Question about Whirlpool Duet GHW9150P Front Load Washer
Has error code F 20 and will not finish cycle
The machine gets the clothes wet and begins to wash then shuts off an the F 20 error code pops up.
  • Anonymous Dec 03, 2008
    Washer starts...minutes in it shuts down with f20
  • cherylx May 11, 2010
    i've had this problem when i'm running a cold water cycle so it shouldn't require heating the water enough, although it kinda runs in the same vein as what you're saying. this is happening in warm weather so it's not like the water going in is freezing cold.
If your water is to cold it will have the same error. Somtimes the water from your water heater is not warm enough so you have to run the water from another source till it is coming out hot. this solved my problem every time.
Posted on Dec 05, 2008
Hi - my washing machine keeps f05 coding & the green start light won't come on
Is the outlet pipe blocked. Check this as sometimes the water gets backed up and this is sensed and an error is displayed
Mar 28, 2015 | Washing Machines
LE error code has popped up & suddenly the control lock is on, I have pressed the control lock & it counted 3,2,1 & nothing happens, won't unlock & LE is still there
if the door locks and wont unlock
LE error
then your machine still has water in it from the last spin/ wash
i think its a blocked up waste outlet
or the pump is blocked up
you need to check the machine is draining correctly and in a timely manner.,..
or it will fail
you need to fully drain the machine then turn off the mains
wait 5 mins and the door will then open
then check the drainage...
Feb 08, 2015 | Washing Machines
I have a 10 beep continous and showing e90 on my frigidaire washer, what will i do?
E90. The E90 error code is not a common error but it may occur when the washing machine electronics get wet for some reason. This may happen if wet clothes are left in the washer for a prolonged period after the wash cycle ends or if the same load is washed repeatedly.
Basic Reset
One of the first steps whenever an error code appears on a Frigidaire washer is to perform a simple reset to the machine. To reset the washer, press and hold the "Cancel" button for 15 seconds. Then try to set a new wash cycle and press "Start." Note that any clothes that have finished washing should always be removed promptly after the cycle is done.
Feb 26, 2014 | Frigidaire Washing Machines
E90 error
If the cancel button reset does not remove the E90 error code from the display, try a full power reset. To accomplish this type of reset, unplug the washing machine and wait 15 minutes or more. Then plug the washing machine back in and make a new wash selection. If the error code does not return, normal function may resume.
Unfortunately, if the cancel button and/or full power reset attempts do not eliminate the E90 error code, it is very possible that the electronic control board will need to be replaced. Here is the board to order.
Nov 29, 2012 | Frigidaire FAFW3577KR - Affinity 3.5 Cu....
My clothes are still very wet even after cycle is finished. It is like they are not fully spinning out, even when I select to do an additional spin cycle. Does anyone know why?
I'm an owner as you and do all my repair on multiple FAV6800A machines.
I don't feel from the info supplied that you have a drain pump/drain line issue because you do not take a "ND" error code for "no drain" during the wash cycle.....the wash cycle completes. I don't believe you have a stuck slightly open water inlet valve in the machine because I feel the machine would eventually over fill and flood the laundry area in time.
Is there any standing water in the wash basket when you remove the wet clothes after the final Spin Cycle?
I would place the machine in Service Mode and run it thru a Quick Spin Test (with a wet load) and record the fastest RPM speed the wash basket will spin up to.
You need the Service Manual to help you get into Service Mode to do the test. Are you going to DIY or call in repair service?
If you want to run the Quick Spin test I will look for a previous post on this forum where I called out the process steps.
Oct 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
Suds then f 35 error code then machine shuts off
try clean drain pump. be careful their lot of water in you washer. remove front bottom panel to get to drain pump. i hope i will solve your problem.
May 23, 2009 | Washing Machines
The spin cycle for my
Dear shelldon39, Fri 2-20-2009 9:24pm EST (USA)
Some machines will shut down during the spin cycle as a precaution to prevent damage!
They will do this if you overload the washer with clothes and/or use too much detergent!
If this doesn't help please get back to me with more details!
jack
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Duet GHW9150P Front Load Washer Logo
190 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
