Oil/grease Leaking from drive shaft seal.
My Hoover 750LA Washing Machine (new Jan 2001), has oil/grease leaking from around the agitator drive shaft, under the agitator, which is staining some washing.
Is there a replacement seal available ? Are any other parts required/recommended when replacing the seal? What would be aprox cost of parts?
Is it possible to replace the seal without completely dismantling the drive assembly?
Will appreciate your comments.
Thanks
Barry McNamara
  • sdcook5 Dec 31, 2008
    I have a similar problem with grease and oil leaking around the agitator on a Speed Queen washer
SOURCE: Hoover automatic 830 washing machine - leaking from under bowl
I had a Hoover 830, many years ago, it went for 15 yrs. solid. :)
Now I have a Fisher & Paykel IW 812 Intuative Washer
they are heaps nice too ... maybe time to get one of them?
maybe?
Posted on Jan 09, 2008
Lumpy816
  • 246 Answers
SOURCE: Leaking washing machine
Jan, if your pump needs to be replaced, I haven't seen a step by step instruction on it so far, so I hope this will do. First Unplug the machine and remove the remaining water from inside of it.(even after the spin cycle, water remains inside the bottom of the tub, the pump and the drain hose) The easiest way to do this is using a wet /dry vac, attaching it to the end of the drain hose that goes into the wall and sucking the remaining water out. Next pull the unit forward and tilt the top of it back about 45 degrees. (when you have it tipped back far enough, the top will rest against the wall behind the machine instead of tipping forward) Remove the belt from the pulleys underneath the machine. Remove the 3 bolts holding the pump to the base of the machine. Use a pair or pliers or channel locks to remove the clamps on the hoses attached to the pump. Install the replacment pump you've purchased from a local appliance parts sttore or bought from the manufactures web site on line by reversing the process. Run a quick fill/ spinto make sure you have no leaks.
Posted on Jun 17, 2008
  • 85 Answers
SOURCE: my hoover 750la only rotates one way something
you should be able to take the agitator out of the tub. from where you load the machine. pull it out. there should be some plastic pieces that normally flip back and forth like a rachet mechanism on teeth made into the plactic main piece.
these small plastic parts most likely have just worn out on one side to cause it to just agitate in one direction it is hard to explain how it works. these small parts are likely to be located at the top of the agitator where you may not have to take the entire agitator out. the parts will be under a center piece on top.
hope this helps....let me know. thanks
Posted on Jun 21, 2009
mgprice
  • 744 Answers
SOURCE: greasy oil and water is leaking from under the washing machine?
Hello, the good news is the water is coming from the pump and is easily replaced, the bad news is if you are seeing a yellow oily substance your transmission has a leak and will go bad at some stage soon. The question here you need to ask yourself is do you want to spend $35 on a new pump when your going to need to buy a new washer? If so pull the machine out and puch it back so it leans against the wall umder it's own weight. wedge some thing underneath the washer so you can access the bottom without the washer falling on you. you will see the pump attached to the motor which is attached to the transmission. remove the 2 clips and 2 pipes from the pump, remove the pump and replace it, reassemble in reverse order, you should be able to see where the leak came from the pump at the point where the motor shaft connected to the pump. Also while you are under there look at the base of the transmission, you should see some oily residue where the transmission fluid is leaking. Hope this helps! if you have any other questions please feel free to comment again. Good Luck!! Mike
Posted on Jul 21, 2009
  • 59 Answers
SOURCE: Stains on clothes after washing.
This could be a couple of things
1....oil from the transmission.
this is not common so lets leave this one
2.....the use of fabric softener causes greasy marks on clothing after a while
Fabric softener reacts with soap and can form a greasy jell. it can be yellow oily color or black.
You will know if you have been using fabric softener.
Stop using it straight away.
To clean oty the machine if it were mine I would put a packet of epson salts in with hot water and let the comp[lete cycly go.
Foe awhile use the machine with caution as this may release build up of grease which can stain further clothing until it is all gone.
The make and model of the washer is needed for an accurate diagnosis.
Posted on Aug 01, 2010
Hoover 700lc is putting grease on clothes
The only part of the washer that has oil or grease is the transmission. This is a very bad sign because it says the transmission is leaking and the center seal is also letting the oil grease come through. I would start looking at new machines because it wont be cost effective to repair if you pay a service comapny and if you've never done one its not something you want tot learn on.
Apr 28, 2012 | Hoover Washing Machines
Clothes left with grease smears
There are two real possibilities, both are in the washer. The first is
that the gear box seal is failing, and the second is that the fabric
softener dispenser needs to be dismantled and cleaned out.
"When the seal starts to fail, this oil floats up into the wash water
in the form of small black drops. The stains are almost impossible
to remove from clothing. Also, as the oil is leaking up, hot soapy
water is leaking down into the transmission, which will eventually
cause it to fail. As I recall, the seal wasn't difficult to replace,
but to get access to it I basically had to disassemble the whole
machine. The hardest part was pulling the agitator off the shaft - I
used a slide hammer puller. I'd start by pulling the agitator off and
see if you can access the transmission seal that way
Apr 15, 2008 | Frigidaire GLTR1670A Front Load Washer
F&P washing machine leaking from the bottom of the tub. I have checked the pump and inlets they are all good. It is an Intuitiuve Eco model about 5 years old. The leak seems to be coming the centre...
The seal has gone, you need to replace the seal and bearings and also the shaft as the seal wears into the shaft.. The leak would have started out as brown in colour, then as the grease is washed out of the bearings, the fluid will run clear, then the bearings will start to make a noise when the machine is doing the spin cycle.
Not an easy job to do, hardest part is fitting the seal properly without tearing the lip on the shaft where it drives the agitator. There is a cover available to do so, but only at autherised repair shops.
Apr 29, 2011 | Washing Machines
My simpson eziset 950 washing machine is leaking water and black grease. only onto the floor,no grease is getting on clothes
OK the trasnsinssion will be full of water and the contents are being forced past the lower oil seal during agitation. You might enwuire about a new transmission or get a new machine....not the best news but if you went for a stronger make you could own it for twenty years......no joke. www.thewashingmachineman.webs.com ask tony
Sep 07, 2010 | Washing Machines
Oil leak
instead of putting a gasket on tell him to take out all of the old grease out that is what has broken down and turning into oil causing a leak and if he can repace the seal around the agitator shaft replace the old grease with a high temp bearing grease or a good quality lithium grease
May 25, 2010 | Hobart A200 Stand Mixer
I have model A-200-D Hobart mixer. Serial # 1575984. It is leaking oil into the bowl. Who can I call to get an estimate to service or repair this machine?
The oil leeking into your bowl is old grease that has broken down into oil and is getting past your oil seal you need to take out all of your old grease and oil replace it with hi-temp grease or a good grade lithium grease and replace your agitor shaft oil seal
May 16, 2010 | Food Mixers
Our 2001 Dodge Caravan seems to be leaking oil around drive shaft
Yes it's a bad seal and most likely the side bearing to the trans axle is bad too. Once the bearing has play, it vibrates and causes the oil to leak though the seal. Note: if one side went bad the other side is soon to follow since they have the same amount of miles on them. Might as well change both side. Good luck and hope this helps. Keep an eye on the transmission fluid level, don't want to burn out the transmission.
Jun 04, 2009 | 2001 Dodge Grand Caravan
I have an oil leak on my clothes washer.
If you have a front loading washing machine the oil is really the grease for the bearings that support the drum. The grease seal needs to be replaced, and if you are replacing the seal you might as well do the bearings. This is not a cheap repair because of the amount of labor involved in tearing the machine apart to replace the seal and bearings. If you don't repair the seal, eventually the grease will be washed out of the bearings and the bearings will be destroyed. You can tell if you need new bearings because when the machine is on the fast spin cycle it will sound like a jet engine taking off.
May 24, 2009 | Washing Machines
Hobart A200 oil leak
grease coming out the planitary on bottom normally means it needs taken apart completley cleaned out of old grease and new seal and newer stile spacer seal goes around with the O-ring on it. and factory grease. the noise impossble from here to tell.
Sep 10, 2008 | Hobart A200 Stand Mixer
Oil seal
1. Remove the acorn nut, hex nut, and washer that hold the "planetary" agitator section on the transmission shaft.
2. Remove the trim ring (if any) around the same.
3. The agitator section should now be able to be worked free.
4. Remove the retainer clip on the top of the agitator shaft. (Some models have a pair of hex nuts here; if so, remove those.)
5. Pry the gear up and off the shaft. Remove the square key from the shaft keyway at the same time.
6. Tap gently on the top of the agitator shaft to drive it out from the bearings and grease seal.
7. Recommend removing and replacing the top bearing at this time; it's inexpensive to replace, if you're in this deep.
8. Use a suitable diameter piece of round steel stock to drive out the lower bearing and oil seal. I don't recommend using the agitator shaft.
9. Clean thoroughly, insert a new bottom bearing and oil seal, drive in place with a rubber mallet.
10. Replace agitator shaft through oil seal and bearing, tap gently into place.
11. Fill cavity with approved lubricant. I use USP-grade mineral oil, as it is food-safe and provides satisfactory lubricity.
11. Install top bearing, tap gently into place.
12. Reverse steps 5-1 to reassemble.
Aug 24, 2008 | Food Mixers
Washing Machines Logo
358 people viewed this question
Top Washing Machines Experts
