Question about Maytag MGR5751AD Gas Kitchen Range
Oven takes a loooong time to reach target temperature
The oven used to reach it's target temperature in a few minutes, now it takes ages. I can smell gas faintly when I open the oven door but have been unable to remove the bottom panel to investigate the condition of the burners. (it is a convection oven so the manual says the bottom can not be removed). Any ideas?
Thanks
  • woodlandways Nov 25, 2008
    Sounds good aborcass, thanks for suggestion. I removed the bottom panel and turned the oven on, the glow block lit up plenty but the gas was a long time coming. Once the burner ignited, the oven reached target temp in seconds. I called Maytag and was told that the valve might be sticky or that the glow block might not be pulling enough juice to trigger the gas valve to open. I will replace glow block first and see if that does it. Thanks much.
    President:
  • Maytag Master
  • 2,651 Answers
Sounds as if your bake igniter has gone bad, common issue witrh all gas ranges, part number 12400035 this will cure your problem, comes will everything youll need including instructions
Posted on Nov 25, 2008
Whirlpool gold oven
One must preheat the oven to the desired baking temperature. If the oven is turned on and the food immediately put in to bake, it will take longer to bake the first batch than the second and subsequent batches, because the oven need a few minutes to heat up.
In other words, the oven isn't at 350 degrees the instant you turn it on. It takes about 15 minutes for the oven to reach 350 degrees. I hope this helps.
Jan 20, 2014 | Kitchen Ranges
Oven will not reach desired temperature and slight gas smell
Just had same problem it was nice it waited until christmas dinner, all i did to resolve the problem was switch the upper broiler igniter with the lower one for the oven. I tuned on the oven & it fired right up i never use the broiler on my oven so itll buy me some time. So if you can get the broiler to light try that but i did have the same low temp. & the smell of gas. Good Luck
Jul 29, 2010 | KitchenAid KGRT607 Gas Kitchen Range
Oven slow to ignite and come to temperature.
Change the igniter.
As they age, they often times will no longer draw enough amperage to allow the gas safety valve to open. Increasing the line voltage would help, but that's a little impractical.
Jul 18, 2009 | Kitchen Ranges
KitchenAid gas range superba not reaching/registering right temp.
Always preheat your oven and let it cycle at least 2 times. Your unit may show 350 but the manufactures know that it is not 350. When it registers preheated, it really means that it is at an acceptable temperature to start cooking. If you think that it may not be calibrated correctly, your owner's manual will have instructions on how to recalibrate your oven. You will be able to raise or lower the temperature by + 25 degrees or - 25 degrees. As far as the gas smell, you will from time to time smell a gas smell with a gas oven especially if you are right at it when it ignites. If you are smelling gas when it is not in use then you should be extremely concerned.
Mar 14, 2009 | KitchenAid KGST307 Gas Kitchen Range
15 yr-old GE electric oven takes over an hour to preheat to 450
After jiggling the lower burn element the oven heated up in the normal time. Perhaps a connection had come loose.
Feb 14, 2009 | GE JEM25 Microwave Oven
GE XL44 Oven Temperature Issue
Have you tried replacing the bake ignitor yet?
Dec 06, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven taking a long timt to heat to temperature
Try shutting off the breaker for about 10 minutes - then bring the power back on
Sep 20, 2007 | GE Profile JT912 Electric Single Oven
Maytag MGR5751AD Gas Kitchen Range Logo
248 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
