Question about RCA RT2760 System
RCA RT2760 NO DISPLAY
I HAVE NO DISPLAY. I DONT KNOW IF DIMMER IS SET TO "0". I TRIED TO RESET WITH REMOTE. DOESN'T WORK. I TRIED TO HOLD IN THE ON/OFF BUTTON. DOESN'T WORK. SOMEONE HELP PLEASE.
TVtechmaniac
  • 140 Answers
SOURCE: Buttons dont respond correctly
Sounds like one or more of the keypad buttons are sticking - That would also cause the remote control to stop functioning.When you saw "P:0 V:0" you somehow managed to put the tv into the service menu. Pull the keyboard away from the plastic buttons and make sure nothing is in the way.
Posted on Aug 23, 2007
  • 3289 Answers
SOURCE: I purchased a rt2760 system with no manuals. I
You can download the manual free of charge at RCA's website. The link for your particular device is below:
http://support.rcaaudiovideo.com/manual.aspx?product=46
I hopw this was very helpful - good luck!
Posted on Jun 24, 2010
SOURCE: RCA RT2760 Home Theatre
having problems with fuse and power.
Posted on Sep 04, 2010
jdvillanueva
  • 2098 Answers
SOURCE: Subwoofer stopped working on my
First check if the speaker is not faulty. Using your ohmmeter(set in resistance measurement) test the continuity of the speaker. If not available, spare battery (D,AA,AAA) may used to confirm the sound from the speakers(test the two wire of the speaker through both end of the battery). Upon testing the continuity of the speaker you will hear a slight crackling sound .
No sound - your speaker voice coil is already open(blown). You must replaced it with new one or rewind the voice coil to the shop specialized in speaker rewinding.
Yes it has sound - Then the fault was came from the amplifier/receiver. I'm assuming that the settings is correct and the speaker is properly hooked up, the sub-woofer sound output IC(mounted in heat sink) is going to be check for faulty. Most of the case it was already blown(shorted or open). You must check it using the ohmmeter.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for an experienced technician to isolate the problem.
Also, check if your unit is still under warranty perio(1 year from the date of purchased), avail it because the manufaceturer will fix it for free. Don't attempt to open the cover of the unit, it will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 17, 2011
Captions are on ther tv and i cant get into the menu. A message keeps popping up saying blog. fpa escend and i dont know what to do please help
Hello
Just reset your RCA tv by the following method. After reset you have to enter a new parential code and proceed.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the [0] button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Feb 23, 2011 | RCA TruFlat 27F520T 27" TV
I have a RCA surround sound system RT2760 the remoye has been destroyed, where can I purchase a new remote?
You can either try ordering a that specific remote from RCA. or you can buy a "universal" remote from Wal-Mart, Shopko, Target etc.
You can also go to the RCA website and contact customer support through this link:
Feb 11, 2011 | RCA RT2760 System
My tv got locked by parental control.. I dont know what to do please helpme
Hello
Just try the following. One amoung these process will surely unlock your TV. After unloking you have to reset the V-Chip.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
OK
Dec 21, 2010 | RCA 24V510T 24" TV
I purchased a rt2760 system with no manuals. I need to know how to program other devices into the remote. exam. dvd player, tv, etc. please help
Jun 24, 2010 | RCA RT2760 System
Need 4 digit password for rca tv 2003
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it’s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Sep 29, 2009 | Televison & Video
My rca tv has locked the parental code and dont have manual or the code
Jul 06, 2009 | Televison & Video
How to reset parental controls
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it’s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
Apr 29, 2008 | RCA 27V530T 27" TV
RCA RT2760 System Logo
37 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
