Question about Plumbing
Price pfister sb o34-4nss leaks
I got the handle off. pried off the cover and removed the allen screw. now i'm stuck! what next?
  • 1 more comment
  • Anonymous Nov 26, 2008
    how did you get the handle off? mine is loose and won't stay up and i'd like to tighten it.
  • RL2ThDr Dec 01, 2008
    I can't figure out how to get the handles off this grohe classic kitchen/bar faucet. How did you get the handles off. There is not "cap" to pry off. Does this model faucet screw off or pull off?
  • Anonymous Mar 16, 2014
    Price pfister c-l 533-50 handle won't come off
    Problem Solver:
  • 6 Answers
Well, this is generic for fixing a Price Pfister ceramic disc valve labatory faucet. On the top of the handle, there is usually a screw cover. Pry it off. Then insert a phillips screwdriver or allen wrench, depending on model and remove. Then remove the handle. At this time, make sure the water is shut off to the faucet. You'll need a socket or wrench to remove the cartridge. On many, the size is 3/4. Loosen all the way, then pull out the cartridge and replace. They are usually between 10-30$/cartridge. Insert new cartridge, tighten (but dont overtighten or you will kill the gasket), then replace the handle and turn on water. Check for leaks.
Posted on Nov 30, 2008
How do I remove a handle?
there is a small allen screw that loosens them and all come with the proper size when purchased .
May 30, 2015 | Price Pfister 01-81BC Savannah...
How do you remove the lever of a kitchen kohler clairette faucet, it seems to be stuck
On the front of the faucet handle, there is a small plastic cover with an emblem on it. Gently pry it off with a sharp knife blade. Next you will notice a small "allen" screw head. Remove it by turning it counter clockwise until it's loose. (lefty loosie - righty tighty) Lift the handle straight up to remove.
Jun 23, 2014 | Kohler K-15160-7 Coralais single-control...
Replace tub faucet
pry plastic cap, under cap remove Phillips screw,pull handle and replace
Oct 16, 2013 | Price Pfister Single HDL Bath Faucet...
Kitchen price pfister with spray that comes out of arm. Need to take off on/off lever at top to look for cause of leak. How to remove the on/off lever?
If you will look .....first thing would be a good idea to turn water cufoffs under the counter to off position....then remove handle,to do this there should be a set screw (hexagonal screw) on the bottom side of handle lever a heagonal wrench will be needed to remove handle...... Now that you have the handle off you can turn the cold side of the cutoff on or the hot side to find out which one is leaking hot or cold .......if indeed it is a washer ( rubber cup) that is leaking.......hope this helps...
Sep 05, 2011 | Price Pfister Plumbing
How do I remove handle? I REMOVE POP OFF COVER & PHILLIPS HEAD SCREW & HANDLE WON'T PULL OFF.
The handel should pull off it must me caroded up try pulling and twisting it at the same time.
Jan 21, 2011 | Price Pfister Genesis Luxury Kitchen...
HELLO THE FAUCET DRIPS AT THE HANDLE AND THE HOT AND COLD SEEM REVERSED
On this valve the hot/cold in reverse is easy enough to fix, but the faucet dripping at the handle is another issue. To reverse the hot and cold, turn off the house water, relieve the pressure by opening a nearby faucet. Once the water stops, remove the handle and faucet cover so you can see the valve. then the four screws that are visible need to be removed. Mark one of the screw holes with a crayon or pencil and then remove by pulling straight out. Once out, inspect the main o-ring right behind where it sits against the valve, (if this is damaged, it might be why the handle area is leaking) then turn the whole assembly clockwise 180 degrees then insert straight back in and insert screws. Tighten screws until snug. Turn water back on before installing cover and handle to check for leaks. If no leaks are found, install cover and handle and check for proper position of hot and cold. If there are leaks, tighten screws in clockwise rotation tightening each screw a quarter turn, then moving to the next one until dripping stops. If dripping is from center of stem, where the handle attaches, you will need to contact Price Pfister to request a replacement. They are very good to work with. Good luck.
Aug 15, 2010 | Price Pfister Universal 0X8-310A Pressure...
How to remove single lever handle does it require a spceial tool, because an allen wrech doesn't work
Most faucets have allen screws holding handle on or it may be recessed back in handle or if it is striped out may need to get a bolt extracter you can get them at hardware store pretty cheap.
Apr 25, 2010 | Price Pfister Single Lever Handle Faucet...
I have an 11 year old, single handle shower control that when turned off has dripping. I have taken off the handle, etc and am at the wall. What is the next step or steps?
After you remove the chrome collar and plastic collar washer (behind the faucet handle), pry the beauty plate off the wall. Turn off the house main water supply. Remove the four screws and washer holding the cartridge and valve stem in place. Save the metal washer under the four screws for use with the new cartridge. Replace the stem/cartridge assembly and secure with the saved metal washer and four screws. Reinstall beauty plate, collar & collar washer, then handle.
Dec 21, 2009 | Price Pfister R89-7PC0 Chrome Portland...
Pull out shower handle
HI jazzman45,
I'm Harvey the Master Plumber.
Your problem is: Pull out Price Pfister valve screw in the handle has separated from the valve. How do you pop the chrome cover to access the small screw to reattach to the valve? You don't want to just pry it off.
If you really don't want to pry it off then ask someone else to do it. That's all there is to it. Just be carefull not to scratch the chrome. From now on any time the handle feels loose retighten before it falls off and save yourself some grief. You'll find it's really easy.
Feel free to contact me again
Don't forget to give me a rating on fixya before you leave.
Harvey your Master Plumber
Oct 15, 2008 | Plumbing
Plumbing Logo
852 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
