Question about Dewalt 18 Volt Compact Drill Kit
Removing the dewalt DC925 'rohm' chuck
How do you remove the DeWalt DC925 chuck? This is the new drill (not DC988) with the Rohm chuck and it doesn't apear to have a retaining screw on the inside.
Many thanks
  • 2 more comments
  • Anonymous Mar 14, 2014
    How do I replaces the chuck correctly on my dcd950 dewalt drill
    How do I replace the chuck correctly on my dcd950 dewalt drill
    How do I remove the chuck correctly on my dcd950 dewalt drill
    How do I replace replace the chuck correctly on my dcd950 dewalt drill
I simply placed the chuck into a large vise and turned the drill counter clockwise and the chuck spun right off no problem without damaging anything!! It does have some thread lock on the chuck but just use your man strength and its as simple as turning the lid off the pickle jar! Do not waste your time or money with the removal tool...YOU DONT NEED IT!
Posted on Oct 18, 2009
  • Derreck Fenske Oct 14, 2011
    thx yer sugestion work out awsome:)
There is no retaining screw with this Rohm chuck (Dewalt PN$ 330075-75 / ~$50 approx cost).
Dewalt sells a special chuck removal tool for ~$75 chuck (nice and user friendly...NOT !!! ).  I have not used or seen this tool, but it's my understanding you're supposed to remove the transmission and gear box together and place them in this tool / fixture which is the tightened into a vise. Once secured, you can then safely remove the chuck without damaging anything.
Now here's the way I'd do it.  Get the largest (high quality) 'L' shaped allen wrench that will chuck up and chuck the short section into the drill.  Put a steel pipe over the arm of the allen wrench for leverage.  Carefully clamp the drill to a table or carefully secure it in your vice with soft jaws and then try twisting the allen wrench / handle counter-clockwise until the chuck loosens.
You could also try this same idea with a slightly different approach, which is to firmly secure the 'L' portion of the allen wrench in your vice.  Then chuck up the drill to the long straight end of the allen wrench.  Once its chucked up, then carefully and slowly with very firm pressure twist / unscrew the drill body counter-clockwise until the chuck loosens.
Install the new chuck using this same procedure in reverse.  If you don't want to bother with any of this, I believe you can also buy the chuck + spindle / housing assembly as a unit for about ~$125.  Then you'd simply take the drill apart, remove the old assembly and install the new one without the risk of damage from clamping your drill body to tight or turning things the wrong way, etc.
Good luck to you and I hope one of these works out for you!
Gary
Posted on Dec 16, 2008
    New Friend:
Thank you. Setting the chuck in a large vice and turning the drill counter clockwise (posted on 18 October 2009) worked a treat. I'd definitely suggest it too.
Posted on Mar 28, 2016
    Novelist:
  • 99 Answers
It should have a retaining screw as far as I know. It may be a torx head in this machine though. Normally left hand thread screw, then normal thread for the actual chuck. It's always worth tightening the chuck a bit before removing the inner screw as it can put pressure on it and make it harder to loosen.
Posted on Nov 29, 2008
Removing chuck from dewalt dcd925
open chuck and look in the bottom of it (chuck)there is probably a screw there. think it will be left hand thread
Oct 25, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
Dewalt dc925 drill, the chuck jaws appear to be jammed tight shut and will not open. any ideas?
Hi, soak the chuck in crc overnight then put the drill in low speed and reverse. Hold the chuck by hand or with multi grips and pull the trigger. Hope this helps, regards Phil.
Jul 23, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
How can i remove the chuck from my cordless dewalt power drill
Hello, W/D here.
To remove your chuck, open the jaws of the chuck fully, but don't open them so tight that they lock in the open position. Remove the screw inside the chuck. Spray the inside of the chuck with penetrating oil. Tap around the edge of the chuck, while pulling it away from the motor.
It should come right off, with a little effort.
Best regards, --W/D--
Feb 08, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Need repair schematics for dc988 dewalt cordless drill
web search-dewalt dc988 schematics-click on 2nd site,{parts list and diagrams
Oct 06, 2010 | Dewalt 18 Volt Dc988 Hammer Drill,dc825...
How do i remove the chuck from dewalt dc925 cordless drill, dosnt have a screw inside the chuck, read somewhere that i need a special tool but no instruction or picture of the tool. please help., thank you
The dc925 and the current model dcd950 along with several other models of Dewalt 's line of cordless hammer drills DO NOT have a screw inside removal requires a CHUCK REMOVAL FIXTURE part #
233804-40 also you can't use a generic replacement chuck. As of 2/2/2010 the prices on the Dewaltservicenet web site are $72.74 for
the tool and $69.70 for the chuck, part # 330075-90.
Oct 17, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
I have a dewalt dc925 combi drill the chuck keep slipping and also the setting ring is hard to adjust . What can i do top solve this?
Probably needs a new transmission. They cost about $34 plus shipping. Easy to fix. Just remove the four torx screws from the metal (gray in color) part $of the drill. Then pull it apart. The transmission comes in a one piece cassette. Insert it, and put the front back on and tighten the screws.
Mar 10, 2009 | Dewalt 2 Dc925 18v ½ Hammer Drill /...
I have a DC927 and a DC926 that I removed 1/2" Rohm Supra SK key-less chucks on. This process is pretty simple. Put the drill motor in 1st gear. Put the clutch ring in drill mode and not in driver or hammer. Reverse or open the chuck all the way. Hold the chuck firmly in a vise and give the drill a good POP counter clockwise. The last step can also be done with a pipe wrench by placing the drill on a work bench and turning the chuck counter clockwise. Continue to un-thread until the chuck is removed. The replacement chuck must have the same mounting process and mechanism. Put a few drops of locktite on the threads and thread the replacement chuck back on. Tighten the chuck using the vise or pipe wrench. Place the short end of an allen wrench in the chuck and tighten down on it. Placing the drill on a work bench, strike the allen wrench with a mallet to finish tightening and locking down the chuck. Congratulations, you have just changed out your chuck.
Feb 16, 2009 | Dewalt DC927KL Heavy Duty 18 Volt Cordless...
Keyless Chuck releases bit when reversed
hi
open the chuck all the way and then look down in the centre of the chuck you should see a cross head screw
unscrew and the chuck should pull out as this is on a taper system ( note the screw is left hand thread )
Nov 21, 2017 | Dewalt 18 Volt Compact Drill Kit
Removing the chuck on a dewalt DC925 cordless drill.
I just changed the chuck on my 18 volt xrp half inch hammer drill,yes first you must remove the torx screw with #15 torx bit,note this is a left handed thread screw,knowing the bad chuck was bad I added some heat from a propane torch to the chuck then making sure it was in 1st gear i took some vise grips and the chuck is screwed on with normal right handed threads,it broke loose (was stubborn but needs a lot of torque )ahhhhhh wat a pain.
Oct 18, 2008 | Dewalt 18 Volt Compact Drill Kit
Keyless chuck problem
I had the locking screw come loose in the center and bottom of the chuck it has a left hand thread and is a torx head . It had backed out and prevented the chuck from closing.
Mar 14, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt 18 Volt Compact Drill Kit Logo
4,423 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Jim Thurston
Craig Butler
Craig Butler
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
