Question about Philips Magnavox 51MP392H Rear Projection Television
Need a part for my magnavox tv
Please help me locate this color module, my tv lost its color and technicians recommend to replace the whole board
TD 1336 / FGHP
E20 9262
Tarjeta Sintonizador
8238-273-8270-3
Microprocesador
PNX 8552 EH / M2 / S1
N36313.00
TV Model
Philips ID 37NF331D/37
Serie BZ3A0623461251
143431
nfandres
  • 168 Answers
SOURCE: Magnavox 51" TV Screen
try 3Dlens.com. this screen is made of fresnel lens. good luck!
Posted on Feb 03, 2007
take the broken piece to the hardware store and have a piece of plexiglass cut the same size. thats what we did and it worked really well.
Posted on Sep 12, 2007
SOURCE: color faded
9p6031c has similar problem. Can we just change out the color tubes??? Who has them and how inexpensive can we get them???
Posted on May 17, 2008
SOURCE: Schematic and/or wiring diagram - Magnavox TV Mod 20ms233s
the problem in my tv is the sound no have
Posted on Jul 04, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Philips Magnavox(model 9P6034C102 )
This is any easy fix. Goto www.magnavoxhelp.com to get a repair kit. Its a common problem on some of the older Magnavox projection TV sets.
Posted on Jul 31, 2008
We lost power the other night. Now I have a continuous green blinking light and it won't turn on. I have tried everything the manual says.
Try Going To The Mitsubishi Web Site. Downloading The Mitsubishi Service Manuals If You Don't Already Have It. It Will recommend The parts You Need To ordering. Circuit board photos are also shown which provide a visual reference during the repair process.
If you decide to have a service technician do the repair, insist that the "DM" module is removed from the TV and ONLY the four 1000uF, 16V Capacitors (Caps) located on the DM Module are replaced. MOST techincians will INSIST on replacing the entire DM Module and not simply the capacitors. The cost is about $200 for a technician to replace the capacitors and $1000 for replacement of the DM Module. As you will read below, doing the repair yourself will cost less than $4.00 for the 4 Caps.
Sep 04, 2011 | Mitsubishi WD-52525 52" Rear Projection...
The screen loses all color and goes very bright.
I guess they replaced the panel, that cost approx $400. but the t-con board may cause this issue. if you need the part number and price. you can tell me the whole model # and version #, there is a sticker on side of the TV.
Jun 17, 2010 | Samsung LN32C450 32 in TV
Magnavox 37MF331D sound and picture fine, no color. What happened?
The problem is in ssb. [scale board] I call it the signal board. But briefly part, location 1H00 [color crystal] PN#823827736071 needs replaced. And caps locations 2H08 and 2H09,PN#223886975478 need replaced. Hope this will help you...these are surface mount repairs that require skills!!!!
Jan 07, 2010 | Toymax Magnavox 37MF331D 37 in. LCD TV
I have a 42 inch floor model large screen tv, by magnavox that I purchased 1987. I've been informed that the "Power Board is gone; that it keeps shorting out the fuses. Please, please help me. It was a...
These have pretty complicated power supplies in them. They have the first switch mode power supplies that were used. It is difficult to say the least to find the parts for this set. The best you can probably do is try to find the whole power supply PCB. Try to contact Tri State module or moduslink. These companies rebuild modules and PCB's. Tri State info:800.203.7484 (ext. 203, ext. 210) or http://www.moduslink.com/Aftermarket_Solutions/index.cfm?ref=ARKADASBUL.NET Good luck and thanks.
Nov 01, 2009 | Philips Magnavox 27MS343S 27" TV
No picture and i replaced the bulb
Joe,
I've never heard of a color wheel costing that much even with labor included - I think I'd try to find another tech for his advice.. If you have trouble locating one try NESDA or let me know what city/state you're in and maybe I can help recommend someone.
That said, if the lamp is good the next logical thing to check is the ballast. If the ballast is not supplying voltage to the lamp then it clearly won't light. A ballast is not that expensive, similar to a ballast in a floresent light - only a bit more complex. In any event I would strongly suggest finding a real professional first we are out there...
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Dec 02, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips-Magnavox 9P5534C103 55IN. PEAR PROJECTION
TV does not display picture on whole screen....it has three smaller colored rings with the picture inside of it
Jun 01, 2008 | Televison & Video
Samsung TV model HCN5527W
The actual Convergence amp ICs not located on the convergence board are probaly what killed the origional convergence module, and likewise has killed the new board. You will need to change the convergence ICs first then replace the convergence module.
I would recommend getting the service manual . I can post a link if you would like.
Mar 17, 2008 | Televison & Video
Blue shadows have appeared on the screen
Hello All,
This is a convergence amplifier problem, it can be fixed for a relatively low price, however I do not suggest that you do this on your own because it may lead to more damage then what you have now.. The price the repairman is quoting you is fair, although I have repaired such problems for the cost of the parts and the labor, total of $180.00, but that was because I am able to work without overhead. I would suggest that you have a qualified TV repair technician fix this problem but if you really want to do it yourself here we go:
Turn the TV off and unplug it
locate the two STK IC modules on the metal heat sink (usually on the deflection board),
Remove the deflection board,
Unscrew the modules from the heat sink,
locate all of the biasing resistors connected to the STK modules and de-solder them along with the modules,
Remove the modules and the resistors,
Replace the modules and resistors with new ones (purchased beforehand),
re-solder all components (making sure that you do not create any shorts)
Check your work with a magnifying glass.
Re-install the deflection board, and power on the TV.
Adjust convergence to manufactures specifications.
I hope this helps,
Thank you,
Shuttle83
Jan 13, 2008 | Philips Magnavox 9P6034C 60" Rear...
No power with remote or manual power switch
Your convergence module is probably bad. It is a plug in module, so labor would be lower if the convergence settings are still good. The bill would be about $300.00 If not, the labor for convergence would add to the bill. If the whole job needed full convergence the cost would be about $500 to $600. Hope this helps, Lee http://www.CrazyComputers.com
Jun 22, 2007 | RCA P60921 60" Rear Projection Television
Philips Magnavox 51MP392H Rear Projection Television Logo
80 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
