Samsung 52" LCD TV turns itself off and back on peroidically.
  • dkschmitz Nov 24, 2008
    Yes. I will follow up as it is still under warranty. Thank you.
  • 586 Answers
     This condition called hicking.This means that power IC get shorted.Contact any expert nearby to you.
     Thanks.
Posted on Nov 23, 2008
  • 19,396 Answers
That means that the tv is switching itself off because it detects an internal error, try leaving the tv unplugged for one hour and see if this can solve the problem.
If you still get the TV turnig off after plugging back the power, that means that there is an internal error. The tv must be taken part and tested by a technician.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, would only suspect a loose connection, a possible cold solder or a heat related issue. As of the moment doubt if any major component is faulty since the unit would still power on albeit would switch off thereafter.
It is important to have the exact model number. This would assist in narrowing possible problem. additionally, this would require opening the unit for a look & see. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
    Novelist:
  • 98 Answers
Sounds like your power supply is beginning to go out. If the TV is still under warranty, I would suggest going that route. If not, I would most likely sall around to get a few estimates on how much it would cost to fix it. I would say that you have a 99% chance that's what's wrong with it though.
  • James Allmond Nov 24, 2008
    No problem...glad I could be some help to you.
I hit the remote on button the 52"samsung tv
Tries tv unplug,replug it back like about an hour later.For the tv to resetting itself back to the factory setting,it should be working again.If it is still have the same problems,the causes mostly the power supply board have the problems,that the board where the power a/c cord plug into it.Tries websites like a Shopjimmy.com,Ebay.com to buy a refurbish power supply for the replacement.
Mar 21, 2011 | Samsung Touch of Color LN52A650 52 in. LCD...
Our 52" lcd was installed with a Bose surround
Tries tv and Bose audio system unplug,replug it back like an hour later.Both systems now,should be resetting itself back to the factory setting.Should work normal now.If still have the same problems.The tv Tuner signal board is having problems and dying.
Nov 08, 2010 | Samsung LN52A850 52 in. LCD HDTV
My 52" flat panal Samsung LCD keeps turning on and off by itself
that is the worst news you can receive from the manufacturer they pretty much shun you after the warranty has expired its very disconcerting and unfair to consumers I would make sure when you talk to them that the work that was done should have been under some warranty and if it was not the place the blame entirely on the technician who came in and tell them it was at least working to some extent cough cough before they sent someone who broke it even more if after this they dont comply boycot the brand and look for a new or gently used tv
Im terribly sorry to hear about this
Robb
Apr 29, 2010 | Samsung LN-R3228W 32 in. HD-Ready LCD...
52" Samsung LCD will not turn on. Blue light is on
Have you ssen the back light lit up? If not, the power supply may have problem. If it has back light, then the suspection are the main board, T-con and inverter. Those boards need checked to find out exact defective board.
Aug 17, 2009 | Samsung LN52A850 52 in. LCD HDTV
Self- reboots at start-up, then shows picture but with pink dots.
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts. It is the board to the left and you notice that the four cap tops are swollen.
It is easy to replace get a stanard solder pencil and you are in business.
Thanks for using FIXA, BIG IRISH.
May 24, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
