Question about Philips PM435S Remote Control
No power I put duracell alkaline batt's in, no power goes into remote led light to show it is on so I cant program. Iam in vancouver B.C.Canada rc5003-slv super sized remote. thank you Herb S.
  • herb1934 Jan 02, 2009
    Still does not work but thanks for the help.
    Herb Happy new year
Try hitting it to the palm of your hand. Mine also did the same. that fixed mine.
Posted on Dec 27, 2008
Satellit 800-batt blinks w/new Duracell alkaline batteries.
Have you checked the voltage on the new batteries.??? Some batteries, even if they are new... have a short shelf life, if they aren't used. You will need a volt meter or battery tester...if you dont have either, take the batteries to a Radio Shack or even a Auto store and ask them to check it for you.
Oct 20, 2014 | Cameras
Iwave rc5003-blk universal remote won't work with old toshiba tv. How do I program it and test?
Automatic Programming
  1. Turn off the device that you want to use with the remote.
  2. Press and hold the corresponding button on the remote until the light turns on.
  3. Press and release the power button (DO NOT HOLD); the light will flash once and then stay on.
  4. Press channel up or channel down; repeat until the device turns on.
  5. When the device turns on, press Ok to store the code.
Nov 16, 2012 | Televison & Video
I just replaced the batteries in my 2 D LED maglite with duracell alkaline batteries and after about 5 minutes use seem to have blown the led. Torch is less than 1 year old and has had limited use. Looking...
The resistor needs to be disconnected at one end -- if the LED is removed this should have the same effect as disconnecting one end of the resistor.
Put the probes of an ohmeter on each end of the resistor -- if it reads 0 ohms (or near zero), it is shorted.
Charlie
Mar 26, 2011 | MagLite Mag-Lite& Flashlight
Batteries are completely discharged after a few pictures are taken.
Batteries you are using are not up to the job, the camera has high power usage so buy some decent Nimh rechargeables and a charger (make sure you buy at least 2000maH batteries) If you don't want to do that use decent alkaline cells such as duracell. (That will cost you a lot more in the long run)
You will find that the batteries you think are finished will power other items OK, they just cant provide the power your camera requires, so don't throw them away before you try them in your radio or remote.
regards
Feb 01, 2011 | Samsung Digimax A7 Digital Camera
How can i check if which need replacement my batt or my charger coz when i charge my batt the led lights on then after a while it turn of the led light then ill unplug it and plug it then still the same...
Power Source Li-ion Rechargeable Battery (LI-42B) Are you using the above battery?
Check the voltage to make sure it has enough as printed on the charger or the battery.
Alkaline rechargeables, or NiMH rechargeables, or other types of batteries don't have enough voltage or amperage as compared to Li-ion.
Jul 03, 2010 | Olympus FE-280 Digital Camera
Iwave model# rc5003-slv SUPER-SIZED TV REMOTE NEED CODE FOR
hope this helps http://www.lexrixa.com/vcr%20codes.pdf has a list for the remote you have for different makes and models
Apr 02, 2009 | Philips PM435S Remote Control
Recently changed the battery and now everytime I shoot a picture the camera goes off and has to be re-powered back on to take another. Now, it won't power back on.
you need to check that you have put in the correct type of battery. Some cameras will only work with alkaline batteries.. I had this problem with my samsung when i inserted zinc batteries instead of alkaline, I use duracell cause they are pretty good for taking lots of shots before running out.
Dec 23, 2008 | Samsung Digimax D53 Digital Camera
My Camera Won't Come On At All.
I have had this exact problem with this camera. I find it behaves much better with rechargeable batteries or oxyride disposables. The stupid part is that it is supplied with alkalines, which can't handle the power requirements of the camera. Even "High power" (eg duracell M3) alkalines are unlikely to work adequately.
Rechargeables will save money in the long run, anyway.
Sep 05, 2007 | Samsung Digimax D53 Digital Camera
Canon S2 IS won't turn on with rechargeable batteries??
I would let them charge til you get an indication that they are done. TV remotes require very little power to operate, while digital cameras need a lot, so that's why the batteries would work in the remotes though not fully charged.
Jun 16, 2007 | Canon PowerShot S2 IS Digital Camera
Batteries
i suggest by 4 NIMH and a charger and look to capacities of above 2500 MAH (anything higher is better) this camera is power hungry all the time , i do not recommend duracell penlights (alkaline) they are draint in 3-5 shots even the high power alkaline cells (aa) of duracell
Feb 27, 2007 | Nikon Coolpix 7600 Digital Camera
Philips PM435S Remote Control Logo
44 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
