Question about EliteGroup P4VMM2 Motherboard
Ecc or non-ecc
Hello, I want to upgrade my memory and I'm presently using 1 stick: Azemram DDR 2.5, 256 mb PC-2100 266mhz I'd like to buy 2 stick of 512mb DDR 184 Pin DIMMs. But i don't know if I should use a ECC or Non ECC and i don't read anything about it in my mainboard user's guide P4VMM2). Will it make any difference? Could you Help? Thanks in advance, christian
  • christian nadeau Dec 29, 2006
    thanks for your collaboration,
    I'll try to locate these caracters...
    Although, in the user's guide it says that the motherboard is using a socket mPGA478...
    I don't know if it help ?
  • 624 Answers
What specific variant motherboard do you have? Your motherboard should be stamped with a P4VMM2 followed by several characters such as: (8.1), V1.x, V3.1, V3.x, V5.x or V7.3.
Posted on Dec 29, 2006
K7s8x asrock won't enter post after inserting ram upgrade
need more info.What memory did you use?
That MB requires either DDR PC2700 or DDR PC3200 Unbuffered,NON-ECC memory.
Max of 1gib per slot.
Jun 25, 2016 | Asrock K7S8X-R3 Motherboard
I bought 2 x 1 GB 128M x 72 333MHz PC2700 DDR SDRAM cards to upgrade my HP Compaq dx 6100 MT Pentium 4 Desktop - Upgraded the BIOS as prescribed...BUT if i insert these memory cards in any order in the...
wrong parts, its not support by chipset
Memory
One of the following
2-GB DDR Synch Dram PC3200 (400-MHz) Non ECC (2x 1GB)
Memory Speed Supported DDR Synch DRAM PC3200 (400MHz) non-ECC
Product documentation
Dec 20, 2014 | HP Computers & Internet
Will a Samsung 256MB DDR PC2700 CL2.5 184 PIN work
No that memory is not compatible. The Precision 350 uses memory called RDRAM aka RAMBUS.
Here are the speeds and sizes that are supported.
Memory modules supported PC800-40: 64-, 128-, 256-, 512-MB, non-ECC or ECC
PC1066-32P: 128-, 256-, 512-MB, ECC and 64-, 128-
,256-,512-MB, non-ECC
Minimum memory PC800-40: 128 MB non-ECC and ECC
PC1066-32P: 128 MB non-ECC and 256 MB ECC
Maximum memory PC800-40: 2 GB non-ECC and ECC
PC1066-32P: 1.5 GB non-ECC and ECC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/benjamin_29adbb94bfb43281
Sep 27, 2014 | Computers & Internet
Got an AsRock P4i65G mobo and bought 2 gig RAM for it. However, I have bought ECC memory by mistake instead of Non-ECC. PC wont boot with the new RAM. Is there any way I can get this to work such as with...
Hi, you can download a manual here:
http://www.asrock.com/mb/overview.asp?model=p4i65g
Your mainboard DOES NOT SUPPORT ECC RAM.
This ram type is ONLY intended for servers
or mainboards that are compatible for that ram type.
This is what your mainboard supports:
Dual Channel DDR memory technology
- 2 x DDR DIMM slots
- Supports DDR400/333/266 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
Use only the asrock site when upgrading the bios.
And a bios upgrade does not supports the ecc ram anyway.
Hope this will help you.
Aug 20, 2011 | Asrock P4i65G Motherboard
What memory can i upgrade to for my system?
The Gateway GT4022 comes from the factory with two sticks each of 512 MB PC3200 DDR 400MHz dual channel, non-ECC memory, for a total of 1GB (1024 MB). You have 4 slots for memory. Each slot can have up to 1GB for a total of 4GB's. You should install the memory in _pairs_ for best performance. Also, when installing in pairs, you'll need to populate the pairs in slots 1 and 3 (_not_ slots 1 and 2 if using only one pair). Slots tabs on slots 1 and 3 are white. The tabs on tabs 2 and 4 are black.
You can go to memory websites like www.crucial.com to get a free scan of your computer to see all the memory options available for your computer.
Mar 11, 2010 | Gateway GT4022 PC Desktop
I wish to add RAM in the PC. Mine motherboard-Epox-EP-4BDA533(I). ID(identification)-05/09/2003-i845d-6A69VPA8C-00. On it costs RAM 256Mb -DDR PC2100 266Mg FSB-400Mg. How many Mb it is possible to add....
Manufacturer Specifications - EPoX EP-4BDA533I Number of Slots:
Slot 1
Slot 2
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.*
*Not to exceed manufacturer supported memory.
  • 184-pin DIMM Banking: 2 (2 banks of 1)
  • Chipset: Intel 845D
  • Error Detection Support: ECC and non-ECC
  • Graphics Support: AGP 4X
  • Max Component Density: 512Mb
  • Max Unbuffered DDR SDRAM: 2048MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR SDRAM only
  • USB Support: 1.x Compliant
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: DDR memory with support for DDR PC2700,DDR PC3200 speeds.
Because DDR memory is backward-compatible, you can safely upgrade your system with any of the guaranteed-compatible DDR speeds listed below, even if your manual calls for PC1600 or PC2100 speeds.
Q: How much memory can my computer handle?
A: 2048MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No.
No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: No.
Your system does not support dual channel.
Q: Does my computer support ECC memory?
A: Yes.
Your system supports ECC. You can put non-ECC modules into an ECC system, but be sure not to mix ECC and non-ECC modules within a system. Install the same type of modules that are already in your system.
Jan 13, 2010 | ASUS Intel 845D Chipset P4B266 (P4B266-PA)...
I have a p4i45g MB with a p4 Processor. Do i use
- Max. capacity of system memory: 2GB DDR or 2GB SDRAM
- DDR x 2, DDR 266/200 non-ECC, un-buffered memory
- SDRAM x 2, PC133/100 non-ECC, un-buffered memory
use DDR1
Jul 14, 2009 | Computers & Internet
No manual - want to install SNP J0202C/512 myself
This (4th)link should answer all your questions. If you enter your service tag number Dell can help more You can also get help from where you buy the memory it's not that hard..I like the first link to find out what memory to buy. I like the second link for pricing. Please rate me mysleuth
http://www.memory-up.com/default.aspx
http://dealnews.com/memory/
http://www.ask.com/web?q=how+to+install+ram&search=search&qsrc=0&o=0&l=dir
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central?~ck=ln&c=us&cs=19&l=en&lnki=0&s=dhs&SystemID=DIM_PNT_P4_4550
Apr 08, 2009 | Dell Dimension 4550 PC Desktop
Want to add memory to Gateway 700x
Upgrading RAM on your Gateway 700X (DDR) Computer is easy, Gateway 700X (DDR) Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. RAM Type, and comes installed with 512 MB (removable) of RAM.
You can upgrade your Gateway 700X (DDR) Computer to up to a maximum of 2.0 GB RAM, the Computer has 4 sockets to install RAM, already with 512 MB (removable) standard RAM installed. For best Computer performance use the maximum amount of allowed RAM per slot for your system.
Dec 08, 2008 | Computers & Internet
Ram upgrade on Sony Viao PCVRS420
You can use even 1 stick of 2GIG of RAM or 2 X 1GIG of RAM or any combination will do for as long it will just be a max of 2GIG since that's the max support of your motherboard....
Oct 15, 2008 | Computers & Internet
EliteGroup P4VMM2 Motherboard Logo
116 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Matson Kurian
Matson Kurian
Joe Negus
Joe Negus
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
