Question about Microsoft Picture It! Publishing Platinum 2002 for PC
Picture It publishing platinum v.2002 - getting runtime error.
Have reinstalled program and still get this error when I drag a picture down to the tray. The message says that this application has requested runtime to terminate it an an unusual way.
Help
  • 1 more comment
  • Anonymous Dec 10, 2008
    Just bought the Picture it Publishing Platinum 2002, 5 CD set from online source and am expeiancing the same problem. Loaded the program into Windows XP. Thumbnail photos load OK, but when I try to move them into the tray I recieve the Runtime Error! message.
  • awagner615 Mar 03, 2009
    i recently installed ram and now when i try to use picture it publishing i get runtime error pip exe abnormal program terminate. Please can someone help?
    awagner615@aol.com
  • Anonymous Mar 23, 2009
    same with picture it 2002
4 Suggested Answers
20YrsCompExp
  • 227 Answers
SOURCE: runtime error
Does the Program issue you the name of the suspect runtime library at any point? If it does, go get the latest version of the runtime from the NET, in a searchengine type the name of the file+ext. download and then copy it in the same direrctory (folder) as the one on your system now. NOTE: I would FIRST rename the one on your system as <currentfilename.current_extention>and then add .OLD to it.
Posted on Mar 31, 2009
SOURCE: Corel Paintshop Pro Photo Xl
I have the same problem with Corel Paintshop Pro Photo X2 but I uninstall the program, do a disk clean up then delete internet cookies and delete the corel folder under
c:/progam files/corel
and also another corel folder under
c:/ Documents and Settings/All Users/Application Data/Corel
You will have to go to tools then folder options and then press the view tab to choose "Show hidden files and folders" because the "Application Data" folder is hidden. I then do a file clean up with Uniblue speed up my pc. Last but not least I reinstall the program. This will work only if I am disconnected and stay disconnected from the internet.If you connect to the internet you have to do the same process over again. I know this is alot of work but I really enjoy the program and its the only way I could use it. I have not found any fix yet but I hope this helps.
Posted on Jul 19, 2009
SOURCE: get a message like this:
http://webcache.googleusercontent.com/search?q=cache:OHz7E5ck-ncJ:www.viva-media.com/download/manuals/Technical_Support_Solutions_for_the_web_%25201-014-07.doc+nD3D9Texture::LoadD3DXFile():Failed+to+load+cube+texture'textures:System/defcube.dds'!&cd=1&hl=en&ct=clnk&gl=nz
This website above addresses your issue directly i think, this will show you how to fix it.
Posted on Jun 18, 2010
Testimonial: "Saw this solution and will have to try and see if this works. Thank you."
I have Microsoft Picture It II 2002 Publishing, which I truly do love. I use it at work, but I recently got a new computer with Windows XP, and I cannot get the program to load. It shows it there and...
Would you like to sell this program....I have it, and need to do a re-install due to corrupt files....unfortunately, I gave it away to the Goodwill, along with several other programs.....Allan B
...you can email me at Malibu1834@aol.com
Oct 29, 2010 | Microsoft Picture It! Publishing Platinum...
New PC,Windows 7(64 bit), reinstalled Microsoft picture It 2002. Get a message saying, program won't work properly.!? Any ideas?
there are to different types of computers when it comes to architectures 64 bit and 32bit the program you have is most likely 32 bit and it wont work on your 64 bit computer you can try downloading a 64 bit picture it! for your computer just google 64 bit picture it
Apr 06, 2010 | Microsoft Picture It! Publishing Platinum...
My Vista laptop will install MS Picture It Publishing Platinum 2002 but stops working when I try to run the program. I was told any PC software newer than 2000 will work on Vista.
Its not just the same that everything will work in vista. Do this procedure to work with the software. Go to the executable file (.exe ) of MS Picture Publishing and then go to its properties , u can find Compatibility Tab , in that select the Program to run in Windows XP Mode. So when u set the compatibility mode you can run the program in Windows Vista.
Nov 04, 2009 | Microsoft Picture It! Publishing Platinum...
I installed my picture it platinum 2002 i my new
Hi!
That means that the program isent compatible with vista, its only compatible and works with Windows 98 / 95 / 2000 / Me / XP / NT
I dont know if there is any pacthes out there to make it work with vista, i couldent find any.
Good luck
Nic
Aug 11, 2009 | Microsoft Picture It! Publishing Platinum...
Runtime error
Mar 31, 2009 | Microsoft Picture It! 2002 for PC
Microssoft picture it publishing platinum
This program is NOT compatible with Microsoft Vista.
Mar 27, 2009 | Microsoft Picture It! Publishing Platinum...
Picture it 2002 terminates when trying to open a project
Hi all!!! I am soooo excited!! I found a solution to fix the abnormal program termination with my picture it 2002!!!! Many, many thanks to John Inzer who made this info available!! I am no computer expert, but persistence and research paid off! My software is now up and running!!!! Click on the link below: microsoft.com/downloads....etc.
The best part is that it doesn't cost anything!!
Eve
Albirt wrote:
> Hi. I am having same problems with picture it.
> "Runtime error / abnormal program termination" message when I try to
> open picture.
> Windows XP and Picture It 2002 Photo.
> Could you reload file to yousendit ?
> Thanks
No problem....try the following link:
http://www.yousendit.com/download/UmNLcmxTSWVrWS92Wmc9PQ
The patch is also available from
Microsoft Download Center:
Picture It! Publishing 2002:
Patch for 19299 (PI19299.exe)
http://tinyurl.com/dfeq28
or...
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=0fb68178-d6bd-41bd-9f00-f44ac7ca9e28
Mar 08, 2009 | Microsoft Picture It! 2002 for PC
Program closes unexpectantly
If you have this premature shutdown problem go to http://support.microsoft.com/default.aspx?scid=kb;en-us;316861
and download this patch
Download PI19299.exe now
it will solve your problem, trust me it worked great for me. After weeks of searching for a solution this was so easy it ticked me off I didn't find it sooner!
Feb 10, 2008 | Microsoft Picture It! Publishing Platinum...
Microsoft Picture It! Publishing Platinum 2002 for PC Logo
337 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
