Where is the fuel sensor located on a 3006 chevy trailblazer? I need to replace it.
Hi there:
On Trailblazer, the Fuel Tank Pressure (FTP) sensor is located on top of the fuel tank, mounted on the fuel tank module.
Additionally, check attached in fuel pump...
...push in the fuel level sensor retainer (1) on the bucket.
Hope this helps; also keep in mind that your feedback
is important and I`ll appreciate your time and consideration if you
leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
THIS WAS VERY HELPFULL ZJ.
Your welcome my friend!
to replace the sensor would the tank have to be dropped????
SOURCE: locate camshaft sensor 2002 chevy trailblazer
Assuming you have a 4.2L engine here is the location.
Hope this helps out,
if so please rate my answers.
Brett
SOURCE: 2002 Chevy Trailblazer Engine Codes
This is actually an easy swap out. Remove the electrical connection, remove the retaining bolt and pull out old one. I believe the sensor is located in the front passenger side of the engine on this particular model.
SOURCE: Where is the fuel filter located on a 2003 chevy
Located in the fuel tank and can be reached by removing the back seat.
Good luck.
SOURCE: is your 2002 trailblazer speed sensor located
Hi!!
The speed sensor is located on top or the transmission, towards the back end.
Don't forget to rate this post!!
SOURCE: Where is the map sensor
drivers side towards the rear of the intake plenum
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
