Muteki 7.2 surround sound
SOURCE: Sony AMP/Subwoofer Problem
It is probably the tweeter, inside the Sub. it's the small ceramic disk between the cone magnet, and the speaker. id this thing is cracked or broken, this will cause the problem. if this is not it, then it is a problem with something in the wiring, and the only way to rectify it is to buy a new sub. Sorry due :(
SOURCE: Teac legacy AG-800 AV receiver.
Hi most amplfiers have DC offset and short circuit protection. Since you have removed all the loads it should not have a short circuit on it, the other possibility is DC on the input so I would recomend trying disconnecting the inputs as one of them may have DC on it, however this is unfortunately unlikely. The most likely cause is that the unit has gone wrong and the power amplifer is faulty. One last thing you could try is too open the unit up and make sure all the cables and PCBs are connected properly sometimes a loose connection can cause this type of fault. Failing that, unless you know how to fault find electronics, you will need to take it to a repair center or replace it. Regards, Andrew
SOURCE: How do I connect a Polkaudio powered subwoofer (psw 125)
Connect a set of stereo RCA cables from the 'Output 2' on the Hafler to the line imputs on the Sub.Turn on the '1+2' output switch on the Hafler and rock out!
SOURCE: Connecting KLH subwoofer to a Sony receiver
Just click and choose whatever hooked up connection you want;
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ..
Plasma or Video Projector Wiring Guide
Blue-ray Surround Wiring
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
SOURCE: i have a bose ta 1 theater amp i need adapters and
check the maplin site maplin.uk they ahve a catalogue of connectors and cableing
