Question about Palm Zire 71 Handheld
Palm Zire 71 Display Problem
While playing Super Solitaire, my display suddenly changed to to a dim gray backlit dsiplay with a two light green vertical bands. It is completely locked up, won't turn off even. I am hoping the battery will eventually drain, and the PDA will work properly on restart. Any ideas?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 20 Answers
If a hard reset does not fix the display, you have a hardware problem.
Posted on Jan 25, 2008
  • 59 Answers
If you slide your Zire up as if you are using the camera, there is a reset hole in the back that you can poke a needle or pin into to have it do a "reboot" which will not lose data.
Not sure why the display changed.
Posted on Jan 07, 2008
Light gray screen with vertical color bar in center
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jul 29, 2015 | Panasonic Televison & Video
Disney princess tv suddenly narrowed the visible part of the screen. Now everything is squished into a two in wide band with all the rest of the screen is black.
if that 2 band according to you from top to bottom,it has a defective vertical stage.if this two band appears one on top and one at the bottom,it`s on vertical stage.leaky capacitors,resistance changed or resistor devalued ang ic`s, are too weak to amplify a signal to make the screen complete....
Jan 29, 2014 | Disney 13" TV
Cq40 180tu laptop display problem
Go to the display options in Vista. Redefine the image settings and see if that solves the problem.
Jan 20, 2013 | Microsoft Windows Vista Home Premium with...
Monitor dims when we turn lights off in room.
You need to give a more detailed description of the problem.
The LG 47LH90 is an LED backlit TV with 'local dimming' technology. This means that there are lots of white LEDs behind the screen and these can be controlled in groups to allow localised areas of the screen to be dimmed to produce better contrast between light and dark. It is very likely that when the room is dark, this local dimming is more noticeable. The actual individual LEDs cannot be controlled and so the area that is dimmed will generally be greater than the area that is required to be dark 'blooming effect'. In addition, LED backlit displays only maintain their contrast through a tight viewing angle. If you sit too farto the right or left, then light from non-dimmed LEDs will leak through and the screen will look lighter.
In short, there may not be any fault with your TV.
Jul 12, 2011 | LG 47LH90 47 in. HDTV LCD
My eee pc suddenly had screen problem a week ago--- when it boots up the screen is solid fluorescent green, then as Win XP starts there wide vertical bands appear, and finally what i'm left with is an...
I just had a smilar problem with the vertical lines and resolved it by disabling the display adapter, the display driver was corrupted, and i am using it to type right now and no problems. Go to the device manager and disable the disp0lay driver by right clicking on it and selecting un9install and restart. I could hardly see through the lines but I did it and it worked. Windows automatically comes with drivers from many manufacturers for many devices and it seemed it has one for mine and it worked as my display adapter is still disabled but my graphics are perfect....All the best!
Aug 17, 2010 | Computers & Internet
When swiched on, the screen displays green vertical bands which almost obscure the picture. By switching off and then back on, the green bands disappear but the vertical edges on the image are very...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi
Most likely a power supply component has aged and thus changed value and/or failed. Take it to a reputable repair person.
Mar 13, 2010 | LG RZ32LZ50 32 in. LCD Television
Sudden change to screen resolution on Spidaire Solitaire only
hi
sheiab try this
go to run and in run type msconfig and in msconfig try to change the boot oder of the computer and disable all start up from the computer and check the things would will definetly work
Jul 22, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
DLP TV: Left half normal, vertical 6" band center is gray, right half almost black. What's wrong?
No. The optical engine is OK. You need an adjustment in the light tunel. Call a tech to do it.
Nov 06, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
White screen with vertical bands
I have experienced the exact same thing. No dropping the Palm. No moisture. Just turned it on at work and it had the lines. Fortunately the data was still available for a synch. Now I am ordering a complete LCM and digitizer from PDA Smart.com. See http://www.pdasmart.com/palm-tx-repair-parts.htm for the pricing. It isn't cheap, but I believe it will fix the problem.  Let me know what solution you came up with and how the issue is now. Thanks, er
Aug 27, 2007 | Palm TX Handheld
Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Palm Zire 71 Handheld Logo
73 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
