The SCSI-B connector is upopulated by default on the SE7520BD2V. Can I easily populate a connector and will it work? Thanks Christoph
Intel Bios update information states these as supported functionality:
1. 8 * DIMMs DDRII-400
2. Intel(R) Xeon(TM) Processor with 667MHz/800MHz system bus speed.
3. Multi-boot support.
4. System Flash BIOS ROM
5. COMA/COMB port
6. CD-ROM boot
7. Floppy port
8. PCI 33/66, PCI-X 66/100/133 mode 1, PCI-E x 4, PCI-E x 8,
PCI-X 66/100/133 mode 2 slots
9. ATI* Rage* XL VGA
10. Serial ATA
13. Clear CMOS
14. Legacy Power button
15. ACPI S0/S1/S4/S5
15. Setup screen
16. Summary screen during POST
17. Legacy USB keyboard / mouse / Floppy / CDROM / HD
18. ARM (ATAPI Removable Media) / IRM (IDE Removable Media)
19. Custom CMOS load/save
20. BIOS recovery
21. Intel Platform Security
22. Intel Server Management
23. LSI 53C1030 dual channel SCSI
25. Customer CMOS backup/restore
26. IMT support
27. User Binary feature
28. SERR/MERR detection & logging for runtime
29. Int15 for ABS2.0
30. ACPI SPCR (Serial Port Console Redirection)
31. NMI detection for PERR/SERR
32. Rolling BIOS
33. SOL (Serial On Lan)
34. Multi-disk Recovery
Item number 23 is this lsi chip: http://www.lsi.com/downloads/Public/SCSI/LSI53C1030/lsi53c1030_pb.pdf
You should locate that chip on the board, The information in the bios update functionality lists that as being functional; however I'm not certain if they mean you can put that lsi chip on professionally or if its there and you would just need to populate the connector to use it. I'm not sure if a bios update is required, they didn't mention that in any of the actual features added to the update, and they say that if updating the bios doesn't fix something, then you shouldn't attempt to update it anyway.
But a whole other issue is whether or not you should physically solder in a new connector or do you mean populated as in a wire is not plugged into a connector and going to a scsi hard drive
