Question about Maytag PAV2300 Top Load Washer
Washer Shaking Violently on Spin Cycle
Washer is 6 yrs old, over the last few months the shaking has slowly gotten worse until it locked up the other day. I found the water pump was bad and leaking, I replaced it and it worked great, smooth for about 5 loads then started really shaking violently. Through internet research I found the snubber was bad and replaced it and it then worked fine for about 10 loads. Really smooth, no shaking, until tonight and it almost took flight. What else is there that can cause this. The whole top of the tub moves about 6 inches in all directions!! All help would be greatly appreciated!!
    Sergeant:
  • 217 Answers
Yes, there is...The legs on the washer are adjustable, the rear legs are often ( not always ) self adjusting, make sure the legs are not stuck and that they can move freely. But the front legs can screw in and out to move the washer depending on the floor the washer is sitting on. Make sure the washer is as low to the floor as possible. When the legs are screwed out too far the washer becomes wobbly. Often on the metal style legs there are lock nuts that can be tightened to secure the legs so they don't move on you. washers where really meant to sit on a cement floor, if your washer is on a wooden floor look carefully at the strength of the floor. If the floor is moving up and down when the washer is running, the floor may not be strong enough to support the washers weight. Most main floor laundry rooms floors are nailed down, the sub-floor is more secure if the sub-floor has been screwed down. Sometimes extra support may have to be added under the flooring to add some strength for leaking issues Check the easy stuff first, fill hoses tight?- drain hose cracked?
Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
Posted on Nov 29, 2008
My maytag washer is shaking violently on the rinse cycle
I am currently having the same issue with my Maytag A482. Not sure if you have found a fix yet, or if you have replaced your washer. My washer runs fine until it nears the end of the cycle, when it begins to spin and shake violently, enough to loosen the leveling feet and rock back and forth. I pulled the front panel of the machine off (two screws near the base in the front, and two clips at the top) and ran a load through it. It ran fine until the end, when the machine started shaking violently. I did notice a few small pieces of roundish felt looking material sitting on the bottom, which after some research looks like it may be the damper pad. I found these online:
Damper pad 203956
Replacement Damper 203725 for MAYTAG Laundry Appliances A482
I am hoping this will resolve the issue, I will order them this afternoon and install them once they arrive. I really hate to replace such a good washer with a new high efficiency unit, which all seem to have terrible reviews after a few months/year of use.
Aug 25, 2014 | Maytag Washing Machines
Crown series washer shakes violently on spin cycle
When you put on the clothes inside the spinner make it equilibrium to prevent shaking violently.
Jan 29, 2012 | Frigidaire FWSB5700DS Top Load Washer
Washing machine shakes violently during spin
Hi
If your washing machine shakes violently or if there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Also check this link bellow:-
http://www.wikihow.com/Fix-a-Shaking-Washing-Machine
May 03, 2011 | KitchenAid Washing Machines
Washer is shaking violently when it is time for the spin cycle
Hi you must make sure its level in all directions. ie front to back and side to side. Alos dont overload it. If its on a wooden floor it will vibrate. A concrete floor is the best
Feb 15, 2009 | Washing Machines
Frigidaire gallery front load washer shaking
if you have had 12 yrs of trouble free service i think it would be safe to say there fine.especialy if they are'nt impeding the movement of the chassis or drum(or disturbing the operation of the shocks)if your still not sure contact the manufacture.hope this helps & good luck on putting that beast back together.thanx for using fix-ya,& please rate all replys, THENTHEREWERE
Nov 15, 2008 | Frigidaire GLTF2940ES Front Load Washer
Kenmore front loader washer squeaks in washer mode and shakes in spin.
shocks made of plastic squeaks, a little greese may help
Nov 08, 2008 | Washing Machines
Indesit w123 shaking
I had the same problem the drum when in spin cycle with the machine almost walked out the door shaking violently as if it was possessed. Check the drum on the inside of machine as most times it has some kind of screw to hold it in place for transporting etc. I did find on the other cycles it worked fine except for the spin cycle, and l have this machine in my caravan near my bed so you can imagine the ferocious noise and how scary it was, and it was a simple error on our behalf. I hope this resolves your problem. Kind Regards Karen.
Jun 24, 2008 | Indesit W 123 Front Load Washer
Frigidaire front-load stackable washer has violent shaking cycle
The Shipping bolts need to be removed from the back of the unit?? they go thru a plastic sleeve once the bolts are out you can twist the plastic peice to remove them completely I think there are 3 of them
Jan 24, 2008 | Frigidaire GLTF1670A Front Load Washer
2 problems smell and alwys out of balence
I leave the front load door open now between washes and that musty odor has gone away. As for the shaking, since I live in a mobil home I reinforced the floor and use the next to highest spin setting. My ultimate solution for all my LG W/D problems is going to be to sell the home and let the LG W/D set go with it.
Jan 23, 2008 | LG WM1814CW Front Load Washer
Maytag PAV2300 Top Load Washer Logo
675 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
