Question about Bose Wave Radio
I have a problem with time display on my Bose CD/Clock Radio.
When the radio is on, either because I turned it on or am using the sleep timer, the display stays fixed on the radio station setting. This happens whether I use the controls on the actual radio or the remote control. This problem began after a recent power outage. Prior to this, the radio station setting would display briefly when selected, then revert to showing the time. I want to be able to tell what time it is when the radio is playing. Any help would be greatly appreciated, thanks!
I found the answer on the Bose website in the manual for the radio. While the radio is on, hold down Alarm Setup and preset 1 at the same time. That will set it so the clock displays. If you do the same thing but hold down preset button 2, that will display the radio info all the time.
Posted on Dec 06, 2008
Why is my Bose radio is too dim?
The Bose Wave Radio has two brightness levels: Bright Hi (with a range of 8-15, and default of 10) and Bright Lo (1-8, default 4). The radio automatically goes from Hi to Lo when a room is darkened so the display doesn't interfere with sleep.
On recent models you can reset the defaults to make the display brighter or dimmer in both Hi and Lo levels.
1. Press and hold the Alarm Setup (Menu) button on your remote until -setup menu- appears in the display.
2. Then press the Tune/MP3 button until Bright Hi- appears. Use the Time - or Time + buttons to change the settings.
3. Go to Bright Lo- and adjust that setting too if necessary.
4. Press Alarm Setup (Menu) again to exit setup, or simply wait 10 seconds.
You're done! Note that if you set both Hi and Lo to 8, the brightness will stay the same all day and night.
Aug 21, 2014 | Bose Wave Radio
Instructions setting time bush stereo cd clock radio cr608cd
Hold the display mode button until the hours part of the clock flashes on alarm 1. Then press the sleep button twice. This will allow you to adjust the hours part of the time using the CD forward and reverse buttons. To adjust the minutes part of the time hold the display mode button again until the hours part of the clock flashes on alarm 1 . Then press the program button once and the sleep button twice. This will now allow you to change the minutes for your clock also using the CD forward and reverse buttons. Leave for a couple of minutes and your time is now set.
Aug 25, 2013 | Audio Players & Recorders
How to set alarm time on bose wave radio
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
Dec 02, 2010 | Bose Wave radio/CD remote control -...
My Bose radio clock switched to military time...how do I change it back? I do not have a remote.
Press and hold down alarm time, setup menu will display, using the arrows of tune/playlist, press the + button until either 12 or 24 hour time displays, then use the - or + to change to which time is desired. Then your clock is set to whichever time you chose.
Nov 07, 2010 | Bose Wave Radio
Dog knocked Bose CD radio off shelve. Doesn't work at all
Does the display light up for a couple of seconds? If so, try holding down the CD MODE and the on/off button at the same time. I hope this helps.
Aug 16, 2009 | Bose Wave Radio
Bose radio display doesn't show at all
I just posted a similar problem and did 2 more minutes of research on this site to figure it out. Hold down the 'cd mode' and press the on/off button. This turns the display on or off.
Jan 21, 2009 | Bose Wave Radio
Bose wave does'nt display light ' can't see the time, Help
Hi
I read that if you hold down the Clock Set button and use the volume adjust you can change the display brightness.
Hope this helps with your rpoblem
Aug 09, 2008 | Bose Wave Radio
Bose Wave Radio - clock display turns off after 1 minute
Hold down CD Mode button and press On/Off button to set display to always on.
Apr 09, 2008 | Bose Wave Radio
Clock on Bose Radio
Push & hold Clock Set Button. While holding, push On/Off button,
Thank You, FixYa Community! Thank you! Thank you! Boy, that one was not obvious.
Nov 06, 2007 | Bose Wave Radio
How do you set the wake up? So the radio turns on automatically? each morning
I did not find my manual, but this worked for me. Set the clock to be a 24 hour clock by pressing and holding the Memory/Clock Adj button. The display will show 24h or 12h. Use the fast forward button to change from 12h to 24h. Press the Memory/Clock Adj button again and use the fast or reverse forward buttons to change the time to read, for example, 13:00 instead of 1:00 if the time is 1pm. Press the Memory/Clock Adj button again to set the minutes.When you are done setting the time, press and hold the Timer/Sleep button. Either a time or "0:00" will appear in the display with the word "TIMER" flashing above it. Quickly press and hold the Memory/Clock Adj button until the first digit in the time starts flashing. Set the hour that you wish the alarm to sound using the fast or reverse forward buttons, just like you do for setting the time. Press the Memory/Clock Adj button again to set the minutes, and one more time to finish. The word "TIMER" will stop flashing and go solid, and the display will return to the time of day. When the alarm sounds, you can hit Snooze which will give you 5 more minutes, or you can turn the Clock Radio off. Pressing the Timer/Sleep button again will turn off the timer (alarm) and pressing and holding it again after that will turn it back on.
May 28, 2007 | Teac LT-1 Clock Radio
Bose Wave Radio Logo
321 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
