Question about Numark TTX1 Turntable
TTX1 went wacky
I've had my 3 TTX1s for a few years, I've gave them some hours but I take care of them. They've been run great until now. One of them malfunctioned during normal use. At first the brake failed, so I shut it down and turned it back on after a pause. At this point the turntable stays on 45RPM, the platter begins spinning as soon as the table is turned on, the brakes don't work, and when you try to switch to 33 rpm it goes into 78 and is stuck there. Like said, this just happened under normal use. Any help would be appreciated! Thanks.
  • 1 more comment
  • Anonymous Dec 23, 2008
    My platter does not start upon power-up but it sounds like the same issue I started having today...
  • guvnuh Dec 26, 2008
    One of mine will sometimes start, then stop after a few moments. Then other times it won't start at all, then at other times it will start and then stop immediately!!?? What is going on?
  • Anonymous May 14, 2009
    exactly trhe same, numarks customer service doesnt exist!!
  • 515 Answers
These are drive issues. More than likely one of the drive IC's failed. This will have to be repaired professionally.
- OPTiC
Numark Repair Videos
Numark DJ Repair
DJ Equipment Sales
Numark Parts
Posted on Jan 17, 2009
Have a 99 Frontier 3.3. Started running real rough, bucking and jerking. Didn't idle. Hard to start when warm.
I have seen a few crank sensors do this. When I pulled them, they had a small crack in them. Don't know where yours is. But guessing under the harmonic balancer.
Dec 02, 2015 | Cars & Trucks
My children had a change in taste buds when they ate their meal. When they drank water throughout the day they had pain follow.
You should discontinue this over the counter vitamin regimen until all symptoms subside before considering restarting with a lesser dosage. Vitamins for people of all ages can sometimes exceed 100% for a given day's recommended total. When you combine this with the amount taken in through normal diet, for instance Calcium gained by drinking milk plus Calcium in the vitamin, you can risk an overdose on the vitamin. Overdose can occur with anything and this will pose certain dangers to children as they grow. While it is admirable to desire to provide children with all the vitamins and nutrients they require to grow, one must be careful not to over-do it, as the saying goes with too much of a good thing.
Nov 21, 2013 | Natures Plus Animal Parade Gold Assorted...
Govideo com
They don't have a phone number since they went bankrupt.
May 28, 2013 | Televison & Video
Startup takes hours, help?
The clicking suggests a power supply issue, a old trick I use in cases like this is a hairdryer, Try to heat (don't melt things) different boards carefully until you get a dramatic reaction, considering the brand which I do not like much less endorse, what is there to lose.
If you pinpoint the issue to one board try to locate that board.
Dec 11, 2012 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Will not turn on. Unit has been working great until tonight. Was on but now off and will not come on. Unpluged it for an hour but still not working.
This same thing happened to me, and yesterday as well no less. I've had mine for a 3-4 years. I think It had run out of oil, which is weird because I've had a Holmes heater for nearly 10 years and it still has plenty of oil left. If you shake it, can you hear the oil? I went and got another from Target last night (it was the coldest night of the year) and can hear the oil swishing around in it as I set it up. Hope it last longer than another 3-4 years or my next one will be a Holmes.
Jan 22, 2011 | Honeywell HZ-709 Oil Filled Radiator...
TV screen goes black, sometimes for hours
This model series had a odd problem that caused this. It was the Hoizonal wire connctors for the yoke. If my memory serves me right, the Yoke wire harness went from Yoke to Yoke and plugged in at the casing of each yoke. What I found is the solder connection on the small board of each Yoke was intermitent. Please be careful if you choose to tackle this. It is in a HV Area.
Hope this helps,
Skyassoc
Jun 19, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Runs great until hot.
put some fuel cleaner in the fuel tank and replace the spark plugs.
Mar 22, 2009 | Honda CB 750 Motorcycles
Short Battery Life
just today figured out that the battery supposed to be at least 17 hours and i bought it before 2 years too and even when i bought it was my battery left only for 2 hours and until today i thought it is supposed to be like that.
Jan 10, 2008 | Sony NW-A1000 MP3 Player
Hitachi 50in. Ultravision Model #50ux14b
Vertical output chip has some ring cracks on leads (cold solder joints). Set is shutting brightness off to protect5 it's crts from burning a black streak across them.
Sep 03, 2007 | Televison & Video
Picture flips from color to black and white continuously
I believe your set has a loose conection that needs to be resoldered ,every time you hit it reacts and that is good,you need to use a wooden or rubber handle to tap in the main board,around the tuner and in different areas until it reacts,be attentive when it does so you can flip the board and resoldered the area that made it react,once the problem is corrected you need to resoldered any other overheated areas and there should be a few in your set,check the grounds in the tuner(where the coax goes in the inside,is a silver box),the horizontal driver transformer and output transformer.Be careful while you do this and stay away from the thick red wire going to the back of the picture tube specially when the set is on. Let Us know how it goes or if you need more information.
Nov 08, 2006 | Sony KV-32FS13 TV
Numark TTX1 Turntable Logo
378 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Morne Olivier
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
