Question about Mitsubishi WS-65869 65" Rear Projection Television
Blinking green timer light won't turn off
Hi. I have a 65" WS 65869 and had to turn the power off in my house for some electrical repair. The green timer light won't stop blinking and I can't turn the tv on or anything else with it including the front panel controls and remote control. I thought the front panel might have been locked, but the procedure to turn that off didn't work. Usually after a power loss it only blinks for a minute and then everything works fine, but this time, it just doesn't stop blinking. Is there anything I can do to correct this on my own without having to call in a technician? Any help is greatly appreciated. Thank you.
  • waltsanders Feb 24, 2009
    I have the same problem. Power to our home was off. Now that the power has been restored, the green light will not stop blinking. We have tried the system reset and unplugging the set. The green light continues to blink and we cannot get the TV to respond.
  • 979 Answers
SOURCE: Mitsubishi WS-65869
This set will require that the power supply voltage problem be fixed...accordianman
Posted on Feb 27, 2008
Slinteriors
  • 8617 Answers
SOURCE: green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
Posted on May 16, 2008
SOURCE: Mitsubishi TV WS 65869 blinking Green Light
I have the same problem with my projection screen TV.
Posted on Dec 08, 2008
  • 126 Answers
SOURCE: Mitsubishi WS-65869 65" blue color problem
Yes, you need to replace the convergence output amplifier IC's. They can be ordered on line. After removing the back you must remove the circuit board which houses the amps. Then desolder them and install the replacemnts. If you are extremely lucky there won't be any re-alignment issues with the new amps. Then you should be good to go.
Posted on May 09, 2009
Slinteriors
  • 8617 Answers
SOURCE: not work ws-65869
The DM capacitors need to be replaced. Heres a link to the DM kit for your model which contains the replacement capacitors and instructions with pictures that show how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Posted on Jun 14, 2009
Mitsubishi 65" WS-65869 Blinking Green Light 3-2 pattern,
two ideas:
Make sure you tested the pico fuses inside the unit with the caps==two or three of them.
Also from front of set behind speaker grill unplug both plugs that go up to front keyboard--set will still work with remote===if set functions now then the reset micro switch is bad/damaged.
Mar 12, 2012 | Mitsubishi WS-65869 65" Rear Projection...
Green timer light in front of tv is blinking and tv picture will not turn on
http://www.fixya.com/support/r5069371-mitsubishi_led_keeps_flashing_green
Let me know if I can be of further assistance.
Sep 07, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Blinking green light on my mitsubishi tv....model ws-65869
Replace the Capacitors on the DM board. You can get the WS55859 DM repair kit which covers your model from www.tvrepairworld.com which has the caps and the CD with repair instructions
Jul 14, 2010 | Mitsubishi WS-65869 65" Rear Projection...
TV will not turn on
capacitors in power spply bad they will be bowed on top may need 4 or 6
Jun 09, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Green light flikering
Replace all 7 capacitors in the DM Module on the DM Power Supply Board. If it is similar to the WS-65869 and WS-65513 it will have a metal enclosed DM Module at far left of chassis, looking from rear. About 4 or 5 connectors, screws, and Module slides out. Take top shield off. Take good notes or use digital camera or video recorder to make re-assembly easy. These capacitors are 1000uf@16 volts. They always check good, just replace them! After re-assembly plug AC in and wait 90 seconds or more (green Timer LED will stop blinking), then press Power button. If Timer LED doesn't stop, look for small pinhole (System Reset) and press switch with pen or small screwdriver, then wait for green LED to stop blinking. Then Power On TV.
Feb 08, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi 65 inch Diamond rear projection
Sounds like your control unit has going down. its the big silver box in the rear to the left of the set.
Oct 28, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Blinking green light stays on and TV won't turn on.
Check for open pico fuse in power supply caused by bad convergence I.C.Get pro help-you have a good set to save.Remember--practice visual acuity technique!And,above all else,do no harm!!
Aug 26, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
60 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
