Question about Kenmore 63693 900 Watts Convection / Microwave Oven
Kenmore 63694 light replacement
The internal light bulb in the microwave is out. Can you tell me how to get to the bulb to replace it. I know you take the exhaust grate off the front. After that I am at a loss. This seems to be a very reoccuring problem with this model. Any ideas on how to keep this bulb from going out so often? Thanks, Stan
Forget about doing it yourself. You have to remove the entire cover to do it. After removing almost all of the screws, I found that two of them require a special tool which only appliance repairmen have. It looks like it would take a "star" screwdriver, but it is a special star with a hole in the middle. I ended up taking mine to a repairman. Then he had to special order the bulb because it is molded into a plastic base, not a screw-in bulb.
Posted on Jun 29, 2007
  • Kenmore Master
  • 9,156 Answers
You can enter your full actual model number at either the GE or Sears parts site listed below and get exploded view diagrams and parts lists. On many newer ovens, they have to be removed from the wall so you can remove the outer cover to replace the bulbs on top of the chassis, in the rear, or near the hood openings. This is a safety measure to protect the customer from line voltage and high voltage. It's important to have clean and dry hands when you handle the new bulb, especially if it's a halogen type. The parts sites: http://www.geappliances.com/shop/prts/ http://www3.sears.com/
Posted on Jan 02, 2007
Can't figure out how to replace light bulb for model #721.66319
Sears Parts Direct lists the microwave, 72166319500 , as using the lamp, 6912W3B002L. This is available for $6.49 here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Microwave-Parts/Model-72166319500/0582/0123245/50026833/00004?blt=06&prst=&shdMod= .
Unplug the microwave and wait a bit before starting to replace the bulb. To change the bulb, you first need to take off the entire cabinet (remove 4 screws on the back of the microwave and lift the part up). Then see the parts diagram on the page given above. There are 2 screws that hold the switch and bulb assembly to the frame of the microwave. I believe you should be able to pull the bulb housing down from the middle of the assembly and then push the unit up after replacing the old bulb with the new bulb. However, the bulb housing may have two screws holding it in place.
I hope this helps.
Nov 25, 2012 | Microwave Ovens
Remove Kenmore Mod. # 5648598601 from wall.
A lot of those you can replace the bulb without taking it down. There should be screws at the top that lossen up the vent in the front. Remove the vent, might have to open the door and slide it to the left (a little latch) then you should see a filter that just comes out and behind that is the bulb. I would try that before taking it down Forgot to mention that in the other e-mail.
Mar 04, 2009 | Kenmore 80412 Microwave Oven
Kenmore 363.6367 internal light doesn't go on
I had the same problem! I was soooo frustrated! But, when my brother came to town, he took off the grill on the top of the micro hood, took out a few more screws, a plastic screen, another screw in the metal cover for the light and then reached in with his fingers to pull out the light bulb, we replaced it, then re-assembled it. It did take us about 30 minutes to do the job and you will need a phillips screwdriver, and a phillips screwdriver drill bit thing, but we were able to do it. I love having the light in the microhood again.
Dec 09, 2008 | Kenmore 63672 Convection/Microwave Oven
REPLACING LIGHT BULB
i have a cookwork microwave the light stoped working
Sep 16, 2008 | Microwave Ovens
Replacing interior light bulb in m/n 63694
On many recent models, it is necessary to remove the mircowave from the wall, then remove the cover to change the cavity bulb. They suggest that only an authoirzed servider replace them, in order to avoid liability. You can enter your actual, full model number (63694 is not enough) and get helpful exploded view drawings and order parts at http://www3.sears.com (the three is correct). Do not handle the bulbs with bare skin, it will shorten their lives. Use a clean dry cloth or gloves.
Apr 29, 2007 | Kenmore 63692 / 63694 / 63699 900 Watts...
Siemens HF87950 Internal Bulb replacement
Move unit forward out from enclosure about 20cm....the light is covered by a small panel on top of the casing.(uses torx T20 screws) Remove lid and replace bulb!
Apr 11, 2007 | Siemens HF87951 800 Watts Microwave Oven
Kenmore 63693 900 Watts Convection / Microwave Oven Logo
140 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
