button. A window will appear asking "Are you sure you want to restore the iPod "iPod" to its factory settings? All of your songs and other data will be erased."
  7. Click Restore again. (If you're on a Mac, you'll then need to type in your password.)
  8. During stage 1 of the restore, a progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
If all else fails and the battery is bad, replace the battery. Here is a video that will show you just how easy it is. No need to pay Apple any more money than you already did to repair it.
http://www.youtube.com/watch?v=2h53otOBTsI
I hope this helps and good luck!
Nov 03, 2009 | Apple iPod MA446LL/A MP3 Player
My ipod touch will not turrn on or reboot whats wrong?
Checklist to see if your iPod needs a reboot:
. Your iPod is charged.
*If not, you might have to plug in your iPod, and make sure the computer can't go to sleep while it's charging. The iPod won't charge if the iPod is locked, so no orange.
Charging your iPod problem solution, that also works.
* Your iPod might need to completely drain in battery source before you can charge it. If that's the case, leave the iPod unplugged for 24 hours before trying to charge it. That will make sure the power is drained and your iPod is ready to be charged.
2. Your iPod is unlocked. Slide the button back and fourth a couple of times, just to make sure it's working.
3. And your iPod still has a black screen, frozen logo, or white screen.
Rebooting your iPod.
1. Run a cold boot (shut your computer down, then turn it back on) on your computer. * If your iPod crashed because of the software freezing, or the computer crashed.
2. Open your Apple Software.
3. Plug in your iPod. Make sure that you plug in your iPod into your computer, and that the plugs are secure. Your computer should detect your iPod, black screen or not.
4. Set down the iPod. Take your iPod and put it on a flat surface.
5. Press firmly. Take your fingers, and firmly press the middle button, and the menu button. It will read menu on the top button of the click wheel, and the center circle of your click wheel is what your looking for.
* Make sure your fingers are planted on the top of the center button, close to the menu button, and you are pressing it together.
6. Count to 8.
Now you should see an Apple logo pop up on your iPod screen.
Sometimes you need to try it a few times, to get it to work.
It should be synchronizing and happily you should be on your way.
*You also can reboot your iPod without it being plugged into the computer, I always do mine while it's plugged in.
you have to erease all the dta on mines and put the music and everything back on,
Sep 23, 2009 | Apple iPod touch
Ipod freezes when i go to connect it to my computer or charge
even if the screen is blank it definatly should charge, then enst thing i could recommend is to possibly reinstall the ipod firmware or if your daring enough to turn it into a rockbox. google rockbox and you will find that it is free ipod software that many people find better than apple's actual software.
Sep 16, 2009 | Apple iPod MA446LL/A MP3 Player
80g ipod classic won't unlock or charge,and itunes won't
My 80GB Ipod classic recently froze. I took it to Apple store and the guy press the Menu and Center Button. Hold them until the APPLE logo appears twice. Then release the button.
Voila, my Ipod work again, no missing data
Jul 22, 2009 | Apple iPod classic MP3 Player
My Video 55 player will not play my videos
You need to switch the video out seeting on the iPod, simple. It is located in Video/video settings/TV Out. Change the setting to "On". Problem solved. However, if you have an iPod that is less than 1 year old, nothing will work, iPod blocked this ability to change to "On" and is set on "Off" permanently.
Mar 04, 2009 | Sonic Impact Technologies Sonic Impact...
80g ipod (5th generation video) - problem with restoring and recovery mode
Do a full reset of ipod. Disconnect it and follow instructions here:
http://support.apple.com/kb/HT1320
Jun 14, 2008 | Apple iPod MA446LL/A MP3 Player
IPod 80g
Hmmnn.
Id Say Id Try To Get Apple To Repair It.
Regards,
Sophiee.
Feb 29, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
