Question about KitchenAid Superba 21.6 cu. ft. Top Freezer Refrigerator w/Factory Installed Icemaker
Oven door I inadvertently took the oven door off and now I cannot seem to get it back there a trickl to putting it back on?
  • staceyrosean Jan 21, 2009
    my oven door came off when i was moving it. what is the trick to getting it back on
  • jennifer9907 Feb 17, 2009
    oven door came off and i cant seem to get the hinges to stay pushed out. they keep popping back in. how do i get the door back on. what is the trick.
The hinges are very tightly spring loaded. pull the hinge out (be careful) and insert a nail or similar item in the hole that is exposed in the hinge after it is pulled out. the door will now slide down into place. just slide it down into place and remove the nails from the holes
Posted on Feb 25, 2009
Re assembling the door....
As a general rule of thumb, oven door glass assemblies are not intended to be removed for "cleaning" or some such procedure. Go to and enter RBS275PDB8. You will be presented with a list of common replacement parts and may be able to view a generic Whirlpool oven disassembly video which may help.
Aug 15, 2016 | Whirlpool RBS275PD Electric Single Oven
I took the door off my Simpson Evolution oven and now it won't go back on. Help
you have to push the hinge down and lock it you will need a screwdriver and turn the round disc the one will the slot in this will hold the hinge down do this both sides of the door and put the door back resting into the oven and then turn the slotted discs and that should do the job
Apr 21, 2012 | Smeg Evolution SCP171X Dual Oven
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
Hope this helps.
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
How to put oven door back on after removing!
Although very tight (because the oven is only 1 yr old) i managed to get the hinges into the open position, then slide the door into position on the oven and close the door. The hinges did go back and lock as they should but I struggled for almost 30 mins before success.
Jan 08, 2010 | Whirlpool GMC275PD Electric Double Oven
Can't get the door back on the oven
Yes, take a pair of pliers to pullout the hinges. They are springloaded and it seems hard but they are designed to keep the door shut tight.
Nov 30, 2008 | Kenmore 47783 Electric Single Oven
GE JKP45 double wall oven shuts off
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Nov 07, 2008 | GE JKP45 Electric Double Oven
Jen air locked latch after cleaning
I finally got my oven to work properly by shutting off the breaker and resetting the main clock. Cured the always locked problem as well as the beep twice when self cleaning.
Have to repeat this every few months since the problem seems to come back.
Feb 24, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Need help putting GE oven door back together again
they're called towers. They go on the 2 long screws once you've put the screws through - so they go between the two panels. They are used to space the 2 panels so that they line up flush when they are back together.
Jan 09, 2008 | Kitchen Ranges
How to take apart oven door
you need to remove the door. On your model just grab the door and lift and it should lift right off. Then remove the screws that run along the bottom of the door. Remove the bottom trim and the glass should slide down and off. Reverse to assemble
Jun 18, 2007 | Maytag MER5775Q Electric Kitchen Range
Refrigerators Logo
203 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
