Cleaning if one thing take a hair dryer on low heat and fan and blow it along the keypad for about 3 min then tip the keyboard so it's facing down on table, and let it 'drip dry' for a day or so
that might help
if not, then the keyboard OR motherboard(bigger issue) is kaput
let me know how this works for you
SOURCE: Spill on laptop..how do I clean
ok -
First:
Disassembly guides with pictures:
How to remove keyboard.
http://irisvista.com/tech/laptops/ToshibaA55/SatelliteA55_remove_keyboard.htm
Remove laptop LCD screen. http://tech.irisvista.com/laptops/ToshibaA3/remove_laptop_LCD_screen.htm
Second:
ONLY clean with 95% - 99% rubbing alcohol, then wait till COMPLETLY dry before re-assembling.
Hope this helps.
SOURCE: How to clean coffee spill from Toshiba laptop
Have you tried to open a laptop? If not, try to go to service center it might causes more damage.But if you can, use a tissue and a ligther fluid to clean the keyboard membrane. Dry it well so that it cant causes shorted.... Thank you for using fixya....please dont rate me if you are not satisfied with my suggestions.
SOURCE: HPG60 Laptop - coffee spill - mouse not working
well this is a common thing but most likely the motherboard was shorted out and causing glitching. I would take it to a tech to see if there is anything recoverable in there
SOURCE: I spilled coffee on my Dell Inspiron 1545 laptop,
You might be able to find a cheap replacement palm rest (which includes the touch pad) on E-Bay or similar site. Just search your model number.
As far as replacing it yourself, I recommend having someone that works on computers regularly doing it, unless you are completely comfortable working inside the laptop. If you are (and you take all necessary precautions), here is the Service Manual from Dell which includes disassembly instructions for the palm rest.
http://support.dell.com/support/edocs/systems/ins1545/en/SM/index.htm
Testimonial: "This was much better information than I expected to receive."
SOURCE: how to remove keypad from compaq mini 110c, i
Try this link:
http://www.insidemylaptop.com/replace-keyboard-in-hp-mini-1033cl-notebook/
