Question about Microsoft LifeCam VX-3000 Web Camera
Plug in camera
Where to plug in camera and microphone in the back of computer
  • bab_sb Nov 23, 2008
    where to plug in camera and microphone in the back of my computer
    President:
  • 8,637 Answers
Normal 0 Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger
Posted on Feb 05, 2009
My computer doesn't see mic when I plug in to the jack
First, did you plug in the microphone when the computer was off or not? If you connected the microphone while the computer was on, it may not have seen the new device to load the drivers. If the computer found the microphone when it was turned on, then the problem could be driver or hardware related.
You need to make sure that the computer is seeing this as the recording device. Click Start and select Control Panel from the right hand column. Click on the Hardware and Sound link. Select the Manage Audio Devices link under Sound. Click on the Recording tab. Is the microphone listed as plugged in? If it isn't, then the microphone isn't making good contact with the jack, has a bad wire or the jack isn't working. If you have another computer, check if the microphone works on it. That will rule out the microphone being faulty. Next go back to the starting Hardware and Sound Control Panel. Look for the link to the Device Manager under Devices. Expand the section for audio inputs and outputs. Check for a red triangle with an x or yellow triangle with an exclamation point. This indicates a problem with the audio drivers. Check with Toshiba for the audio drivers for your computer and the current service pack for Vista. You may need to uninstall the current driver and then reinstall that driver. A final option may be to check if the external audio input was disabled in the BIOS. When you turn on the computer, you should see a screen that tells you how to access the BIOS. (Usually this is F1, Esc, Del or F2). I find pressing the appropriate key repeatedly after turning on the computer doesn't always work. If you get to the Windows splash screen, turn off the computer at the login screen and try again.
If the microphone is plugged in, set it as the default device. You should be able to record with your software.
If the microphone still doesn't work with this computer and does work with another machine, you will probably be better off using a USB microphone or a USB audio adapter (USB to 3.5 mm microphone and speaker jacks). The wiring of the jack is probably faulty and it's not worth the effort to repair.
I hope this helps.
Dec 25, 2013 | Micro Innovations Microphones MM760 Mini...
Where is the microphone? I know where the microphone plug is but I can not find the physical microphone
Most computers/PC's do not come with a microphone. You have to buy a stand alone mic or headset with mic and then plug it into the microphone jack on the front or back of your comptuer.
Oct 18, 2013 | Dell Dimension 8400 PC Desktop
Where do you plug it in on the camera
What you are trying to plug,USB cable external microphone?
For USB cable normally the ports are located on the sides of the camera and have the USB symbol on the covering cap.If external microphone or flash check for the top metal shoe
Mar 31, 2011 | Cameras
I have a qhmpl webcam with 2 leads, a flat and a long lead - i don't know how to fix it to the computer, does it need a softwear to activate? help
The flat lead is a USB connector and the headphone lead is for the microphone. Both plug in on the back of your computer. The microphone plug is color coded to your lead so match those two up. The USB will match up with several ports on the back of your computer. You can use any of them. It will require software to use.
Look for the model number of the camera and look for it on this page where you can get the software you need:
http://www.qhmpl.com/drivers.html
Mar 02, 2011 | Computers & Internet
I want to plug my headset into this so that i can talk to people but I cannot figure out where to plug it in at
the headset should have 2 plugs one green one red they usually plug into the back of the computer with the speaker plug in the middle you could alternate these also make sure the microphone settings are correct
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
Feb 13, 2011 | Dell A215 Computer Speakers
How do i turn the microphone on, on my Toshiba laptop
1 . Turn your computer on. Be sure that the speakers on your computer are turned on as well.
2 . Attach the adapter to the microphone cable, if it has not been done already.
3 . Find your computer's microphone input. On most PCs, there will be an area in back of the tower with red, blue and green plug-in ports. The red port is the one for microphones.
4 . Plug the microphone cable into the red port. If you see ports that are labeled "line-in" and "mic-in," be sure to plug the microphone into the port that says "mic-in."
5 . Double-click the small speaker icon on your computer to open up the mixer. Make sure the microphone column is not muted and adjust your volume until you are satisfied.
Hope the above information will be helpful to you.
Thanks for using Fixya.
Nov 13, 2010 | Toshiba Computers & Internet
How do I plug my BA745 Boston speakers into a MAC desktop with one headphone outlet in the back?
I have the same speakers. It should have two plugs, one green and one pink. the pink plug is for a microphone. On the side of the speaker with the control knobs, you will find a headphone jack and a microphone jack. Unless you plan to plug a microphone into the pink microphone jack on the side of the speaker, you don't need to plug in the pink plug that goes to the PC. This is basically a microphone extension cord that runs through the speaker cord. That's all the pink plug is for. The green plug, on the other hand, is for your audio out. take the green plug and plug it into your computer's head phone outlet and you're good to go. You can use the speakers with any device that has a headphone jack. Just make sure you use the green plug, not the pink plug.
May 03, 2010 | Boston Acoustics BA745 Computer Speakers
Microphone not plugged in
It should plug into the sound card on the back of your computer. As a rule, the GREEN plug goes into the GREEN jack and the RED plug goes into the PINK jack on the sound card in the back. Look for these jacks and after you plug them in it should work.
Hope this helps. Bud
Apr 23, 2009 | Computers & Internet
Ax-12 computer mic
The Califone AX-12 has a 3.5mm connector on the cord. This should plug into the sound card on your computer... usually found on the back of the computer in the same general area that the speakers plug in.
Jul 14, 2008 | Califone International (AX-12) Consumer...
Microsoft LifeCam VX-3000 Web Camera Logo
23 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
