Question about Mag Innovision LT765b 17" Flat Panel LCD Monitor
Power goes green then back to standby
My flat screen suddenly stopped working. When you press the power button the light goes from amber to green then quickly back to amber. Screen does not flash or anything. I've tried it on a different computer and with a different video cable. The power supply is puting out the proper voltage. Any ideas?
  • 9,149 Answers
It sounds like this one needs component-level troubleshooting, probably in the power supply section.
Posted on Jan 02, 2007
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
Sony Bravia KLV-40X250A power indicator blinks once but screen is black
um u should turn your tv off for like 10 minutes , i think yourr tv is a internet tv so let it cool sometimes sony internet tvs freeze with black screen so try it out.
good luck :)
Aug 06, 2012 | Televison & Video
Hi, I have a 37lc46 LG LCD which takes ages to start. When I press the power button the standby light goes off for about an hour, when it comes back on again I have to continue pressing the remote power...
Replacement power supply is used?
You need to verify the DC output voltages of the power supply first and make sure this power supply has no bad caps with leaking/bulging tops. It goes into standby can also be that it detects fault some where in the set.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Dec 06, 2010 | LG 42LC2D 42 in. LCD HDTV
The monitor will not turn on. When power button
First--was it working?
Did it suddenly stop?
When you see the LG logo, then it goes away, does the power light turn from green to amber? Sounds like that doesn't happen.
So--if you are getting a signal, you should see something.
If there is no signal, then the power light should change from green to orange.
With no lights at all, I suspect a faulty monitor.
Feb 22, 2010 | Computers & Internet
My ps3 stopped showing picture ,it was working i turned it on i saw user screen then nothing,already replaced video cord
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
Thomson DTI6300-16 digital TV recorder frozen, red light on constantly, no resposnse to any commands. I think it needs a factory reset - how do I do this?
Try Resetting the box to its factory setting:
  • Menu > Setup > Help
  • Then press the Green Button (Even though it doesn't show as an option)
  • Then press the Red button for a full reset
Warning: You will lose all data on the Hard Disk!
I did this when mine wouldn't record anything and dumped all my pre-recorded programs.
Worked a treat.
Jul 20, 2008 | Televison & Video
Screen says attention no signal
Your TV is probably on the PC mode and you are not using it as a PC monitor.
You need to change the source by pressing the TV/Video button on the remote control or the SOURCE button on the TV itself. You may also just press the channel up or down buttons. Do this before the TV goes to standby mode (amber light) or while it shows the message: ATTENTION NO SIGNAL.
If it does not work, reboot the TV first and do this again.
May 17, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
Lg plasma 50px4d-eb keeps going into standby mode
good grief - my TV just did the same thing - its locked in standby mode - I disconnected power several times - each time i reconnect the green light comes on for about a minute 9nothing happens on the screen) and then returns to the stanby mode
Sep 27, 2007 | Televison & Video
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Mag Innovision LT765b 17" Flat Panel LCD Monitor Logo
328 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
