Question about Bulova Watch
How to remove back from a Prague watch to replace battery
How do I remove the back of a Prague watch to replace the battery. Does it twist off or lift off. Not sure what tool to use to twist and there is not notch to pry the back off.
  • Anonymous Feb 07, 2009
    i have the same exact problem
Does the watch back for a Sharp SHP8903 twist off or pry off? I need to replace the battery.
If the back has notches, it probably is a twist off. Otherwise most likely a pry off. If in doubt, take your watch to a jeweler for battery replacement.
Jan 23, 2017 | Sharp Watches
How do i remove the back to replace the battery on this watch
Watch backs are usually either push-fit and simply need to be levered off, or are twist-fit and need to be rotated off. If there are a number of indentations around the rim of the back then it is likely to twist off. You need to get a suitable tool or tools to remove the cover or you will damage the back of the watch. Check on amazon or ebay for watch repair tools. Getting the cover back on is usually harder with push-fit and is more likely to lead to damage without the correct tools.
Or take it to a watch shop and they will replace the battery for you!
Jan 08, 2016 | Watches
How do i remove the back cover to replace battery.
you are going to need something small, i have used in the past, just a butter knife ***BE VERY CAREFUL
You should be able to see a very small tang over lapping the case, put your small butter knife under that and twist/lift at the same time.
Jul 19, 2011 | Watches
The crystal on my Prague watch cracked. Is this covered.
mcdevito75 here, It may be, best bet is to contact Prague watches at www.WatchesOutlet.com online. Once at page, left side of page click contact us and email them with your watches info.
Sep 21, 2010 | Prague Watches
How do you replace the battery in a ironman triathlon sleek digital watch
Thank you for contacting FIxYa.
Turn your Timex Ironman face down and remove the four screws holding the back cover in place.
  • Remove the back case cover by gently prying it up with your screwdriver. Be careful to avoid disrupting any electrical contacts with the tip of your screwdriver.
  • Remove the interior sticker that covers the battery by lifting it up with the tip of your screwdriver. It should come off relatively easily. At this point the small circular battery should be visible in the compartment.
  • Lift up the small metal clip (battery strap) that covers the battery using the tip of your screwdriver.
  • Remove the battery from its housing and replace it with your new battery (available at any electronics store or online). Reassemble the watch in the same way you to took it apart.
  • Sep 01, 2010 | Timex Ironman Triathlon 50 Lap Digital...
    Self winding Prague men's watch. Will not keep wind
    GOTO
    http://www.watch-clock-makers.org/
    Hope this tip helps.
    r/ David
    http://antiqueclock.clockstop.com/
    Mar 04, 2010 | Prague Sunray 49025G
    Prague skeleton EG-8901 loose penulum
    did you find a solution for this? I had the same problem. Good looking watch jeweler couldn't fix.
    Sep 23, 2008 | Prague Skeleton EG-8901
    Prague watch
    A New Battery?
    Aug 01, 2008 | Prague 49011-W
    Wristband Replacement
    Dear pickledpink,
    Go to http://www.voguestrap.com/ , you can buy a wristband replacement overthere
    Leather,metal,sports...., whatever you need
    Hope this was helpful :0)
    Kind regards,
    Gaby
    Mar 04, 2008 | Prague OT20LSLB
    Prague 49011G, automatic wind watch - stopped ticking
    I also have a Prague automatic watch (not the same model) which I purchased in 10/06 and have had it repaired twice. If you purchased the watch new, a little white warranty paper should have accompanied it. If not, you might be out of luck. Anyhow, each Prague has a two year warranty. My warranty instructed me to send the original receipt, a check for $10 (for return shipping) and the watch to Croton Repair; 195 Anderson Avenue; Moonachie, NJ 07074. There of course is no phone number to call them. Make the check out to Croton Repair. The warranty also says they do not guarantee they will fix the watch, but they guarantee they'll send you the watch back if it cannot be repaired. It took about 5 weeks and my watch came back repaired. Unfortunately about 6 months later it broke again, same exact problem (no long self-winds, ticks or keeps time, my watch also has a diamond at each hour, two of which fell out)... I've seen a lot of the issues people are posting seem to be the automatic watches not working. Probably duds, the inner workings seem to be very sensitive.
    Dec 24, 2007 | Watches
    Bulova Watch Logo
    69 people viewed this question
    Top Bulova Watches Experts
    Geoff
    Ansel Alberto
    Ansel Alberto
    Are you a Bulova Watch Expert? Answer questions, earn points and help others
