Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Bosch Nexxt Premium inlet valve solution you posted.
Our Bosch Next Pemium Washer will only run water through the detergent dispensing cup once. You diagnosed the problem but now where do I go to find a schematic or diagram showing me where the part is and how to replace it and also, where do I find a replacement part Thanks. sp
  • slp2004 Nov 27, 2008
    Your information was very helpful. I have ordered the valves and am waiting for their arrival.
    Thanks.
  • Bosch Master
  • 3,463 Answers
Hi.
You do not need a schematic for your washer, the valve is located at the top left rear of the m/c, where the hose is connected to.
Your best course of action is to contact Bosch direct for price and availability of valve.
Address as below
www.bosch.co .uk.
Or www.4bosch.co.uk/spares.
Hope this helps, and please bear in mind I have diagnosed this problem on the information supplied by you, so cannot guarantee it will solve your problem. Good luck
Posted on Nov 24, 2008
My bosch nexxt premium washer keeps getting check water tap light
Blocked inlet filter or kinked hose
if not then it will be your inlet valve
Feb 14, 2015 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt 700 Series Washer, water from cold supply does not dispense into detergent tray
Make sure that the cold supply is on and/or the supply hose is not crimped or clogged. Other than that it can be a control panel issue in the unit itself. But first eliminate the basic things.
Mar 25, 2014 | Bosch Nexxt 700 Series WFMC6401UC Front...
Soap dispenser overflowing with water
You will have to pull the dispenser tray out and clear any debris. I've seen a sock in one (who knows how that got there,) toys and even a glob of laundry detergent pods leavings.
Dec 21, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
How best to remove mold from my Bosch Nexxt 300 washer
any hard water remover hydocloric acid be careful dont breathe the vapors
Jun 08, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch Next Pemium Washer-intermittent detergent dispensing cycle
Hi.
Sounds like the valve that lets the water in on the dispensing cycle is sticking, if you can hear the valve buzzing i would certainly suspect it to be faulty
Nov 23, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch washer smell
Just clean the filter and make sure all the water drains from the pipes, That water can be a realy smelly story, i know.
Good luck...
Sep 07, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosh washer won't dispense softener. cleaned the tray and tested it by filling with water and it drained completly out, so i know its not clogged. washed another load and softener still there at end of...
I had the same problem. the only thing that works for me is fulling the fabric softener compartment all the way to the top with water then it will syphon down! it adds it to the load at the start instead on the rinse cycle but its better then nothing!
Jul 28, 2008 | Bosch Washing Machines
Detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
Feb 28, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bleach and softener dispensers filled with water at end of cycle
Yes, remove the dispenser tray by pressing on the button on the softner and pulling out tray completely. Now lift the flap over the softner compartment and clean thourougly with hot water, making sure all tubes and holes are free from residue softner/detergents. Replace flap by making sure the bigger tube fits OVER the smaller tube and click into place. Replace tray. Water is present due to the "syphon effect" of the dispenser not working, caused by residue detergents blocking the tubes/holes. Oshie
Oct 28, 2006 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
201 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
